08-02-2015, 10:14 | #16 (permalink) | ||||
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
If withut sarcasm - I not make anything, what kan kill phones. 0.5-1% it is max, statical barrier , if chance is more - no. I seen , how other teams just stupidly remove posts with problems and all seems as extra-great. We not erase any post, so, you can find all "killed" phones by our tools ( can't remember count exactly , something near 14-15 pcs for 1.5 year - it is even less, than 0,01% statical count ) | ||||
08-02-2015, 11:56 | #18 (permalink) | |
No Life Poster Join Date: Oct 2005 Location: QQ id 2593032292
Member: 189673 Status: Offline Sonork: 100.1592062 Thanks Meter: 351 | Quote:
08-02-2015, 12:52 | #19 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | @sameera , for you as well : http://forum.gsmhosting.com/vbb/11199447-post28.html |
08-03-2015, 08:50 | #20 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Factory Reset Protection (FRP) Age: 13
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,543 | Really? all cpu is needed - if we will give you 6820-8810 - you will be cry for 8825 - 6825, if we will give u 8825 and 6825 - again you will be cry for 7735 - if we will be given you 7735 - again you will be cry for 9830 we are working hard and trying to finish all new cpu first - after that we will think about 6820/8810 - keep patience BTW - who have phone in hand 6820/8810/8825 send to Dzirt For Support |
The Following User Says Thank You to pradeep_kus For This Useful Post: |
08-03-2015, 09:51 | #21 (permalink) |
No Life Poster Join Date: Apr 2008 Location: nigeria
Member: 757064 Status: Offline Sonork: 11111111 Thanks Meter: 365 | what is solution to this Operation : Check / Read Info [ v1.24 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 52 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending NAND_ID : 009800BC009000660076001500010000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x88 DRAM not initialized , configure DRAM Settings DRAM EmiReq Ok , 0x00A8 DRAM Init Ok , 0x10000000 DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0087 , UNKNOWN [NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0015 0001 [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! NAND : Detecting structure now... Please, wait. NAND : Structure detect failed [1F]! Send report to support! Info read not done Erased phone or unsupported FlashIc? You can change settings : Settings -> Other -> NAND init Mode Done! Elapsed: 00:02:52 Reconnect Power/Cable! |
08-03-2015, 14:26 | #24 (permalink) | |
08-03-2015, 18:25 | #25 (permalink) |
Super Moderator Join Date: Jul 2009 Location: .:India:.
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Karbonn A80 Hang At "Logo" Successfully "Repaired" By Format With CM2. Operation : Check/Read Info [ v1.03 ] Code: Loading : UTLA80v1020_18-09-2014.pac CRVersion : BP_R1.0.0 PacCPUinfo : SC7715 PacVersion : UTLA80v1020_18-09-2014 FastCheck : 0x1B42315E Loading files ... File : fdl1.bin File : fdl2.bin File : wnvitem.bin File : wcnnvitem.bin File : prodnv.img File : u-boot-spl-16k.bin File : wmodem.bin File : wdsp.bin File : wcnmodem.bin File : KarbonnA80_LOGO_256_480_800.bmp File : KarbonnA80_LOGO_256_480_800.bmp(1) File : boot.img File : system.img File : cache.img File : recovery.img File : userdata.img File : u-boot.bin File : SC7715.xml Load Ok! Operation : Check/Read Info [ v1.03 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 241 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : scx15_sp7715eaplusMM5008_2p2 Model Brand : A80 Model Device: scx15_sp7715ea_2p2 AndrVersion : 4.4.2 BaseBand CPU: SCX15_SP7715EA CompileDate : 1407405432 Project Ver : UTLA80v1017_07-08-2014 Model Ext : A80 Elapsed: 00:00:18 Reconnect Power/Cable! Operation : Format File System [ v1.03 ] Settings : SmartFormat is On Code: 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 241 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x000000004AAFB000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Done! Elapsed: 00:00:25 Reconnect Power/Cable! |
The Following User Says Thank You to MyGSM World For This Useful Post: |
08-03-2015, 19:39 | #26 (permalink) | |
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,543 | Quote:
08-03-2015, 20:01 | #27 (permalink) | |
Please see details here - http://forum.gsmhosting.com/vbb/f641...ongle-1973526/ | |
08-03-2015, 20:07 | #28 (permalink) | |
99% of people do not read thread name and start to wrte offtopic posts. Here is thread about 8830 but people start to write useless posts. Thank you very much once again ! At least one user understand how to select correct thread ! | |
08-03-2015, 20:25 | #29 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Dear Friends, Posts regarding new features and cpu requests moved here - http://forum.gsmhosting.com/vbb/f296...quest-1975636/ |
08-05-2015, 13:00 | #30 (permalink) |
No Life Poster Join Date: Jun 2011 Location: pakistan
Member: 1602407 Status: Offline Sonork: 100.1648061 Thanks Meter: 360 | v. good update please also add support for sc6820/ 8810 read/write bin, pac reset user code, privacy & pattern format fs complete read/write nv write imei/imei1/imei2/imei3 i will wait for this supper update. thanks. |
