10-04-2018, 22:04 | #137 (permalink) | |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Quote:
The Following User Says Thank You to Yusuf Lawal For This Useful Post: |
11-20-2018, 20:42 | #138 (permalink) |
Junior Member Join Date: Feb 2014 Location: Ghana
Member: 2135376 Status: Offline Thanks Meter: 1 | HELP NEED TO REVIVE DEAD PHONE READ DUMP FILE AND FLASH TO REMOVE USER LOCK NOW PHONE DEAD Operation : Write Flash [ v1.03 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Spreadtrum Boot Block version 1.2 Port speed : 921600 FDL Flash : Control transfered! Boot Done! BIN : Format UserData BIN : Format UserData Ok! Error : Flashing failed! Remove battery, cable. Check cable and connection. Repeat operation! PLEASE HOW CAN I REVIVE THIS PHONE CS0_MEM : SPI : [FIDELIX] : FM25Q128 : 0x01000000 [ 16MiB ] |
11-25-2018, 10:56 | #139 (permalink) |
Freak Poster Join Date: Jul 2008
Member: 822589 Status: Offline Sonork: Mbo Thanks Meter: 18 | support for mtn 11 shyne c291 [QUOTE=YellowBoss;13175445]Infinity Chinese Miracle II SCR/SPD-RDA v1.03: New models and features Supported CPU list: Spreadtrum: SC6530, SC6531, SC6531(A/C), SC6531E, SC6533, SC6533G RDA Mirco: RDA8851 rev A,B,C,L,CL RDA Micro: RDA8826 RDA Mirco RDA8851 rev A,B,C,L,CL/RDA8826 Flashing protocol updated Updated LOD tools ( flashing / customizing ) Spreadtrum SC6533/G: Protocol updated Support for REV2 bootrom mode activated FW reading revised Updated LOD tools ( flashing / customizing ) Spreadtrum SC6530/6531/A/C/E: Revised Repair security feature Flashing revised -> Activated "Format FFS" during BINARY dump writing -> Use that feature, if device not allow make direct format ( some C/E revision devices ) User code read revised - activated 2nd mode : from DUMP -> Press and hold LEFT SHIFT key, while starting ReadUsercode code operation. Select desired dump file to read code. Activated AUTO fixer for memory dumps Internal loaders updated Spreadtrum other: Protocol updated PAC handling revised Improved Flashing procedure for SC7701/SC7702 devices Improved Flashing procedure for SC6825/SC8825 devices Known issues[*]/warnings[!]/info[I]: 1. [I] AUTO fixer for memory dumps -> That feature will AUTOMATICALLY FIX dumps from devices with "abnormal" flash and memory layout ( issue found on number of devices 16MB flash with 8MB layout ) -> Just select binary dump in flashing tab or any other operation, which require file select. 2. [*] In some cases Format FFS may fail on E and C rev -> Read Flash Dump, write it back. During Dump writing SW will ask you about FormatFFS. can we unlock network mtn II shyne c291 is it supported if it is supported how do i go about it to unlock it |
12-15-2018, 13:16 | #142 (permalink) |
Freak Poster Join Date: Dec 2008
Member: 931121 Status: Offline Thanks Meter: 100 | lecom l800 read user code done by infinity box Operation : Identify [ v1.03 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Spreadtrum Boot Block version 1.2 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ] IMEI[1] : 359961070382494 IMEI[2] : 359961070382502 Done! Elapsed: 00:00:20 Reconnect Power/Cable! Operation : Read UserCode [ v1.03 ] MODE : From Device 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Spreadtrum Boot Block version 1.2 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ] Reading data ... Sorting data ... STATE : ACTIVE : CODE : 5432 Done! Elapsed: 00:00:26 Reconnect Power/Cable! |
The Following User Says Thank You to moniuzzaman For This Useful Post: |
12-18-2018, 10:51 | #143 (permalink) | |
Please contact to your seller for details - https://www.infinity-box.com/buy/ | |
12-23-2018, 15:11 | #144 (permalink) |
Insane Poster Join Date: Nov 2006 Location: Bangladesh
Member: 387577 Status: Offline Thanks Meter: 7 | WALTON L7 6531E Read CODE 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR SC6531E Loader v 1.2 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ] Reading data ... Sorting data ... STATE : ACTIVE : CODE : 7799 Done! Elapsed: 00:00:39 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to mizan298 For This Useful Post: |
12-27-2018, 12:56 | #149 (permalink) |
Member: 931121 Status: Offline Thanks Meter: 100 | spd 6530 format done by infinity box Card found : 64C1CE3F , v0137 Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.03 SCRD mode : AUTO SPRD mode : SC6530 : REV : 0000 : NOR Operation : Read Flash [ v1.03 ] ----- > Powered On : 1. Power On device 2. Connect USB cable 3. When device show StorageMode : Press '0' button for a 5 second! ----- > Powered Off : 1. Insert USB cable 2. Wait when device show Charge icon 3. When device show StorageMode : Press '0' button for a 5 second! Wait for device ... Device Connected! BOOT_PWR0 : 0x00200000 BOOT_INIT : 0x7A56C157 BOOT_MODE : BOOTROM Boot_CPU : 0x08090007 : [SPREADTRUM] : SC6533G MEMD for flsh_spi32m Branch: none Boot_CS0 : 0x00000000 : SPI : [SPIDEF] : 25Q32 : 0x00400000 [ 4MiB ] Performing MemoryInit Selecting RL Sending RL Config : MemoryInit Config : Loader BOOT_MODE : RLOADER Boot IV : 0xFBA2A250 Boot done! Read done, 0x00400000 Verify FlashContent MCU verified CAL verified FAC verified Device Info Details : [0] : S03_ZTR_310_ROKEA [1] : 8809 [2] : 8809e2 [3] : CT8851C [4] : pasw_rda6625 [5] : flsh_spi32m [6] : gc9102/gc9106/nv3021/st7735rsmall/rm68116/st7789v [7] : bf3a01serial/gc6123/sp0820 [8] : rdabt_8809 [9] : rdafm_8809e [10] : release [11] : S03_ZTR_310_ROKEA_128x160_21KEY_ZTR7735HSD_SL9102L T_SL9106CTC_V01_20170727 [12] : 20170727 [13] : 2017-07-27_12:43:52 [14] : test_version Saved to : C:\Users\maalas\Desktop\ Saved as : SC6533G_4MiB_S03_ZTR_310_ROKEA_2017-07-27_124352.ilod Done! Elapsed: 00:03:15 Reconnect Power/Cable! Operation : Reset Settings [ v1.03 ] ----- > Powered On : 1. Power On device 2. Connect USB cable 3. When device show StorageMode : Press '0' button for a 5 second! ----- > Powered Off : 1. Insert USB cable 2. Wait when device show Charge icon 3. When device show StorageMode : Press '0' button for a 5 second! Wait for device ... Device Connected! BOOT_PWR0 : 0x00200000 BOOT_INIT : 0x5A56C151 BOOT_MODE : BOOTROM Boot_CPU : 0x08090007 : [SPREADTRUM] : SC6533G MEMD for flsh_spi32m Branch: none Boot_CS0 : 0x00000000 : SPI : [SPIDEF] : 25Q32 : 0x00400000 [ 4MiB ] Performing MemoryInit Selecting RL Sending RL Config : MemoryInit Config : Loader BOOT_MODE : RLOADER Boot IV : 0xFBA2A250 Boot done! Preparing PMT Verifying PMT Erasing 1474560 bytes FileSystem format done! Done! Elapsed: 00:00:45 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to moniuzzaman For This Useful Post: |
