Old 06-07-2019, 22:03   #16 (permalink)
Member: 2545468
Thanks Meter: 62
thanks for the infinite equipment update !!
Old 06-08-2019, 09:05   #17 (permalink)
Member: 2287326
Thanks Meter: 12
I need to recover the phonebook from a “huawei ascend g7500” with sc8810 chip.
It’s stuck on Huawei logo What can I do?
It is not supported by infinity box!
Old 06-08-2019, 12:30   #18 (permalink)
Member: 1109337
Thanks Meter: 168
starmobile play click LTE frp not done
logs say OK but on actual phone frp still not removed
please fix on next update
thanks
Operation : Format FS / Reset Settings [ v2.00r2 ]
Mode : Reset FRP
1. Power off device, wait 10-15 seconds
2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- )
3. Insert cable in device!
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : 0_SC9832E_BASE : SC9832E_eMMC_1GB_RS
Sending Init Boot ...
Boot sent!
Kick FDL ...
BootVersion : Spreadtrum Boot Block version 1.1
Protocol setup ...
Port speed : 921600
Sending Flash Boot ...
Boot sent!
Kick FLASH FDL ...
FDL : Control transfered!
Boot Done!
Wipe Ok : FRP
Reconnect Power/Cable!
Done!
Elapsed: 00:00:53
Mode : Default [ Reset Settings + FRP ]
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
Boot Done!
Wipe Ok : UserData
Wipe Ok : Cache
Wipe Ok : FRP
Done!
Elapsed: 00:01:02
Old 06-08-2019, 13:04   #19 (permalink)
hitech care's Avatar
Member: 1834832
Thanks Meter: 1,233
Is Anyone Check Read Sec Info. As I Checked With 2 Phones But No Changes In Log (Not Found Anywhere Written Read Sec Info : Enable/Yes)
As Well As Txt Also Same On Both Mode After Tick Sec Info N Without Tick SEC Info...
With Tick Read SEC Info
Operation : Identify [ v2.00r2 ]
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : Micromax : Micromax Q402+
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
Boot Done!
Device info :
Patch Level : NRD90M
Display ID : MMX_Q402+_000_0118_V3.0_070818
Ver. CodeName : REL
Ver. Release : 7.0
Sec. Patch : 2018-06-05
Build Time : 1533643027
Product Model : Micromax Q402+
Product Brand : Micromax
Product Name : Q402Plus
Product Device : Q402Plus
Product Board : Micromax
Product Manfct : Micromax
Board Platform : sc8830
Product Info : Q402Plus
UserData : STATE : ENCRYPTION
Done!
Elapsed: 00:00:37
Without Sec. Info Tick Log
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
Boot Done!
Device info :
Ver. CodeName : REL
Ver. Release : 7.0
UserData : STATE : PLAIN
Done!
Elapsed: 00:00:34
(Note :- About User Area State Is Different As I Take 2nd Info After Format Device)
Read Sec. Info For Read IMEI N Check NV Status Right...?
Old 06-08-2019, 13:17   #20 (permalink)
Member: 1834832
Thanks Meter: 1,233
thanks
Mode : Reset FRP
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
Boot Done!
Wipe Ok : FRP
Done!
Elapsed: 00:00:53
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
Boot Done!
Wipe Ok : UserData
Wipe Ok : Cache
Wipe Ok : FRP
Done!
Elapsed: 00:01:02
Try Forced Mode....
Old 06-08-2019, 13:51   #21 (permalink)
nessyb's Avatar
Member: 1866877
Sonork: 100.1681933
Thanks Meter: 659
YES SEC INFO IS NOT SHOWING
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_512MB_RS
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
Boot Done!
UserData : STATE : DAMAGED
Done!
Elapsed: 00:00:42
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
Boot Done!
Done!
Elapsed: 00:00:27
Old 06-08-2019, 14:12   #22 (permalink)
Member: 10168
Thanks Meter: 136
CM2SP2 r1 has a Security tab but it's missing on CM2SP2 r2.
Old 06-08-2019, 14:35   #23 (permalink)
Member: 1834832
Thanks Meter: 1,233
Will Update In Upcoming Ver
Old 06-08-2019, 18:11   #24 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 15,655
Can't find anything about this model at all.
Does it even try connect to PC? Give to log connection string?
Old 06-08-2019, 18:12   #25 (permalink)
JayDi's Avatar
Member: 462970
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
Boot Done!
Done!
Elapsed: 00:00:42
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
Boot Done!
Done!
Elapsed: 00:00:27
SecInfo will be shown during enabled ReadInfo only. Platform-specific.
The Following User Says Thank You to JayDi For This Useful Post:
Old 06-08-2019, 18:17   #26 (permalink)
JayDi's Avatar
Member: 462970
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
Boot Done!
Device info :
Ver. CodeName  : REL
Ver. Release   : 7.0
Done!
Elapsed: 00:00:37
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
Boot Done!
Device info :
Ver. CodeName  : REL
Ver. Release   : 7.0
Done!
Elapsed: 00:00:34
Please, use CODE tag for logs. It really makes things more easy for reading.
Info about security will read with both - ReadInfo and SecInfo enabled.
Read SecInfo for android, lower than 8, not possible in pre-release Rx versions.
Data state changed after format, it okay until first boot ( if factory-enabled ) or because user set it forcedly.
In some cases state shown as DAMAGED because SPRD default FS is very ugly and made in uncommon way ( probably for resource saving and other cheap tricks to make that thing work faster )
Old 06-08-2019, 18:22   #27 (permalink)
JayDi's Avatar
Member: 462970
thanks
Mode : Reset FRP
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
Boot Done!
Wipe Ok : FRP
Done!
Elapsed: 00:00:53
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
Boot Done!
Wipe Ok : UserData
Wipe Ok : Cache
Wipe Ok : FRP
Done!
Elapsed: 00:01:02
After Forced one mode - does device startup in SetupWizzard or not?
Does after operation finish - it show Erasing circle?
Old 06-08-2019, 18:22   #28 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 6,978
Hello,
Info about security will read when selected options - ReadInfo and SecInfo.
Br.
Infinity-Box Team.
Old 06-08-2019, 18:26   #29 (permalink)
Member: 2581848
Thanks Meter: 227
Created by Infinity-Box (c) 2019
Chinese Miracle II : MediaTek Service Module
Device Info file : _Android_info.txt
Patch Level : O11019
Display ID : Digicel_DL501_V8.0_20181023
Ver. CodeName : REL
Ver. Release : 8.1.0
Sec. Patch : 2018-09-05
Build Time : 1540294607
Product Model : DL501
Product Brand : Digicel
Product Name : DL501
Product Device : DL501
Product Manfct : TEM
Product Info : k39tv1_bsp_1g
Product Board : DL501
Board Platform : mt6739
Old 06-08-2019, 18:52   #30 (permalink)
rebainoor's Avatar
Member: 231728
Thanks Meter: 1,304
Originally Posted by JayDi View Post
If you select PAC as FDL base - you dont need select anything more, if you select fdl1/fdl2 - they must be exactly fdl files, not pac or anything else.
may be you can add auto create loaders (*.fg) from PAC file to get smal size in future update
Page generated in 0.44973 seconds with 8 queries
