Old 06-26-2019, 17:12   #61 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
@pink009, in next version we can try atleast check it, how much security cookies are active.
Old 06-26-2019, 17:31   #62 (permalink)
Member: 2576731
Thanks Meter: 72
Smile Firmware read
Pls enable firmware read for spd android 8
all is not acept to read firware
and imei repair pls great team
Old 06-26-2019, 19:30   #63 (permalink)
Member: 2515171
i cant use it to reset itel a14 and a16 frp it gives me change settings
Old 06-26-2019, 20:23   #64 (permalink)
JayDi's Avatar
Member: 462970
So, do as SW asks - change them!
Old 06-29-2019, 10:25   #65 (permalink)
KrzychuG's Avatar
Member: 25996
Thanks Meter: 253
Any chance to get read data/memory tool working in close future? Only UFI seems to have a semi working option to read data, including userdata but the dump seems incomplete. If it worked here it would be something unique.
Old 07-01-2019, 14:20   #66 (permalink)
aminnovelty's Avatar
Member: 566122
Thanks Meter: 322
Q MOBILE XLi
Dear supporter i got q mobile XLi new SPRD3 cpu ,,on FRP lock ,,,but my question is how can i come to know that which boot selection is require ?
Waiting for kind replies ,,,, if anybody knows about it ,
Old 07-01-2019, 15:13   #67 (permalink)
Member: 2869072
Thanks Meter: 107
Select Mobicel Astro. Volume + is boot key.
The Following User Says Thank You to MinPin For This Useful Post:
Old 07-23-2019, 13:47   #68 (permalink)
Member: 2267293
Thanks Meter: 79
I'm ready for test version...
IT'S GLAD WE HAVE THIS NEW SOFTWARE BUT I NEED SP UNLOCK FOR THIS DEVICE...
Operation : Identify [ v2.00r2 ]
1. Power off device, wait 10-15 seconds
2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- )
3. Insert cable in device!
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : 0_SC9832E_BASE : SC9832E_eMMC_1GB_RS
Sending Init Boot ...
Boot sent!
Kick FDL ...
BootVersion : Spreadtrum Boot Block version 1.1
Protocol setup ...
Port speed : 921600
Sending Flash Boot ...
Boot sent!
Kick FLASH FDL ...
FDL : Control transfered!
Boot Done!
Device info :
Patch Level : OPM2.171019.012
Display ID : SFC_NEON RAY_V05_20190424
Ver. CodeName : REL
Ver. Release : 8.1.0
Sec. Patch : 2019-04-01
Build Time : 1556357453
Product Model : NEON_RAY
Product Brand : Safaricom
Product Name : NEON_RAY
Product Device : NEON_RAY
Product Manfct : Safaricom
Product Info : NEON_RAY
Product Board : NEON_RAY
Board Platform : sp9832e
SecInfo :
IMEI[1] : 355XXXXXXXXXXX
IMEI[2] : 86XXXXXXXXXXXX
IMEI[3] : 8XXXXXXXXXXXXX
WIFIMAC : FFFFFFFFFFFF
BT_MAC : FFFFFFFFFFFF
UserData : STATE : ENCRYPTION
Done!
Elapsed: 00:01:01
Old 07-25-2019, 09:28   #69 (permalink)
mbiborna's Avatar
Member: 770503
Thanks Meter: 1,215
Itel A46 Aka itel L5503 Boot File.
Tested 100%
The Following User Says Thank You to mbiborna For This Useful Post:
Old 07-25-2019, 10:42   #70 (permalink)
Member: 2110006
Thanks Meter: 11
why read firmware disable and imei repair option not showing ?
Old 07-28-2019, 16:52   #71 (permalink)
Member: 2440478
Thanks Meter: 24
pls update for read firmware and imei repair option showing.
Old 08-01-2019, 10:17   #72 (permalink)
Member: 2617208
Sonork: none
Thanks Meter: 5
CM2 Dongle CM2SP2 exe not running
Hi,
I purchased new CM2 Dongle in our local supplier.
All Functions are working fine but, when i've installed CM2SP2 newly update (InfinityBox_install_CM2SP2_v2.00-r2) and when i try to run the program, IT ONLY SHOWS LOGO and disappear. Nothings happen. Please guide me how to solve it because i have a lot of work on SPD.
Dongle INFO:
Token
- Type: Infinity-Box/Dongle
- Account Status: Active
- Hardware Status: Ok
Services
- Activation 1: Infinity-Box/Dongle; S/N: XXXXXXXX; Firmware Version: 0138; Registered: 13-Jul-2019; Expired: 12-Jul-2020; Support: Active
- More Services may be active but not listed
Old 08-01-2019, 12:31   #73 (permalink)
Member: 2812901
Thanks Meter: 493
Try to scan your pc with strong antivirus.
The Following User Says Thank You to Oyetunde Semiu For This Useful Post:
Old 08-01-2019, 12:33   #74 (permalink)
Member: 2812901
Thanks Meter: 493
You can also change the installation position to..... C/ program file.
Old 08-02-2019, 05:36   #75 (permalink)
Member: 2617208
Sonork: none
Thanks Meter: 5
Problem Solve Thank you Sir. i Change installation folder to C/ program files and it works now.
Page generated in 0.23749 seconds with 10 queries
