Old 11-18-2009, 18:57   #1 (permalink)
gee4234's Avatar
Member: 86579
Thanks Meter: 70
Infinity does not support flashing LG KP215 Confirmed
hello
infinity does not support this model for flash.unlock and format work fine but when you try to flash it always fails in the same place i thought it was phone with bad hardware.so i tried to flash a kp215 that was working fine and flashed failed in the same place and ended up with a dead. .hopefully infinity team will look into this problem.also this kp215 that i tried to flash that was working but ended up dead after flash i sent to my frined who has other box and was revived with flash no problem
Gee4234
Device: LG-KP215
Checking data, wait...
Action: flash write
Write: Firmware (code)
Skip: File system
Skip: Alchemy data
Skip: Eeprom
"smart write" active
"keep calibration" active
Boot ...
Connecting, wait...
Release Power button now !
flash: 20880EFFFFFFFF:20880E00000000
flash: ST Intel/Sharp ext [def 0004x008000 00FFx020000] 32Mb
Boot Done
Set baud ...
115200
Set baud Done
Check flash ...
current eeprom imei: 011416006521749
file saved: C:\Program Files\InfinityBox\LGA\eeprom_011416006521749_LG-KP215_20091118-133817.B1E.bin
Check flash Done
Check space ...
Check space Done
Check parameters ...
Check parameters Done
Erase ...
Erase Done
Write ...
calibration area skipped
error: no any expected answer
error: flash write error: 010A0000:00020000
Write Fail
Finished, time used: 172 sec
Remove/Install battery now !
Old 11-18-2009, 23:46   #2 (permalink)
gee4234's Avatar
Member: 86579
Thanks Meter: 70
infinity team please fix this problem
hello infinity support
please fix this issue.
Gee4234
Old 11-19-2009, 01:22   #3 (permalink)
gee4234's Avatar
Member: 86579
Thanks Meter: 70
i have solved the problem
what i did was install older versions of LGA module 1.39,1.37,1.36,1.35 get errors flashing kp215.with version LGA 1.33 its flashing and past 5% when it is done i will confirm and post log
Gee4234
The Following User Says Thank You to gee4234 For This Useful Post:
Old 11-20-2009, 17:05   #4 (permalink)
gee4234's Avatar
Member: 86579
Thanks Meter: 70
COM2 [VCP0] selected
Device: LG-KP215
advanced flash detection active
Action: flash write
Skip: File system
Write: Alchemy data
Write: Eeprom
"smart write" enabled
Boot...
Phone must be POWERED-OFF !
Press and HOLD Power button !
Connecting, wait...
Release Power button !
Boot Done
Set baud...
921600
Set baud Done
Check flash...
current eeprom imei: 011416005295774
file saved: C:\Program Files\InfinityBox\LGA1.33\eeprom_011416005295774_L G-KP215_20091120-125536.B1E.bin
Check flash Done
Check space...
Check space Done
Check parameters...
Erase...
Erase Done
Write...
Write: Alchemy data
Write: Eeprom
Write Done
Finished, time used: 470 sec
The Following 3 Users Say Thank You to gee4234 For This Useful Post:
Old 11-20-2009, 18:11   #5 (permalink)
gee4234's Avatar
Member: 86579
Thanks Meter: 70
hello infinity team
can you add full flash for kp215a.because after flash phone still hangs on logo.i have this same problem with kp110 after flashing code and alchemy.but when i flash full flash to kp110 phone works 100%.im thinking with a full flash for kp215a it will solve this problem like it does in kp110.
thanx
Gee4234
Old 11-22-2009, 23:56   #6 (permalink)
gee4234's Avatar
Member: 86579
Thanks Meter: 70
thanx
Gee4234
11-20-09 18:05
Old 11-24-2009, 13:34   #7 (permalink)
gee4234's Avatar
Member: 86579
Thanks Meter: 70
add fullflash for kp215
please support team add this fullflash to support site ASAP.i will only have this phone for test for a couple of more days.
Thank you
Gee4234
Old 02-01-2010, 17:05   #8 (permalink)
gee4234's Avatar
Member: 86579
Thanks Meter: 70
hello infinity team
i keep getting these kp215 that hang at logo.infinity box still cannot repair them but other boxes can.please infinity solve this problem.hang at logo kp215 is a very common problem and i see alot of them.please make solution to this problem so we can make money with these kp215 with this problem
Gee4234
Old 08-16-2010, 14:21   #9 (permalink)
Member: 644224
Thanks Meter: 70
Device: LG-KP215
Action: flash write
Skip: File system
Write: Alchemy data
Write: Eeprom
Boot...
Connecting, wait...
Boot Done
Set baud...
921600
Set baud Done
Check flash...
Check flash Done
Check space...
Check space Done
Check parameters...
Erase...
Erase Done
Write...
Write: Alchemy data
Write: Eeprom
Write Done
100% working solution. Brother Keep it up ............
Old 09-01-2010, 16:33   #10 (permalink)
Member: 32847
Thanks Meter: 5
I have the same situation!
Old 09-02-2010, 09:21   #11 (permalink)
Member: 32847
Thanks Meter: 5
module lga 1.34 also works with kp215.
InfinitySetupMain_v2.14a.rar contain this module.
LG KU380 does not support? ? licheng Z3X-Team Products 1 03-17-2010 08:37
KP215 not supported flash type dary775 VygisToolbox 1 12-01-2009 20:35
@ infiinty Support...Infinity Box supports or does not support Unlock alc. v607 v570 residentdenuevo Infinity-Box 0 08-15-2009 02:48
My infinity does not see all new software Eliass Infinity-Box 1 03-14-2009 16:03
How flash LG KP215 ..::Fixcell::.. VygisToolbox 0 03-03-2009 17:16
Page generated in 0.43182 seconds with 9 queries
