06-08-2019, 08:05 | #17 (permalink) |
Freak Poster Join Date: Nov 2014 Location: Algeria
Member: 2287326 Status: Offline Thanks Meter: 54 | I need to recover the phonebook from a “huawei ascend g7500” with sc8810 chip. It’s stuck on Huawei logo What can I do? It is not supported by infinity box! |
06-08-2019, 11:30 | #18 (permalink) |
No Life Poster Join Date: Sep 2009
Member: 1109337 Status: Offline Thanks Meter: 197 | starmobile play click LTE frp not done logs say OK but on actual phone frp still not removed please fix on next update thanks Code: Operation : Format FS / Reset Settings [ v2.00r2 ] Mode : Reset FRP 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC9832E_BASE : SC9832E_eMMC_1GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:53 Operation : Format FS / Reset Settings [ v2.00r2 ] Mode : Default [ Reset Settings + FRP ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC9832E_BASE : SC9832E_eMMC_1GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:01:02 |
06-08-2019, 12:04 | #19 (permalink) |
No Life Poster Join Date: Nov 2012 Location: Ek India Happy Wala.. :-)
Member: 1834832 Status: Offline Thanks Meter: 1,450 | Is Anyone Check Read Sec Info. As I Checked With 2 Phones But No Changes In Log (Not Found Anywhere Written Read Sec Info : Enable/Yes) As Well As Txt Also Same On Both Mode After Tick Sec Info N Without Tick SEC Info... With Tick Read SEC Info Operation : Identify [ v2.00r2 ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Micromax : Micromax Q402+ Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Device info : Patch Level : NRD90M Display ID : MMX_Q402+_000_0118_V3.0_070818 Ver. CodeName : REL Ver. Release : 7.0 Sec. Patch : 2018-06-05 Build Time : 1533643027 Product Model : Micromax Q402+ Product Brand : Micromax Product Name : Q402Plus Product Device : Q402Plus Product Board : Micromax Product Manfct : Micromax Board Platform : sc8830 Product Info : Q402Plus UserData : STATE : ENCRYPTION Done! Elapsed: 00:00:37 Without Sec. Info Tick Log Operation : Identify [ v2.00r2 ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Micromax : Micromax Q402+ Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Device info : Patch Level : NRD90M Display ID : MMX_Q402+_000_0118_V3.0_070818 Ver. CodeName : REL Ver. Release : 7.0 Sec. Patch : 2018-06-05 Build Time : 1533643027 Product Model : Micromax Q402+ Product Brand : Micromax Product Name : Q402Plus Product Device : Q402Plus Product Board : Micromax Product Manfct : Micromax Board Platform : sc8830 Product Info : Q402Plus UserData : STATE : PLAIN Done! Elapsed: 00:00:34 (Note :- About User Area State Is Different As I Take 2nd Info After Format Device) Read Sec. Info For Read IMEI N Check NV Status Right...? |
06-08-2019, 12:17 | #20 (permalink) | |
Member: 1834832 Status: Offline Thanks Meter: 1,450 | Quote:
Try Forced Mode.... | |
06-08-2019, 12:51 | #21 (permalink) |
No Life Poster Join Date: Jan 2013 Location: zimbabwe south africa
Member: 1866877 Status: Offline Sonork: 100.1681933 Thanks Meter: 707 | YES SEC INFO IS NOT SHOWING Code: Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_512MB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! UserData : STATE : DAMAGED Done! Elapsed: 00:00:42 Operation : Identify [ v2.00r2 ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_512MB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! UserData : STATE : DAMAGED Done! Elapsed: 00:00:27 |
06-08-2019, 17:11 | #24 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
Does it even try connect to PC? Give to log connection string? | |
06-08-2019, 17:12 | #25 (permalink) | |
06-08-2019, 17:17 | #26 (permalink) | |
Info about security will read with both - ReadInfo and SecInfo enabled. Read SecInfo for android, lower than 8, not possible in pre-release Rx versions. Data state changed after format, it okay until first boot ( if factory-enabled ) or because user set it forcedly. In some cases state shown as DAMAGED because SPRD default FS is very ugly and made in uncommon way ( probably for resource saving and other cheap tricks to make that thing work faster ) | |
06-08-2019, 17:22 | #27 (permalink) | |
Does after operation finish - it show Erasing circle? | |
06-08-2019, 17:26 | #29 (permalink) |
No Life Poster Join Date: Jun 2016 Location: UK
Member: 2581848 Status: Offline Thanks Meter: 249 | Created by Infinity-Box (c) 2019 Chinese Miracle II : MediaTek Service Module Device Info file : _Android_info.txt Patch Level : O11019 Display ID : Digicel_DL501_V8.0_20181023 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2018-09-05 Build Time : 1540294607 Product Model : DL501 Product Brand : Digicel Product Name : DL501 Product Device : DL501 Product Manfct : TEM Product Info : k39tv1_bsp_1g Product Board : DL501 Board Platform : mt6739 |
