02-12-2020, 18:19 | #211 (permalink) | |
Freak Poster Join Date: Dec 2015 Age: 46
Member: 2496790 Status: Offline Thanks Meter: 11 | Quote:
and the engeneers listen to ower requests ! so .. this is best team ! | |
02-19-2020, 11:08 | #216 (permalink) | ||
No Life Poster Join Date: Aug 2008 Location: Spain
Member: 840762 Status: Offline Thanks Meter: 166 | In latest data explorer not way for extract phonebook in android tab: I try qualcomm in rda tab: Quote:
BR Last edited by NEOCRIVI; 02-19-2020 at 11:14. | ||
02-19-2020, 11:46 | #217 (permalink) | |
Work about more files format support is in progress. | |
The Following 3 Users Say Thank You to InfinitySupport For This Useful Post: |
02-19-2020, 21:03 | #218 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | One more firmware type has been tested: FLYCOM61D_M151C_TEXET_PCB01_gprs_MT6261_S00.TEXET_ V1_0 Last edited by YellowBoss; 02-19-2020 at 21:09. |
02-24-2020, 12:11 | #219 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Infinity Data Explorer v1.05 - MTK functions for SMS released, Heuristic engine updated Data extraction based on full reconstruction of file system - SMS extraction for MTK activated, supports multipart sms supported as well - Heuristic engine updated - more data can be found/extracted from the unknown dumps - GUI improved - Minor bugs fixed |
02-24-2020, 19:48 | #220 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | One more firmware has been tested and found supported with Infinity Data Explorer. Firmware version: M810H_D_HL_M24D_V31_PCB01_gprs_MT6261_S00.SENSEIT_ L208_V18_04032017 |
02-24-2020, 20:51 | #221 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Philips-E180 firmware tested and found supported. SANGFEI60_11B_E180_RU_PCB01_gprs_MT6260_S00.E180_M 6260A_1535_V11A_RU Code: Operation : Extract Data from MTK Dump [v1.05] Loading file : PhilipsE180_Full.img ... OK Detected SF_BOOT Type *** Memory Info : [0200][0001][0000] Searching FileSystem ... OK *** FileSystem found at: [00B00000] size: [00500000] Extracting FileSystem ... *** Stage #1 *** Stage #2 Checking FileSystem image ... OK Searching additional data ... *** IMEI[0]: 865832029093549 *** IMEI[1]: 865832029104544 *** Sec Code : 1122 [NOT ACTIVE] Searching required data ... *** Names Found *** Numbers Found Extracting contacts... *** PhoneBook size: 1000 contact(s) *** Extracted 588 contact(s) TXT saved to - C:\InfinityBox\DataExplorer\ReadOut\PhilipsE180_Full\ VCF saved to - C:\InfinityBox\DataExplorer\ReadOut\PhilipsE180_Full\ Finish. |
02-24-2020, 20:51 | #222 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | RugGear RG150 firmware tested and found supported. Code: Operation : Extract Data from MTK Dump [v1.05] Loading file : RugGear-RG150_FARSIGHTED60A_BT_11B_PCB01_gprs_MT6260_S00.RG150_NEW_RUSSIAN_5_V3_1_V2_0_20150209.bin ... OK Detected SF_BOOT Type *** Memory Info : [0200][0001][0000] Searching FileSystem ... OK *** FileSystem found at: [00670000] size: [0018E000] Extracting FileSystem ... *** Stage #1 *** Stage #2 Checking FileSystem image ... OK Searching additional data ... *** IMEI[0]: 863695024591847 *** IMEI[1]: 863695024622444 *** Sec Code : 1122 [NOT ACTIVE] Searching required data ... *** Names Found *** Numbers Found Extracting contacts... *** PhoneBook size: 1000 contact(s) *** Extracted 545 contact(s) TXT saved to - C:\InfinityBox\DataExplorer\ReadOut\RugGear-RG150_FARSIGHTED60A_BT_11B_PCB01_gprs_MT6260_S00.RG150_NEW_RUSSIAN_5_V3_1_V2_0_20150209\ VCF saved to - C:\InfinityBox\DataExplorer\ReadOut\RugGear-RG150_FARSIGHTED60A_BT_11B_PCB01_gprs_MT6260_S00.RG150_NEW_RUSSIAN_5_V3_1_V2_0_20150209\ Finish. |
02-24-2020, 20:52 | #223 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Philips-E311 firmware tested and found supported Code: Operation : Extract Data from MTK Dump [v1.05] Loading file : SANGFEI60_11B_E311_RU_PCB01_gprs_MT6260_S00.E311_M6260A_1637_V18A_RU.bin ... OK Detected SF_BOOT Type *** Memory Info : [0200][0001][0000] Searching FileSystem ... OK *** FileSystem found at: [00B00000] size: [00500000] Extracting FileSystem ... *** Stage #1 *** Stage #2 Checking FileSystem image ... OK Searching additional data ... *** IMEI[0]: 866635025092558 *** IMEI[1]: 866635027842554 *** Sec Code : 1122 [NOT ACTIVE] Searching required data ... *** Names Found *** Numbers Found Extracting contacts... *** PhoneBook size: 1000 contact(s) *** Extracted 199 contact(s) TXT saved to - C:\InfinityBox\DataExplorer\ReadOut\SANGFEI60_11B_E311_RU_PCB01_gprs_MT6260_S00.E311_M6260A_1637_V18A_RU\ VCF saved to - C:\InfinityBox\DataExplorer\ReadOut\SANGFEI60_11B_E311_RU_PCB01_gprs_MT6260_S00.E311_M6260A_1637_V18A_RU\ Finish. |
03-11-2020, 23:32 | #224 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Infinity Data Explorer v1.06 - Android contacts/sms support and more Data extraction based on full reconstruction of file system - Contacts and accounts reconstrucion from Android storage contacts2.db - SMS messages reconstrucion from Android storage mmssms.db - Data storage engine rebuilded - TXT file storage format updated - Minor bugs fixed |
