04-14-2019, 10:09 | #91 (permalink) |
Freak Poster Join Date: Nov 2013 Location: Deira, Dubai
Member: 2062071 Status: Offline Sonork: 100.1663486 Thanks Meter: 60 | starmobile fs evo1 Need Unlock Solution Code: Operation : Check/Read Info [ v1.27 ] Normal Normal , 1 : Power On phone. Insert USB cable ( Normal USB cable ) Service Service , 1 : Insert USB cable ( Use adapter or special cable ) Service , 2 : Insert battery Service , 3 : If boot not start - press 'Power' button shortly ==== Wait for phone... Phone found! [ 396 ] Port Opened Sync... Normal Mode init Sync... Phone Initial Info : Platform : MOCORTM_15C_W17.26.2_P1_Debug Project : sc9820w_cp1 HWInfo : sc9820w_modem Phone Security Info : IMEI [1] : 033393XXXXXXXXX IMEI [2] : 033393XXXXXXXXX BT_ADDR : 000000000000 Done Reconnect Power/Cable! |
06-25-2019, 06:55 | #98 (permalink) |
Freak Poster Join Date: Feb 2007 Location: Pakistan
Member: 444381 Status: Offline Sonork: 100.1604585 Thanks Meter: 31 | cm2 scr not opening cm2 scr not opening when i open cm2scr open blinking the light cm2 but softwere not open and there is no any showing error i have seen the old and new version re-installed but same problem antivirus disabling but same problem |
07-02-2019, 10:17 | #100 (permalink) |
Freak Poster Join Date: Sep 2014 Location: islamabad pakistan Age: 39
Member: 2266425 Status: Offline Thanks Meter: 58 | Operation : Read User Code Waiting phone ... Connect battery, press and hold '0' button Connect USB cable and keep hold button, until phone will be detected Init : 049FFC0C Settings registers ... 1st boot Ok ==== CPU CPU_ID : 0809 , rev : 0007 CPU_CN : ==== FLASH FL_VEN : 0000 , rev : 0000 FL_CNM : FL_CAP : 00000000 Initial : 81C0024C ==== Booting Sending RamRun Loader ... Set : 0809 , 00000000 Boot File Not Found! CPU not Supported , or BootFiles are missng. Contact to Support! Reconnect Power/Cable! |
08-12-2019, 14:51 | #101 (permalink) |
No Life Poster Join Date: Feb 2019 Location: Madagascar
Member: 2897012 Status: Offline Thanks Meter: 400 | Itel 5600 unlock done Operation : Identify [ v1.04 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR 6531EFM v1.1 (c)2019 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [GIGADEVICE] : GD25Q32 : 0x00400000 [ 4MiB ] IMEI[1] : 357XXXXXXXXXXX IMEI[2] : 357XXXXXXXXXXX Done! Elapsed: 00:00:26 Operation : Format FileSystem [ v1.04 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR 6531EFM v1.1 (c)2019 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [GIGADEVICE] : GD25Q32 : 0x00400000 [ 4MiB ] Make backup of sensetive data Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_0D7 5BBC97195_NVM.nv Executing FormatFFS ... Format FFS Done! Done! Elapsed: 00:00:29 |
The Following User Says Thank You to Manikanika81 For This Useful Post: |
09-18-2019, 05:31 | #103 (permalink) |
No Life Poster Join Date: Aug 2014
Member: 2233266 Status: Offline Thanks Meter: 252 | winster discoey y-d5 flash done Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR 6531EFM v1.1 (c)2019 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [GIGADEVICE] : GD25Q32 : 0x00400000 [ 4MiB ] Make backup of sensetive data Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_1D7 BE47B5EEC_NVM.nv Executing FormatFFS ... Format FFS Done! Done! Elapsed: 00:00:20 Reconnect Power/Cable! |
The Following User Says Thank You to Yahia_Sb For This Useful Post: |
