05-06-2006, 15:32 | #1 (permalink) |
Freak Poster Join Date: Mar 2006 Location: Winnipeg Canada
Member: 244492 Status: Offline Thanks Meter: 8 | Infinity With Dongle Not Found |
The Following User Says Thank You to bambo clan For This Useful Post: |
05-07-2006, 00:04 | #4 (permalink) |
Freak Poster Join Date: Apr 2004 Age: 39
Member: 61620 Status: Offline Thanks Meter: 5 | The problem occurs when the 3 device is not found in the device manager, if one is missing you will have that problem. Make sure the SIM-card is sitting good in the dongle. Sometime I have to plug and remove it a couple of times. Regard, The Beast |
05-07-2006, 00:25 | #5 (permalink) | |
No Life Poster Join Date: Jul 2002
Member: 13737 Status: Offline Sonork: 100.100725 Thanks Meter: 194 | Quote:
TRY TO CHANGE THE SIM JACKET OF UR DONGLE IF NOT SOLVE UPDATE IT STILL NOT SOLVED SEND TO UR RESELLER FOR REPAIRS BR UHK | |
The Following User Says Thank You to UHK For This Useful Post: |
05-07-2006, 00:32 | #6 (permalink) |
No Life Poster Join Date: Mar 2004 Location: UAE / UK / PAK / HK
Member: 59731 Status: Offline Sonork: 100.99999 Thanks Meter: 514 | Are you using Infinity Dongle or Infinity Box (Smart Card) version. because there is a problem we have also come accross with Boxes (Smart Card) version the card reader inside the box is not working properly. If you are box user you can use that smart card into external USB EGATE READER it will sort out your problem. Infinity Box is a very good and stable product but its just a manufacturing problem with boxes. If problem still presist please contact me i will try my best to help you guys out. email me at [email protected] regards Sunny Unlocking Expert Ltd |
05-08-2006, 07:50 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hi, Check this: http://forum.gsmhosting.com/vbb/showthread.php?t=220849 http://forum.gsmhosting.com/vbb/showthread.php?t=260667 http://forum.gsmhosting.com/vbb/showthread.php?t=272901 http://forum.gsmhosting.com/vbb/show...ghlight=repair If it will be no luck: open box, remove sim-card from card holder, check card holder contacts, insert card back. Last edited by InfinitySupport; 05-08-2006 at 12:56. |
05-08-2006, 16:48 | #11 (permalink) | |
Member: 244492 Status: Offline Thanks Meter: 8 | MY BOX IS OK.APPRECIATE. Quote:
05-22-2014, 11:42 | #12 (permalink) |
Junior Member Join Date: Feb 2009
Member: 973592 Status: Offline Thanks Meter: 0 | The problem occurs when the 3 device is not found in the device manager, if one is missing you will have that problem. Make sure the SIM-card is sitting good in the dongle. Sometime I have to plug and remove it a couple of times. Regard, The Beast my problem have solved . |
05-26-2014, 00:52 | #14 (permalink) |
Freak Poster Join Date: Mar 2014
Member: 2157134 Status: Offline Thanks Meter: 8 | same problem not reading the dongle, I removed the sim card install it back in.. same problem no dongle reading. Dongle can't be found Error when listing readers! SmartCard API error #2148532270 Cannot find a smart card reader. |
05-26-2014, 10:45 | #15 (permalink) | |
Member: 1043909 Status: Offline Thanks Meter: 60,925 | Quote:
Install drivers: http://server1.infinity-box.biz/down...der_PKey_XP.7z Waiting for your results. | |
HELP! Dongle not found on my computer | GNOSIS | Nokia Multimedia | 41 | 02-13-2010 00:22 |
Dongle not found after upgrading with pinfinder | tavoonly | Infinity-Box | 20 | 10-12-2008 01:38 |
dongle not found how to deal with smart card broken | leroi | Infinity-Box | 5 | 08-19-2008 20:05 |
infinity box dongle cant found | COMPAQ | Infinity-Box | 8 | 05-01-2007 06:51 |
Terminator dongle not found | vrem | Sony Ericsson | 8 | 02-13-2004 03:07 |
