05-25-2020, 06:49 | #137 (permalink) |
No Life Poster Join Date: Sep 2014 Location: Technology town
Member: 2252481 Status: Offline Sonork: 1660352 Thanks Meter: 206 | this phone is alive and working i need to read firmware but this happens at the end oad IDBase v42913 Ok! Operation : Identify [ v2.05 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 ERROR : BOOT ACK not received! Error : Fail to init protocol! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Identify [ v2.05 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 ERROR : BOOT ACK not received! Error : Fail to init protocol! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Identify [ v2.05 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! ERROR : Protocol HandShake failed! Error : Fail to init protocol! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.05 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Device info : Patch Level : O21019 Display ID : SFC_Neon_Storm_V02_20190218 Ver. Incmt : 1550472943 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2019-02-05 Build Time : 1550472943 Product Model : Neon Storm Product Brand : Safaricom Product Name : Neon_Storm Product Device : Neon_Storm Product Manfct : revoview Product Info : Neon_Storm Product Board : sp7731e_1h20 Board Platform : sp7731e Platform Version: MOCORTM_17C_W18.23.4_P9_Debug Project Version: pike2_pub BASE Version: FM_BASE_17C_W18.23.4_P9 HW Version: sc7731e_modem CMP_Time : 10-13-2018 10:47:12 MODEM TAG : MOCORTM_17C_W18.23.4_P9_Debug_FM_BASE_17C_W18.23.4 _P9_sc7731e_modem_pike2_pub UserData : STATE : PLAIN [EXTFS] Done! Elapsed: 00:02:16 Operation : Read FW [ v2.05 ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Device info : Patch Level : O21019 Display ID : SFC_Neon_Storm_V02_20190218 Ver. Incmt : 1550472943 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2019-02-05 Build Time : 1550472943 Product Model : Neon Storm Product Brand : Safaricom Product Name : Neon_Storm Product Device : Neon_Storm Product Manfct : revoview Product Info : Neon_Storm Product Board : sp7731e_1h20 Board Platform : sp7731e AndroidVer : 8 VlnrLevel : 0x00 SP7731E__revoview__Neon_Storm__8.1.0__SFC_Neon_Sto rm_V02_20190218__O21019__Neon_Storm Read : prodnv.img ExtSparse : Compression ratio : 73% Read : phase.cfg Read : recovery.img Read : tos.bin Read : sml.bin Read : u-boot.bin Read : boot_logo.bmp Read : fastboot_logo.bmp Read : nvitem_w.bin Make : persist.img Read : tee_persist.bin ExtSparse : Compression ratio : 17% Read : gnssmodem.bin Read : gnssbdmodem.bin Read : modem_wcn.img Read : modem_w.bin Read : deltanv_w.bin Read : gdsp_w.bin Read : pm_sys.bin Read : boot.img Read : system.img ExtSparse : Compression ratio : 70% Make : cache.img Read : vendor.img ExtSparse : Compression ratio : 43% ERROR : Critical data has been damaged! Info : Data processing failed! Most probably device software already corrupted and cant be used further! Reconnect Power/Cable! |
The Following User Says Thank You to Techsky For This Useful Post: |
05-29-2020, 13:35 | #142 (permalink) |
Freak Poster Join Date: Mar 2009 Location: Bayelsa State, Nigeria
Member: 997641 Status: Offline Thanks Meter: 12 | itel p33, s15 privacy Itel P33, S15 read privacy does not work with spd/unisoc v2.05, i have to uninstall 2.05 and install 2.04 before i could read privacy. Pls infinity team work on the next update |
05-29-2020, 14:48 | #143 (permalink) | |
Member: 1043909 Status: Online Thanks Meter: 60,926 | Quote:
Please always post softare operation log text, this helps to find a problen reaon (if any) Thank you ! | |
05-29-2020, 19:23 | #144 (permalink) |
No Life Poster Join Date: Feb 2006 Location: In my LAB
Member: 231728 Status: Offline Thanks Meter: 2,103 | read firmware done but : very very slow read operation in PC config (I5 7eme generation ;RAM 8go ; SSD drive 256 Go) more than 40 min and no ExtSparse for system.img file 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Device info : Patch Level : PPR1.180610.011 Display ID : AS0119_V09_20190613 Ver. Incmt : 190589 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2019-05-05 Build Time : 1560368546 Product Model : BUZZ 2 Lite Product Brand : ACE Product Name : BUZZ_2_Lite Product Device : BUZZ_2_Lite Product Manfct : ACE France Product Info : BUZZ_2_Lite Product Board : sp7731e_1h10 Board Platform : sp7731e AndroidVer : 9 VlnrLevel : 0x00 SP7731E__ACE_France__BUZZ_2_Lite__9__AS0119_V09_20 190613__PPR1.180610.011__BUZZ_2_Lite Read : prodnv.img ExtSparse : Compression ratio : 13% Read : phase.cfg Read : recovery.img Read : tos.bin Read : sml.bin Read : u-boot.bin Read : boot_logo.bmp Read : fastboot_logo.bmp Read : nvitem_w.bin Make : persist.img Read : gnssmodem.bin Read : gnssbdmodem.bin Read : modem_wcn.img Read : modem_w.bin Read : deltanv_w.bin Read : gdsp_w.bin Read : pm_sys.bin Read : boot.img Read : dtb.img Read : dtbo.img Read : system.img Make : cache.img Read : vendor.img ExtSparse : Compression ratio : 48% Read : otp_product.img ExtSparse : Compression ratio : 1% Read : vbmeta.img Make : userdata.img Read : u-boot-spl.bin Firmware size : 0x8B3C4494 ( 2,18 GiB ) Android Info saved : _Android_info.txt Reconnect Power/Cable! Done! Elapsed: 00:40:29 |
The Following User Says Thank You to rebainoor For This Useful Post: |
05-29-2020, 19:46 | #145 (permalink) | |
Member: 231728 Status: Offline Thanks Meter: 2,103 | an other read firmware done but with very slow and take more than 44 min Quote:
05-31-2020, 09:13 | #146 (permalink) |
Major Poster Join Date: May 2020 Location: pakistan
Member: 2956389 Status: Offline Thanks Meter: 124 | QMOBILE J1000 Format DONE NO BOOTKEY SVC MODE DONE Operation : Identify [ v1.06 ] BootMode : SVC 1. Power off device 2. Not hold any key on device! 3. Insert cable and battery in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SOC GEN : SPRD ( Legacy ) ModemInfo : Project Version: SC6531EFM_BAR BASE Version: BASE_SVN HW Version: SC6531EFM_BAR CMP_Time : 09-27-2018 16:33:42 SecInfo : IMEI[1] : 356XXXXXXXXXXXXX IMEI[2] : 356XXXXXXXXXXXXX IMEI[3] : 000000000000000 WIFIMAC : FFFFFFFFFFFF BT_MAC : 082112193338 SEC_ID : B66FFFFF341B64CF Done! Elapsed: 00:00:41 Reconnect Power/Cable! Operation : Format FileSystem [ v1.06 ] 1. Power off device 2. Not hold any key on device! 3. Insert cable and battery in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! Format FFS Done! Done! Elapsed: 00:00:28 Reconnect Power/Cable! |
The Following 4 Users Say Thank You to MAHER GEE For This Useful Post: |
