05-24-2018, 14:44 | #1 (permalink) |
No Life Poster Join Date: Aug 2010 Location: SearchinG ... Age: 39
Member: 1369772 Status: Offline Thanks Meter: 297 | Infinity CM2MT2 V2.00, V2.00 r2, V2.00 r3 Full of BUG !! Card found : xxxxx , v0136 Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.00 r3 Operation : Identify [ v2.00 r3 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : PreLoader USB VCOM (Android) (COM5) MODE : PRELOADER PORT PORT : 5 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6572 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 TYPE : LEGACY MTK Info : Device is not supported yet! Reconnect Power/Cable! Operation : Identify [ v2.00 r3 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : PreLoader USB VCOM (Android) (COM5) MODE : PRELOADER PORT PORT : 5 Waiting BOOT ack ... PRELOADER : ACK confirm FAIL! BROM : Init BROM BROM init passed! CHIP : MT6572 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 TYPE : LEGACY MTK Info : Device is not supported yet! Reconnect Power/Cable! Operation : Identify [ v2.00 r3 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : PreLoader USB VCOM (Android) (COM5) MODE : PRELOADER PORT PORT : 5 Waiting BOOT ack ... PRELOADER : ACK confirm FAIL! BROM : Init BROM BROM init passed! CHIP : MT6572 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 TYPE : LEGACY MTK Info : Device is not supported yet! Reconnect Power/Cable! Operation : Identify [ v2.00 r3 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : PreLoader USB VCOM (Android) (COM5) MODE : PRELOADER PORT PORT : 5 Waiting BOOT ack ... PRELOADER : ACK confirm FAIL! BROM : Init BROM BROM init passed! CHIP : MT6572 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 TYPE : LEGACY MTK Info : Device is not supported yet! Reconnect Power/Cable! Operation : Identify [ v2.00 r3 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : PreLoader USB VCOM (Android) (COM5) MODE : PRELOADER PORT PORT : 5 Waiting BOOT ack ... PRELOADER : ACK confirm FAIL! BROM : Init BROM BROM init passed! CHIP : MT6572 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 TYPE : LEGACY MTK Info : Device is not supported yet! Reconnect Power/Cable! Read Firmware Error Card found : xxxxx , v0136 Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.00 r3 Operation : Read Firmware [ v2.00 r3 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : PreLoader USB VCOM (Android) (COM5) MODE : PRELOADER PORT PORT : 5 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6582 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 TYPE : LEGACY MTK Info : Device is not supported yet! Reconnect Power/Cable! But Old version 1.58 Success Read Info Card found : S/N : xxxxx, v0136 Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 45010053454D3034472805CABCC67123 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x45 , OEM : 0100 [eMMC] : FLASH_INF : [SANDISK] , G40ME [eMMC] : FLASH_CID : 45010053454D3034472805CABCC67123 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB] DEV RID : 0x02685F6C751709C4FFD389371CB26CEF INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Done! Elapsed: 00:00:06 Reconnect Power/Cable! Read Flash Card found : S/N : xxxxxxx , v0136 Chinese Miracle II [MTK module] v 1.58 Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 45010053454D3034472805CABCC67123 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x45 , OEM : 0100 [eMMC] : FLASH_INF : [SANDISK] , G40ME [eMMC] : FLASH_CID : 45010053454D3034472805CABCC67123 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB] DEV RID : 0x02685F6C751709C4FFD389371CB26CEF INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... Brand : Walton ProdName : Primo_EF2 ProdModel : Primo_EF2 Device : Primo_EF2 AndroidVer: 4.4.2 MTKxCPU : MT6582 MTKxPRJ : ALPS.KK1.MP1.V2.11 [Read Ok] : preloader_techain82_wet_kk.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : EBR2 [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6582 / V1.1.1 / techain82_wet_kk / EMMC Android Info saved MAUI Meta DB saved HWConfig Info saved FW Size : 1186 MiB Scatter saved to : C:\Users\J.H\Documents\MT6582__Walton__Primo_EF2__ Primo_EF2__4.4.2__ALPS.KK1.MP1.V2.11\ All done! Done! Elapsed: 00:04:57 Reconnect Power/Cable! |
05-24-2018, 14:59 | #2 (permalink) |
No Life Poster Join Date: Jan 2013 Location: gsmhosting Age: 29
Member: 1876736 Status: Offline Thanks Meter: 735 | your mind Full of BUG just read updates log if you still did not get it thats your brain bug |
The Following 7 Users Say Thank You to sky73 For This Useful Post: |
05-24-2018, 15:12 | #4 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | old Devices will Work on version 1.58 new secure boot devices is supported on v2 see update logs and cpu list if mobile with listed cpu does not work then you can post here with logs . |
The Following User Says Thank You to Akhtar Ali Jatt For This Useful Post: |
05-24-2018, 15:14 | #5 (permalink) |
No Life Poster Join Date: May 2005 Location: Romania Focsani
Member: 149135 Status: Offline Thanks Meter: 234 | Your brain (if you have one) is full off bug. I see every day some kind of message..sorry to you if you don not undestand how to work with this software. |
The Following 2 Users Say Thank You to djdansmart For This Useful Post: |
05-24-2018, 20:24 | #7 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Important information: - You DO NOT need to update Smart-Card to use this version. Smart-Card firmware v0136 is enough to use this version - DO NOT uninstall previous version 1.58, in some cases you still need it - Software installed to new folder /CM2MT2/ and designed to support new models - If you are trying to connect phone with new software and see a message like LEGACY MTK - please use version 1.58 for this device ! |
The Following 3 Users Say Thank You to InfinityHelp For This Useful Post: |
05-25-2018, 00:22 | #8 (permalink) |
Freak Poster Join Date: Aug 2017 Location: Mindanao Philippines
Member: 2752651 Status: Offline Thanks Meter: 182 | [QUOTE=maxpro12;13148580]Read Info Error Card found : xxxxx , v0136 Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.00 r3 Operation : Identify [ v2.00 r3 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : PreLoader USB VCOM (Android) (COM5) MODE : PRELOADER PORT PORT : 5 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6572 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 TYPE : LEGACY MTK Info : Device is not supported yet! Reconnect Power/Cable! ------------------------------------------------------------------------------------------------------------------------------------ Your brain is full of bug not the tools, you did not even know how to use it or what tools to use |
The Following User Says Thank You to meerl329 For This Useful Post: |
06-02-2018, 10:44 | #10 (permalink) |
Freak Poster Join Date: Oct 2007 Location: Armenia, Armavir
Member: 616204 Status: Offline Thanks Meter: 26 | I Cannot update smart card Error: === DongleManager [Infinity] v1.72 [02.06.2018 13:41:25] === Searching... Card-Reader: Gemalto e-gate Smart Card 0 HWID: ***************** Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): ******* Firmware version: 0135.02 === Process started: 02.06.2018 13:41:30 === Connecting to server Connection to server failedSocket Error # 10061 Connection refused. |
