Old 05-01-2020, 14:05   #46 (permalink)
Member: 148515
Thanks Meter: 19,534
Originally Posted by sudarshanagrwal View Post
=== DongleManager [Infinity] v1.76 [01-05-2020 14:51:55] ===
Searching...
Card-Reader: Generic EMV Smartcard Reader 0
HWID: 0000186D21344082
Box/Dongle found: Infinity-Box/Dongle
Reading...
Serial No (S/N): 0162186D
Firmware version: 0143.02
=== Process started: 01-05-2020 14:51:57 ===
Connecting to server
Server connection successfully established
Checking DongleManager version...
Your DongleManager is up-to-date
Checking Dongle Identification...
Authenticating on server...
Authentication stage error:
Server answer:[0007] No updates found for your Smart-Card. DO NOT try more today !
Do you see any error message after you run exe ?
Old 05-01-2020, 14:08   #47 (permalink)
Member: 148515
Originally Posted by delwer View Post
password 12345678 dose not work
you must uninstall WinRAR and install 7-zip !
What is the result ?
Old 05-01-2020, 14:09   #48 (permalink)
Member: 148515
Originally Posted by khalillll View Post
hi ....
When i trying to run the application (cm2spd2 2.05), the team's infinity logo opens and then disappears.
where is the problem. infinity team ?
the same problem in cm2scr version (1.06)
The other versions work well.
Do you have fault.bin file in folder with software ?
Old 05-01-2020, 14:25   #49 (permalink)
***MALIK***'s Avatar
Member: 556396
Sonork: 100.1609417
Thanks Meter: 363
Qmobile qsmart 4g plus not booted
how to boot
Old 05-01-2020, 15:17   #50 (permalink)
Member: 130995
Thanks Meter: 35,227
how to boot
pls always copy/paste software operation log text
Old 05-01-2020, 15:18   #51 (permalink)
Member: 130995
Originally Posted by amirhosting View Post
Dongle Firmware version : v0137
Dongle Firrmare version is outdates!
i update via dongle manager but same error:!
=== DongleManager [Infinity] v1.76 [30/04/2020 23:16:50] ===
Searching...
Card-Reader: FT SCR2000 0
HWID: 000058057CEA4082
Reading...
Serial No (S/N): DAFB5805
Firmware version: 0137.02
=== Process started: 30/04/2020 23:16:54 ===
Authentication successfull
Service stage 1 confirmed
Securing session...
Session secured ok
Upgrading dongle...
Wait 4-5 minutes ! DO NOT disconnect Box/Dongle !
Applet upgrade ok
Identification Ok. Finalizing...
Finalizing ok
Process completed
=== Process finished: 30/04/2020 23:17:30 ===
=== DongleManager [Infinity] v1.76 [30/04/2020 23:17:30] ===
Box/Dongle type selected: Infinity-Box/Dongle
=> Activations:
- 00: Infinity-Box/Dongle v0137
Guide Plz!
Hello,
It looks like your dongle support period is expired.
How to check - https://www.infinity-box.com/doc/?r=17
If support is expired please contact to your seller and renew support - https://www.infinity-box.com/buy/
Old 05-01-2020, 15:19   #52 (permalink)
Member: 130995
Originally Posted by ansar.r View Post
My device 1.76 dongel manger uptodate
But letest setup not open any one explain me
Do you see any error message after you run software ?
Old 05-01-2020, 20:44   #53 (permalink)
Member: 2948043
Thanks Meter: 3
Yes, I found it
fault : 35 octets ( E R R O R : P R I V I L E G E )...
i delete it and turn off kaspersky , then reinstall cm2spd2 2.05 again...
the same problem..
Old 05-01-2020, 22:08   #54 (permalink)
Member: 2948043
Thanks Meter: 3
i did this :
other pc , without old installation and without antivirus
the same results.. logo infinity then no things
Old 05-01-2020, 22:11   #55 (permalink)
Member: 2815426
You have to try your best to include boot 8810/6820 also even though it's old
Old 05-02-2020, 01:12   #56 (permalink)
Member: 2948043
Thanks Meter: 3
sorry. but this is not update; this is real problem.
good luck.
Old 05-02-2020, 08:38   #57 (permalink)
Member: 556396
Sonork: 100.1609417
Thanks Meter: 363
Card found : A9F77866 , v0143
Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.05
Load IDBase v42913 Ok!
Operation : Identify [ v2.05 ]
BootMode : FLASH
1. Power off device, wait 10-15 seconds
2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- )
3. Insert cable in device!
Wait for device ...
Device Connected!
ERROR : Protocol HandShake failed!
Error : Fail to init protocol!
Remove battery, cable. Check cable and connection. Repeat operation!
Reconnect Power/Cable!
Old 05-02-2020, 09:20   #58 (permalink)
Member: 556396
Sonork: 100.1609417
Thanks Meter: 363
BootMode : FLASH
Wait for device ...
Device Connected!
BootMode : FLASH
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_512MB_RS
Sending Init Boot ...
Boot sent!
Kick FDL ...
ERROR : FDL NOT started!
Error : Fail to boot FDL!
Unsupported device with selected fdl or settings! Change settings!
BootMode : FLASH
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_512MB_RS_LOW
Boot sent!
Kick FDL ...
BootMode : FLASH
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_512MB_SS
Boot sent!
Kick FDL ...
BootMode : FLASH
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : 0_SC7731x_BASE : SC7731C_eMMC_512MB_NS
Boot sent!
Kick FDL ...
BootMode : FLASH
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : 0_SC7715_BASE : SC7715_eMMC_512MB_NS
Boot sent!
Kick FDL ...
Kick FDL again ...
Device not found!
Operation : Read FW [ v2.05 ]
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot sent!
Kick FDL ...
Kick FDL again ...
Device not found!
BootMode : FLASH
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : 0_SC7715x_BASE : SC7715G_NAND_256MB_NS
Boot sent!
Kick FDL ...
Operation : Format FS / Reset Settings [ v2.05 ]
Mode : Default [ Reset Settings + FRP ]
BootMode : FLASH
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot sent!
Kick FDL ...
Kick FDL again ...
Device not found!
Old 05-02-2020, 10:34   #59 (permalink)
Member: 2951507
Thanks Meter: 11
its Stunning Update Thnx and Respect Infinity Developers
Old 05-02-2020, 11:38   #60 (permalink)
Member: 2951507
Thanks Meter: 11
HELLO INFINITY TEAM GREETING! I WOULD LIKE TO SHARE A PAINFUL BUG OF INFINITY UPDATE NOW A DAYS PLEASE CHECK BELOW MY ALL ERROR DETAIL !
BEFORE IT WAS HAPPEN ON LATEST UPDATE CM2 SCR 1.06 MODULE UNTIL NOW THERE IS NO SOLUTION ! AND NOW THIS ERROR IM GETTING ON SAME cm2spd2 2.05 UPDATE.
THERE IS NO SIGN OF ANY VIRUS
ALREADY INSTALLED FRESH WINDOW 10 ENTERPRISE 64 BIT
1ST OF ALL CHECK DONGLE FIRMWARE DETAIL:
Serial No (S/N): XXXXXXX
=> Activations:
- 00: Infinity-Box/Dongle v0143
NOW WHEN I INSTALLED CM2 SP2 (2.05) VERSION AND I GET THESE ERROR
ERROR NO# 1
https://imgur.com/Fs6dmZs
after press Ok The Open Module like this
error # 2
https://imgur.com/GvKzRJE
every thing empty in this module!
before i was getting same issue on cm2 scr 1.06 module but for mine 1.05 module working Ok and Also Previous version of cm2sp2 2.04 working Fine Only The new updates Are very Very such a Painful becoz if i got these error so its mean i cannot use new modules !
Addational Deatil:
System Info :
https://imgur.com/rbn59CA
Page generated in 0.25463 seconds with 10 queries
