04-29-2018, 03:48 | #32 (permalink) | |
Freak Poster Join Date: Aug 2017 Location: Mindanao Philippines
Member: 2752651 Status: Offline Thanks Meter: 182 | Quote:
Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 90014A483847316505075274B5999347 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e1G8 [eMMC] : FLASH_CID : 90014A483847316505075274B5999347 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xE5C818C395A9351C3E673C2288E7B1FF INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... Brand : HUAWEI ProdName : CUN-U29 ProdModel : HUAWEI CUN-U29 Device : HWCUN-U6582 AndroidVer: 5.1 MTKxCPU : MT6582 MTKxPRJ : CUN-U29C567B134 [Read Ok] : preloader_hq6582_we_b1b_l1.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : EBR2 [Read Ok] : system.img [Read Ok] : cust.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6582 / V1.1.1 / hq6582_we_b1b_l1 / EMMC Android Info saved MAUI Meta DB saved HWConfig Info saved FW Size : 2844 MiB Scatter saved to : C:\Users\Meerl\Documents\MT6582__HUAWEI__HUAWEI_CU N-U29__HWCUN-U6582__5.1__CUN-U29C567B134\ All done! Done! Elapsed: 00:11:07 | |
The Following 3 Users Say Thank You to meerl329 For This Useful Post: |
04-29-2018, 03:52 | #33 (permalink) | |
No Life Poster Join Date: Apr 2016 Location: B A N G L A D E S H
Member: 2556542 Status: Offline Thanks Meter: 1,790 | Quote:
try to understand what i can say,otherwise put some water in your ---------- hole. Last edited by kothamamun; 04-29-2018 at 04:01. | |
04-29-2018, 03:57 | #34 (permalink) |
Member: 2556542 Status: Offline Thanks Meter: 1,790 | @meerl329 people know cun-u29 support mtk 1.58 by using custom da but why we need add cun-u29 da file in mtk 2.0 r1. what the benefit,i am asking that. |
04-29-2018, 09:51 | #37 (permalink) | |
No Life Poster Join Date: Apr 2014 Location: B A N G L A D E S H
Member: 2171294 Status: Offline Sonork: 100.1659207(No More Use) Thanks Meter: 706 | idiot Quote:
again read from first post then again bla bla here. did u know what is 1.58 & v2.0? first study about both module then again cry here.... | |
04-30-2018, 01:47 | #41 (permalink) | |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Quote:
04-30-2018, 09:11 | #44 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Pakistan
Member: 570093 Status: Offline Thanks Meter: 1,067 | @Kothamamun CM2MTK and CM2MT2 both are diffrent modules which used for MTK cpu.when you repair old phones use CM2MTK and when you repair new MTK CPU then use CM2MT2.This is just like CM2SPD and CM2SCR if you know. |
