02-11-2024, 10:10 | #16 (permalink) | |
need more info | |
02-11-2024, 13:39 | #19 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | have you tried this but it reverse direction? https://www.youtube.com/watch?v=AARe1KCtoyI |
02-11-2024, 14:37 | #21 (permalink) |
Major Poster Join Date: Sep 2017 Location: Pakistan
Member: 2761588 Status: Offline Thanks Meter: 24 | Samsung A035F U5 Frp Remove Done Operation: Reset Settings / Format FS [sc9230 Boot FireFly] [v2.22] WARNING: Reset may delete ALL USER DATA! Continue? Yes [-] Wipe [-] Userdata [+] FRP [-] Smart Reset Userdata is Off If FRP still active after reset make Userdata On and repeat operation Wait... Backup exist: C:\InfinityBox\CM2SP3\backup\sc9230_e68379ab6f1016 61\ Stage: FRP... Looking for items... 1 items found [1] Writing... Ok |
The Following 2 Users Say Thank You to usman5752 For This Useful Post: |
02-11-2024, 14:40 | #22 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Infinix-X6816C Format Error Code: Operation: Connect [T610 Boot FireFly] [v2.22] Wait... - Power device Off - Connect cable [remember Vol+ | Vol-] [remember Test-Point] Waiting for device... Device found PTFN: SPRD U2S Diag (COM91) vid 0x1782 pid 0x4D00 boot: SPRD3 boot iLoader... Ok start iLoader... Ok Handshake... Ok boot xLoader... Ok start FireFly... Ok crc? Loader exec Ok Dev UID: e5f904d52c326ee7c38fc087d34ae42039c816575c1c42c162789644605a5657 get storage info... EMMC CID: F4012241525631315813C45F082D5925 crc Ok Vendor: Biwin OEM: 290 ID: 415256313158 [ARV11X] PRV: 0x13 Serial: 3294562349 0xC45F082D MM/YY: 5/2022 CSD: D02701320F5903FFFFFFFFEF8A404001 temp_write_protect: False perm_write_protect: False wp_group: 0x10 en 0x01 EXTCSD rev1.8 EMMC 5.1 ERASE_GROUP_DEF: 0x 0400 BOOT_BUS_WIDTH: 0x00 PARTITION_CONFIG: 0x08 RST_N_FUNCTION: 0x01 PART_S_COMPLETED: False BOOT0/BOOT1 SIZE: 0x00400000 4.00 Mb WP_GRP_SIZE: 0x00800000 8.00 Mb RPMB size: 0x00400000 4.00 Mb SIZE: Market 64 Gb SIZE: Actual 0xE90000000 58.25 Gb EOL: Status: Normal: Less than 80% reserved blocks used EOL_A: SLC status: 30% - 40% used EOL_B: MLC status: 20% - 30% used read extcsd... Ok extcsd stored: C:\InfinityBox\CM2SP3\backup\ext_csd\T618_e5f904d52c326ee7_extcsd_00F4-Biwin_ARV11X_5.1_2024-02-11.bin Verify config values... Ok get partitions... Partitions: 77 items Connected get slots... slot: b get sw info... probe boot... [vendor_boot_a] [boot_a] SW: Infinix/X6816C-GL/Infinix-X6816C:11/RP1A.201005.001/230704V17:user/release-keys Product Device: Infinix-X6816C Product Name: X6816C-GL Product Model: Infinix X6816C Product Brand: Infinix SW Version: 230704V17 Display ID: X6816C-ST683SBCDS-R-GL-230704V17 Market Name: Infinix HOT 12 Play Patch Level: RP1A.201005.001 Display ID: RP1A.201005.001 release-keys Ver. CodeName: REL Ver. Release: 11 Sec. Patch: 2023-07-05 Build Time: 04/07/2023 6:15:28 am CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Info: X6816C SW: X6816C-ST683SBCDS-R-GL-230704V17 Product Board: X6816C Board Platform: ums512 Product Manfct: INFINIX MOBILITY LIMITED Android Ver: 11; UserDataFS: 0x02 [ext4|8+]; CacheFS: 0x02 [ext4|8+] Device ID: infinix-mobility-limited-infinix-x6816c-x6816c-gl-infinix-hot-12-play Strategy: [infinix] Firmware ID: UMS512_INFINIX_MOBILITY_LIMITED_Infinix_X6816C_OSv11_RP1A.201005.001_X6816C Read Device-ID... IMEI[0]: IMEI[1]: IMEI[2]: IMEI[3]: BT MAC: ac:29:29:bb:81:f4 WF MAC: ac:29:29:bb:81:f5 Backup 8 items to: C:\InfinityBox\CM2SP3\backup\T618_e5f904d52c326ee7\ Read [1/8] prodnv 10.00 Mb Ok Read [2/8] miscdata 1024.00 Kb Ok Read [3/8] uboot_a 1024.00 Kb Ok Read [4/8] uboot_b 1024.00 Kb Ok Read [5/8] l_fixnv1_a 2.00 Mb Ok Read [6/8] l_fixnv2_a 2.00 Mb Ok Read [7/8] l_fixnv1_b 2.00 Mb Ok Read [8/8] l_fixnv2_b 2.00 Mb Ok Done 8 files Compress: C:\InfinityBox\CM2SP3\backup\T618_e5f904d52c326ee7\ Cleanup... Ok Verify C:\InfinityBox\CM2SP3\backup\T618_e5f904d52c326ee7.7z Verified [4fded18c] Loaded 77 Finished 1 min 26 sec Operation: Reset Settings / Format FS [T610 Boot FireFly] [v2.22] WARNING: Reset may delete ALL USER DATA! Continue? Yes [-] Wipe [+] Userdata [+] FRP [+] Smart Wait... Stage: FRP... Looking for items... 1 items found [1] Writing... Ok Completed Stage: Userdata... [1] Format... Ok 1 sec [2] Format... Ok 6 sec [3] Format... fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED Ok 1 min 12 sec Completed Stage: Smart... [17] Format... [l_runtimenv1] size 0x200000 addr 0x200000; code 0x00 [18] Format... fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED fault 0x79 0x84 | BSL_REP_OPERATION_FAILED Ok Completed Finished 1 min 27 sec |
02-11-2024, 15:03 | #23 (permalink) | |
02-11-2024, 15:19 | #24 (permalink) | |
Freak Poster Join Date: Sep 2007 Location: algeria Age: 35
Member: 580077 Status: Online Sonork: 100.1591941 Thanks Meter: 207 | Quote:
access to developper option blocked from admin | |
02-12-2024, 20:58 | #26 (permalink) |
Freak Poster Join Date: Dec 2010 Location: cairo Age: 44
Member: 1468987 Status: Offline Thanks Meter: 163 | #CM2SP3 v2.23 (https://infinity-box.com/news/?r=4330) released - [MemoryTool] and more features |
The Following User Says Thank You to hamada yousri For This Useful Post: |
