09-20-2015, 12:41 | #1 (permalink) |
No Life Poster Join Date: Apr 2007 Location: SL3 LBF IN Kamoke(Gujranwala)
Member: 481915 Status: Offline Sonork: 100.1604233 Thanks Meter: 476 | infinity dongle error with main infinity setup while running well with CM2 need help |
09-20-2015, 14:07 | #2 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hello, Yes, there is a problem but it may be fixed with this method - http://server1.infinity-box.com/down...artCardFix.rar Waiting for your result. |
09-20-2015, 15:33 | #3 (permalink) |
Member: 481915 Status: Offline Sonork: 100.1604233 Thanks Meter: 476 | operating system Windows seven 32bit other computer Windows xp i paste two files "original.dll, winscard.dll" into C:\Program Files\InfinityBox but still same error or suggest me correct location and also mention which files to past? |
09-20-2015, 15:49 | #4 (permalink) | |
Yes, that two files. You should copy both files in folder with EXE that can not run well. | |
09-20-2015, 16:11 | #5 (permalink) |
Member: 481915 Status: Offline Sonork: 100.1604233 Thanks Meter: 476 | i have copied these two files into HModule in C:\Program Files\InfinityBox\HModule and also in C:\Program Files\InfinityBox but same error need help to work well |
09-20-2015, 16:24 | #6 (permalink) |
Member: 481915 Status: Offline Sonork: 100.1604233 Thanks Meter: 476 | thnx for help! in Windows xp, i paste these two files into C:\Program Files\InfinityBox\HModule because i want to unlock Motorola W377 with this Module, now unlocked success but in windows seven not solved. anyway thnx for help MianLinks |
09-20-2015, 16:26 | #7 (permalink) | |
I think you can make it working at W7 also, just copy to HModule folder two files from "x64" folder from archive instead of "x32". | |
09-21-2015, 10:51 | #8 (permalink) | |||
No Life Poster Join Date: Dec 2010 Location: Gsm Hosting (INDIA)
Member: 1478271 Status: Offline Sonork: 100.1608386 Thanks Meter: 1,806 | Quote:
you have problem in Software path wrong only Download latest version Main module EXE And give path C/ not in C/program Files/InfinityBox i,m waiting your response | |||
09-21-2015, 12:32 | #9 (permalink) | |
It was a problem with old software compatibility with new Dongle but not a problem with installation path. | |
