06-14-2018, 09:28 | #62 (permalink) | |
No Life Poster Join Date: Mar 2016 Location: Ukraine
Member: 2550141 Status: Offline Thanks Meter: 1,115 | Quote:
06-14-2018, 09:34 | #64 (permalink) | |
06-14-2018, 11:01 | #67 (permalink) |
No Life Poster Join Date: Jun 2014 Location: Infinity Box Team
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | --------------------------- Infinity SCR --------------------------- Dongle Firmware version : v0136 Dongle Firmware version is outdated! Download "DongleManager" from support and update firmware! --------------------------- OK --------------------------- |
06-14-2018, 11:58 | #68 (permalink) |
Freak Poster Join Date: Jun 2008 Location: peshawar
Member: 784983 Status: Offline Sonork: 100.1676767 QQ 1125933349 Thanks Meter: 39 | === DongleManager [Infinity] v1.72 [6/14/2018 15:33:06] === Searching... Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 000125B37D314082 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): Firmware version: 0136.02 === Process started: 6/14/2018 15:33:08 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0007] No updates found for your Smart-Card. DO NOT try more today ! pless help me dear team |
06-14-2018, 12:31 | #69 (permalink) |
Product Supporter Join Date: Mar 2005 Location: in CPU
Member: 128745 Status: Offline Thanks Meter: 16,936 | Important Information how to get this update working for you To use this new update you need to update dongle to latest Firmware version: 0137.02 dongle update will only work for people with renewed support . so if you try to update dongle and you see Server answer:[0007] No updates found for your Smart-Card. DO NOT try more this means you do not have renewed support . You will need to buy CM2 yearly renewed support from your reseller How to check if your dongle has active paid update HERE |
The Following User Says Thank You to Infinity-Box For This Useful Post: |
06-14-2018, 16:36 | #71 (permalink) |
No Life Poster Join Date: Sep 2008 Location: Bohicon (Rep of Benin)
Member: 862014 Status: Offline Sonork: 100.1608307 Thanks Meter: 64 | good updat but hi verry good update. i have one friend who have one infinity box and when he put the smart card inside , the box disconnect or display ''unknow peripheri'' . but without scard it connect, how do in this case? |
06-15-2018, 08:51 | #72 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Please download and run Sysinternals Process Explorer - https://docs.microsoft.com/en-us/sys...ocess-explorer Do you see in running process list any kind of sharing/trace or similar process ? |
06-15-2018, 08:52 | #73 (permalink) | |
Try to connect Dongle to another PC Try to insert Smart-Card into another Card-Reader or Box (if you have it) If problem still exist: - Remove Smart-Card from Card-Reader - Clean Smart-Card contacts - Try to use hot air gun and heat Smart-Card - Insert Smart-Card back to Card-reader If problem still exist this means it's a hardware problem and you need new Smart-Card. | |
06-15-2018, 11:30 | #74 (permalink) | |
No Life Poster Join Date: Aug 2003 Location: Mars Age: 40
Member: 38084 Status: Offline Thanks Meter: 115 | Quote:
System Idle Process 97.71 52 K 8 K 0 System 0.23 156 K 24 K 4 Interrupts 0.27 0 K 0 K n/a Hardware Interrupts and DPCs smss.exe 484 K 492 K 452 Memory Compression 196 K 21 K 1812 csrss.exe 1 K 2 K 688 wininit.exe 1 K 1 K 792 services.exe 4 K 7 K 868 svchost.exe 940 K 784 K 564 Processo host per servizi di Windows Microsoft Corporation svchost.exe 9 K 14 K 668 Processo host per servizi di Windows Microsoft Corporation ShellExperienceHost.exe Suspended 30 K 21 K 6756 Windows Shell Experience Host Microsoft Corporation SearchUI.exe Suspended 58 K 43 K 1044 Search and Cortana application Microsoft Corporation WmiPrvSE.exe 2 K 4 K 5972 dllhost.exe 1 K 2 K 10176 COM Surrogate Microsoft Corporation ApplicationFrameHost.exe 13 K 27 K 7376 Application Frame Host Microsoft Corporation Microsoft.Photos.exe Suspended 187 K 261 K 7256 SystemSettings.exe Suspended 20 K 47 K 8736 Impostazioni Microsoft Corporation WmiPrvSE.exe 3 K 9 K 8964 RuntimeBroker.exe 4 K 19 K 6520 Runtime Broker Microsoft Corporation RuntimeBroker.exe 5 K 20 K 1292 Runtime Broker Microsoft Corporation dllhost.exe 3 K 11 K 6420 COM Surrogate Microsoft Corporation WmiPrvSE.exe 2 K 8 K 6296 explorer.exe 16 K 57 K 9952 Esplora risorse Microsoft Corporation backgroundTaskHost.exe Suspended 15 K 38 K 9556 Background Task Host Microsoft Corporation dllhost.exe 1 K 6 K 968 COM Surrogate Microsoft Corporation WUDFHost.exe 2 K 3 K 812 svchost.exe 0.01 5 K 7 K 1084 Processo host per servizi di Windows Microsoft Corporation svchost.exe < 0.01 2 K 3 K 1128 Processo host per servizi di Windows Microsoft Corporation svchost.exe 2 K 4 K 1276 Processo host per servizi di Windows Microsoft Corporation svchost.exe 1 K 2 K 1352 Processo host per servizi di Windows Microsoft Corporation svchost.exe 1 K 1 K 1364 Processo host per servizi di Windows Microsoft Corporation svchost.exe 1 K 4 K 1408 Processo host per servizi di Windows Microsoft Corporation svchost.exe 6 K 8 K 1420 Processo host per servizi di Windows Microsoft Corporation taskhostw.exe 3 K 10 K 5272 Processo host per attivitą di Windows Microsoft Corporation SamsungMagician.exe 20 K 8 K 3828 svchost.exe 2 K 5 K 1444 Processo host per servizi di Windows Microsoft Corporation svchost.exe 15 K 13 K 1604 Processo host per servizi di Windows Microsoft Corporation svchost.exe 1 K 5 K 1612 Processo host per servizi di Windows Microsoft Corporation svchost.exe 1 K 1 K 1684 Processo host per servizi di Windows Microsoft Corporation svchost.exe 2 K 5 K 1692 Processo host per servizi di Windows Microsoft Corporation svchost.exe 2 K 4 K 1704 Processo host per servizi di Windows Microsoft Corporation sihost.exe 5 K 16 K 4980 Shell Infrastructure Host Microsoft Corporation igfxCUIService.exe 1 K 2 K 1732 igfxCUIService Module Intel Corporation svchost.exe 1 K 1 K 1776 Processo host per servizi di Windows Microsoft Corporation svchost.exe 1 K 3 K 1784 Processo host per servizi di Windows Microsoft Corporation WUDFHost.exe 2 K 2 K 1892 svchost.exe 2 K 3 K 1900 Processo host per servizi di Windows Microsoft Corporation svchost.exe 2 K 5 K 1984 Processo host per servizi di Windows Microsoft Corporation svchost.exe 4 K 4 K 2024 Processo host per servizi di Windows Microsoft Corporation svchost.exe < 0.01 9 K 13 K 2060 Processo host per servizi di Windows Microsoft Corporation svchost.exe 2 K 3 K 2104 Processo host per servizi di Windows Microsoft Corporation svchost.exe 3 K 7 K 2168 Processo host per servizi di Windows Microsoft Corporation audiodg.exe 11 K 14 K 2692 svchost.exe 4 K 8 K 2252 Processo host per servizi di Windows Microsoft Corporation svchost.exe 3 K 7 K 2272 Processo host per servizi di Windows Microsoft Corporation svchost.exe 2 K 4 K 2288 Processo host per servizi di Windows Microsoft Corporation svchost.exe 2 K 2 K 2300 Processo host per servizi di Windows Microsoft Corporation svchost.exe < 0.01 4 K 9 K 2328 Processo host per servizi di Windows Microsoft Corporation svchost.exe < 0.01 10 K 13 K 2384 Processo host per servizi di Windows Microsoft Corporation svchost.exe 1 K 2 K 2416 Processo host per servizi di Windows Microsoft Corporation svchost.exe 12 K 13 K 2428 Processo host per servizi di Windows Microsoft Corporation svchost.exe 3 K 8 K 2516 Processo host per servizi di Windows Microsoft Corporation svchost.exe 3 K 5 K 2776 Processo host per servizi di Windows Microsoft Corporation svchost.exe 2 K 3 K 2972 Processo host per servizi di Windows Microsoft Corporation svchost.exe 4 K 8 K 1960 Processo host per servizi di Windows Microsoft Corporation svchost.exe 2 K 3 K 3004 Processo host per servizi di Windows Microsoft Corporation spoolsv.exe < 0.01 10 K 18 K 3164 Applicazione sottosistema spooler Microsoft Corporation svchost.exe < 0.01 4 K 8 K 3244 Processo host per servizi di Windows Microsoft Corporation svchost.exe 1 K 3 K 3252 Processo host per servizi di Windows Microsoft Corporation atkexComSvc.exe 7 K 2 K 3392 svchost.exe 2 K 2 K 3436 Processo host per servizi di Windows Microsoft Corporation svchost.exe 3 K 4 K 3444 Processo host per servizi di Windows Microsoft Corporation svchost.exe 1 K 2 K 3452 Processo host per servizi di Windows Microsoft Corporation dasHost.exe 3 K 9 K 3432 OfficeClickToRun.exe 37 K 37 K 3472 Microsoft Office Click-to-Run (SxS) Microsoft Corporation svchost.exe 22 K 25 K 3484 Processo host per servizi di Windows Microsoft Corporation svchost.exe 8 K 15 K 3500 Processo host per servizi di Windows Microsoft Corporation svchost.exe 2 K 3 K 3556 Processo host per servizi di Windows Microsoft Corporation svchost.exe 1 K 1 K 3580 Processo host per servizi di Windows Microsoft Corporation svchost.exe 1 K 1 K 3612 Processo host per servizi di Windows Microsoft Corporation SecurityHealthService.exe 4 K 6 K 3628 Windows Security Health Service Microsoft Corporation ss_conn_service.exe < 0.01 1 K 1 K 3636 MSS CS Connectivity Service DEVGURU Co., LTD. svchost.exe 4 K 12 K 3668 Processo host per servizi di Windows Microsoft Corporation svchost.exe 0.03 5 K 5 K 3676 Processo host per servizi di Windows Microsoft Corporation svchost.exe 1 K 1 K 3688 Processo host per servizi di Windows Microsoft Corporation svchost.exe 1 K 1 K 4084 Processo host per servizi di Windows Microsoft Corporation svchost.exe 1 K 1 K 4212 Processo host per servizi di Windows Microsoft Corporation svchost.exe 3 K 3 K 4992 Processo host per servizi di Windows Microsoft Corporation svchost.exe 1 K 2 K 4868 Processo host per servizi di Windows Microsoft Corporation PresentationFontCache.exe 31 K 10 K 4840 PresentationFontCache.exe Microsoft Corporation svchost.exe 5 K 13 K 5080 Processo host per servizi di Windows Microsoft Corporation svchost.exe 3 K 7 K 5344 Processo host per servizi di Windows Microsoft Corporation svchost.exe 1 K 2 K 5456 Processo host per servizi di Windows Microsoft Corporation ctfmon.exe 2 K 7 K 5612 svchost.exe 1 K 2 K 5564 Processo host per servizi di Windows Microsoft Corporation svchost.exe 2 K 3 K 7036 Processo host per servizi di Windows Microsoft Corporation svchost.exe 4 K 7 K 7488 Processo host per servizi di Windows Microsoft Corporation SearchIndexer.exe 19 K 23 K 8144 Microsoft Windows Search Indexer Microsoft Corporation svchost.exe 1 K 6 K 8608 Processo host per servizi di Windows Microsoft Corporation svchost.exe 1 K 2 K 8344 Processo host per servizi di Windows Microsoft Corporation svchost.exe 3 K 4 K 8928 Processo host per servizi di Windows Microsoft Corporation svchost.exe 2 K 3 K 1536 Processo host per servizi di Windows Microsoft Corporation svchost.exe 2 K 3 K 2968 Processo host per servizi di Windows Microsoft Corporation svchost.exe 2 K 3 K 8248 Processo host per servizi di Windows Microsoft Corporation svchost.exe 1 K 6 K 8636 Processo host per servizi di Windows Microsoft Corporation svchost.exe 1 K 5 K 6336 Processo host per servizi di Windows Microsoft Corporation svchost.exe 1 K 8 K 9464 Processo host per servizi di Windows Microsoft Corporation svchost.exe 1 K 7 K 9476 Processo host per servizi di Windows Microsoft Corporation lsass.exe < 0.01 6 K 10 K 904 Local Security Authority Process Microsoft Corporation fontdrvhost.exe 1 K 1 K 600 csrss.exe 0.17 2 K 2 K 808 winlogon.exe 2 K 1 K 916 fontdrvhost.exe 4 K 9 K 604 dwm.exe 0.55 42 K 47 K 1188 igfxEM.exe 3 K 3 K 5576 igfxEM Module Intel Corporation igfxHK.exe 2 K 2 K 5584 igfxHK Module Intel Corporation explorer.exe 0.08 51 K 89 K 5852 Esplora risorse Microsoft Corporation XMouseButtonControl.exe 0.04 2 K 3 K 6572 procexp64.exe 0.86 34 K 59 K 7084 Sysinternals Process Explorer Sysinternals - www.sysinternals.com IEMonitor.exe 0.03 1 K 9 K 3496 Internet Download Manager agent for click monitoring in IE-based browsers Tonec Inc. | |
