09-14-2020, 08:03 | #1 (permalink) |
Freak Poster Join Date: Aug 2015 Location: Peace Age: 27
Member: 2441366 Status: Offline Sonork: Telegram: @FahadBoss10 Thanks Meter: 245 | Infinity CM2MT2 invalid class error! Infinity CM2MT2 module is showing invalid class error on starting. Error: After clicking OK module starts but nothing shows. I've tried uninstalling and installing it again, but same error. Rest modules working fine. |
09-14-2020, 09:24 | #4 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | You dongle firmware was updated not long time ago, it should be no problem with the dongle. Do you have any antivirus installed ? Try to disamle it or add CM2MT2 to exception. Result ? |
09-14-2020, 10:25 | #7 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | If DongleManager can not read data well it may be a problem with smart-card, your smart-card is from year 2007 Try to connect Dongle to another PC Try to insert Smart-Card into another Card-Reader or Box If problem still exist: - Remove Smart-Card from Card-Reader - Clean Smart-Card contacts - Try to use hot air gun and heat Smart-Card - Insert Smart-Card back to Card-reader |
09-15-2020, 15:27 | #11 (permalink) |
Member: 2441366 Status: Offline Sonork: Telegram: @FahadBoss10 Thanks Meter: 245 | Finally, problem solved after clean installing Windows as a last resort. Thank you for all your responses! |
The Following 2 Users Say Thank You to fahadboss For This Useful Post: |
01-24-2021, 21:29 | #12 (permalink) |
Junior Member Join Date: Jun 2017 Location: Maputo,nampula
Member: 2730213 Status: Offline Thanks Meter: 2 | Card found : 98FA2699 , v0147 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.17 Load IDBase v729152 Ok! Operation : Reset Settings/Format FS [ v2.17 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM115) MODE : BOOTROM PORT : 115 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6785 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Krug TYPE : MODERN RAPHAEL BROM : MEID : 684F479B6CAF7F0272D6FDFE74A98E50 BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : Xiaomi : Helio [G90][A22] | Manual : Disabled BROM : SOCID : 82E34F9FAD8CAAC196FB03FD2827828A5AEC50F5069D8C65E2 D896C56BA4864F BROM : SLA : Local Auth BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA_V2.bin AGENT : Found MT6785 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! DA : EMI : Failed to get EMI info from selected source! Error : Fail to init protocol! >>> Internal EMI : Select other EMI number! External Preloader - make sure it correct for connected device! Reconnect Power/Cable! |
01-24-2021, 21:34 | #13 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
01-24-2021, 21:39 | #14 (permalink) |
Freak Poster Join Date: Sep 2017 Location: Rawalpindi
Member: 2755459 Status: Offline Thanks Meter: 46 | Hi JayDi boss please make your official chenal on YouTube because with this new update you are going to shake all the vendor in market...really appreciate your team work... please make a YouTube channel and I will do whatever I could to promote it....again thanks for update I am using cm2 since 7 years Sent from my SM-N960F using Tapatalk |
01-24-2021, 22:10 | #15 (permalink) | |
For now you can join to Telegram Channel and to facebook group | |
The Following 2 Users Say Thank You to YellowBoss For This Useful Post: |
