07-28-2008, 08:41 | #1 (permalink) |
Product Supporter Join Date: Feb 2008 Location: Jat-Chi-Bangladesh Age: 46
Member: 705213 Status: Offline Sonork: https://wa.link/aru52t Thanks Meter: 2,733 | infinity flah file to set whjte screen Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] v2.51 S/N: ***x:***x Wait... Device: Autodetect 6205-6227 NOR Done WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? COM5 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: reset Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6228:8A02:8A02]... CPU: MT6228 high speed boot enabled chip: 0031:0000:0101 error: Wrong model selected, select model: Autodetect 6228 NAND Finished, time used: 15 sec Remove/Install battery now ! Device: Autodetect 6228 NAND WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? COM5 [VCP0] selected Device: Autodetect 6228 NAND Checking data, wait... Action: NAND reset Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6228:8A02:8A02]... CPU: MT6228 high speed boot enabled chip: 0031:0000:0101 boot step size: 0400 Release Power button now ! Boot Done Initialize... version: 3.0207 loader: 3.748.0 NAND id: ADF1801D page size: 800+40 pages/block: 40 bits i/o: 08 address cycles: 04 blocks: 0400 ram size: 00800000 NOR: 0000:000000000000 [00000000] NAND: 00AD:00F10080001D [08400000] NOR chip is not installed Initialize Done Set baud... 115200 Set baud Done Identification... reading structure area... detecting structure... source data: page+spare converting data... done 0x00080000 bytes identification#1 protocol ver: 04 ver. sw1: BXWY28_06B_PCB04_GPRS_MT6228_S02.R888_320_7670_HYN _HY128_V2_1.BIN ver. sw2: R888_320_7670_Hyn_Hy128_V2.1, 40619D2D ffs offset/size: 02000000/06000000 id-page1 Ok nfi area detection finished: Ok identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.27EADFDB.[BXWY28_06B_PCB04_GPRS_MT6228_S02.R888_320_7670_HYN _HY128_V2_1.BIN_D2629EBF].rpl identification#1 detection finished Identification Done Write... formatting... .....................................error: code: 2E00006900 Write Fail file saved: C:\Program Files\InfinityBox\ChineseMiracle\system_log_27EADF DB_BXWY28_06B_PCB04_GPRS_MT6228_S02.R888_320_7670_ HYN_HY128_V2_1.BIN_D2629EBF_20080726-062429.B4X.bin Finished, time used: 116 sec Remove/Install battery now ! Last edited by ..::Neo::..; 08-02-2008 at 23:13. Reason: S/N Removed |
07-28-2008, 08:45 | #2 (permalink) |
Member: 705213 Status: Offline Sonork: https://wa.link/aru52t Thanks Meter: 2,733 | 1st time flash not on my phone BXWY28_06B_PCB04_GPRS_MT6228_S02.R888_320_7670_HYN _HY128_V2_1__I808_128m_En_Cn.B4M COM5 [VCP0] selected Device: Autodetect 6228 NAND Checking data, wait... Action: write NAND flash write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs source data: page only identification#1 protocol ver: 04 ver. sw1: BXWY28_06B_PCB04_GPRS_MT6228_S02.R888_320_7670_HYN _HY128_V2_1.BIN ver. sw2: R888_320_7670_Hyn_Hy128_V2.1, 40619D2D ffs offset/size: 02000000/06000000 id-page1 Ok nfi area detection finished: Ok Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6228:8A02:8A02]... CPU: MT6228 high speed boot enabled chip: 0031:0000:0101 boot step size: 0400 Release Power button now ! Boot Done Initialize... version: 3.0207 loader: 3.748.0 NAND id: ADF1801D page size: 800+40 pages/block: 40 bits i/o: 08 address cycles: 04 blocks: 0400 ram size: 00800000 NOR: 0000:000000000000 [00000000] NAND: 00AD:00F10080001D [08400000] NOR chip is not installed Initialize Done Set baud... 921600 Set baud Done Identification... reading structure area... detecting structure... source data: page+spare converting data... done 0x00080000 bytes identification#1 protocol ver: 04 ver. sw1: BXWY28_06B_PCB04_GPRS_MT6228_S02.R888_320_7670_HYN _HY128_V2_1.BIN ver. sw2: R888_320_7670_Hyn_Hy128_V2.1, 40619D2D ffs offset/size: 02000000/06000000 id-page1 Ok nfi area detection finished: Ok identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.27EADFDB.[BXWY28_06B_PCB04_GPRS_MT6228_S02.R888_320_7670_HYN _HY128_V2_1.BIN_D2629EBF].rpl identification#1 detection finished security area#1 calculation... Identification Done Write... file saved: C:\Program Files\InfinityBox\ChineseMiracle\system_log_27EADF DB_BXWY28_06B_PCB04_GPRS_MT6228_S02.R888_320_7670_ HYN_HY128_V2_1.BIN_D2629EBF_20080727-125754.B4X.bin write core area 1 of 3... write core area 2 of 3... write core area 3 of 3... Write Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\system_log_27EADF DB_BXWY28_06B_PCB04_GPRS_MT6228_S02.R888_320_7670_ HYN_HY128_V2_1.BIN_D2629EBF_20080727-130343.B4X.bin Finished, time used: 437 sec Remove/Install battery now ! |
07-28-2008, 08:48 | #3 (permalink) |
Member: 705213 Status: Offline Sonork: https://wa.link/aru52t Thanks Meter: 2,733 | two time flash it BXWY28_06B_PCB04_GPRS_MT6228_S02.R888_432_7670_HYN _HY128_V2_1__Cect-N528_128m_En_Cn.B4M not on my phone Loading file v.02... BXWY28_06B_PCB04_GPRS_MT6228_S02.R888_432_7670_HYN _HY128_V2_1__Cect-N528_128m_En_Cn.B4M.bin loaded identification#1 protocol ver: 04 ver. sw1: BXWY28_06B_PCB04_GPRS_MT6228_S02.R888_432_7670_HYN _HY128_V2_1.BIN ver. sw2: R888_432_7670_HYN_Hy128_V2.1, CB844424 You have loaded file with security features enabled. detecting languages... Languages: En Cn Loading file v.02... BXWY28_06B_PCB04_GPRS_MT6228_S02.R888_432_7670_HYN _HY128_V2_1__Cect-N528_128m_En_Cn.B4M.bin loaded identification#1 protocol ver: 04 ver. sw1: BXWY28_06B_PCB04_GPRS_MT6228_S02.R888_432_7670_HYN _HY128_V2_1.BIN ver. sw2: R888_432_7670_HYN_Hy128_V2.1, CB844424 You have loaded file with security features enabled. detecting languages... Languages: En Cn COM5 [VCP0] selected Device: Autodetect 6228 NAND Checking data, wait... Action: write NAND flash write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs source data: page only identification#1 protocol ver: 04 ver. sw1: BXWY28_06B_PCB04_GPRS_MT6228_S02.R888_432_7670_HYN _HY128_V2_1.BIN ver. sw2: R888_432_7670_HYN_Hy128_V2.1, CB844424 ffs offset/size: 02000000/06000000 id-page1 Ok nfi area detection finished: Ok Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6228:8A02:8A02]... CPU: MT6228 high speed boot enabled chip: 0031:0000:0101 boot step size: 0400 Release Power button now ! Boot Done Initialize... version: 3.0207 loader: 3.748.0 NAND id: ADF1801D page size: 800+40 pages/block: 40 bits i/o: 08 address cycles: 04 blocks: 0400 ram size: 00800000 NOR: 0000:000000000000 [00000000] NAND: 00AD:00F10080001D [08400000] NOR chip is not installed Initialize Done Set baud... 921600 Set baud Done Identification... reading structure area... detecting structure... source data: page+spare converting data... done 0x00080000 bytes identification#1 protocol ver: 04 ver. sw1: BXWY28_06B_PCB04_GPRS_MT6228_S02.R888_320_7670_HYN _HY128_V2_1.BIN ver. sw2: R888_320_7670_Hyn_Hy128_V2.1, 40619D2D ffs offset/size: 02000000/06000000 id-page1 Ok nfi area detection finished: Ok identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.27EADFDB.[BXWY28_06B_PCB04_GPRS_MT6228_S02.R888_320_7670_HYN _HY128_V2_1.BIN_D2629EBF].rpl identification#1 detection finished warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.27EADFDB.[BXWY28_06B_PCB04_GPRS_MT6228_S02.R888_432_7670_HYN _HY128_V2_1.BIN_DBBB7B34].rpl warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.27EADFDB._BXWY 28_06B_PCB04_GPRS_MT6228_S02.R888_432_7670_HYN_HY1 28_V2_1.BIN_DBBB7B34_.rpl warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.27EADFDB.[BXWY28_06B_PCB04_GPRS_MT6228_S02.R888_432_7670_HYN _HY128_V2_1.BIN_DBBB7B34].rpl warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.27EADFDB._BXWY28_06B_PCB04_GPRS_MT6228_S02.R888_ 432_7670_HYN_HY128_V2_1.BIN_DBBB7B34_.rpl ==================== warning: unknown identification#1 structure: BXWY28_06B_PCB04_GPRS_MT6228_S02.R888_432_7670_HYN _HY128_V2_1.BIN_DBBB7B34 error: Unknown firmware, user action required: 1. download latest software from support area and try again ! 2. if no still luck follow the next procedure: - find good working phone with the same firmware: BXWY28_06B_PCB04_GPRS_MT6228_S02.R888_432_7670_HYN _HY128_V2_1.BIN - make "Read detailed information" operation - send "backup_system_log_..." file to support: [email protected] - make "Read full flash" operation - send flash backup file(s) to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) - be little bit patient and wait update ==================== You can flash phone now but can't finalize it. In most cases phone can NOT power-on normally. Do you want to write flash anyway ? Identification Done Write... file saved: C:\Program Files\InfinityBox\ChineseMiracle\system_log_27EADF DB_BXWY28_06B_PCB04_GPRS_MT6228_S02.R888_320_7670_ HYN_HY128_V2_1.BIN_D2629EBF_20080727-131433.B4X.bin write core area 1 of 3... write core area 2 of 3... write core area 3 of 3... Write Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\system_log_27EADF DB_BXWY28_06B_PCB04_GPRS_MT6228_S02.R888_320_7670_ HYN_HY128_V2_1.BIN_D2629EBF_20080727-132103.B4X.bin Finished, time used: 736 sec Remove/Install battery now ! |
07-28-2008, 09:01 | #4 (permalink) |
Member: 705213 Status: Offline Sonork: https://wa.link/aru52t Thanks Meter: 2,733 | 3rd time flash it BXWY28_06B_PCB04_GPRS_MT6228_S02.R888_432_6680_INF _HY64_V2_2_TR__ZT8900_64m_En_Cn_Cn.B4M its file flash to white screen this file flash to set on but white display ==== log opened: [7/27/2008 1:41:02 PM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] v2.51 S/N: ****:**** Wait... Device: Autodetect 6205-6227 NOR Done Device: Autodetect 6228 NAND Loading file v.02... BXWY28_06B_PCB04_GPRS_MT6228_S02.R888_432_6680_INF _HY64_V2_2_TR__ZT8900_64m_En_Cn_Cn.B4M.bin loaded identification#1 protocol ver: 04 ver. sw1: BXWY28_06B_PCB04_GPRS_MT6228_S02.R888_432_6680_INF _HY64_V2_2_TR.BIN ver. sw2: R888_432_6680_inf_Hy64_V2.2_TR, BF72D7D6 You have loaded file with security features enabled. detecting languages... Languages: En Cn Cn COM5 [VCP0] selected Device: Autodetect 6228 NAND Checking data, wait... Action: write NAND flash write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs source data: page only identification#1 protocol ver: 04 ver. sw1: BXWY28_06B_PCB04_GPRS_MT6228_S02.R888_432_6680_INF _HY64_V2_2_TR.BIN ver. sw2: R888_432_6680_inf_Hy64_V2.2_TR, BF72D7D6 ffs offset/size: 02000000/02000000 id-page1 Ok nfi area detection finished: Ok Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6228:8A02:8A02]... CPU: MT6228 high speed boot enabled chip: 0031:0000:0101 boot step size: 0400 Release Power button now ! Boot Done Initialize... version: 3.0207 loader: 3.748.0 NAND id: ADF1801D page size: 800+40 pages/block: 40 bits i/o: 08 address cycles: 04 blocks: 0400 ram size: 00800000 NOR: 0000:000000000000 [00000000] NAND: 00AD:00F10080001D [08400000] NOR chip is not installed Initialize Done Set baud... 115200 Set baud Done Identification... reading structure area... detecting structure... source data: page+spare converting data... done 0x00080000 bytes identification#1 protocol ver: 04 ver. sw1: BXWY28_06B_PCB04_GPRS_MT6228_S02.R888_432_6680_INF _HY64_V2_2_TR.BIN ver. sw2: R888_432_6680_inf_Hy64_V2.2_TR, BF72D7D6 ffs offset/size: 02000000/02000000 id-page1 Ok nfi area detection finished: Ok identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.27EADFDB.[BXWY28_06B_PCB04_GPRS_MT6228_S02.R888_432_6680_INF _HY64_V2_2_TR.BIN_29288D40].rpl identification#1 detection finished security area#1 calculation... Identification Done Write... file saved: C:\Program Files\InfinityBox\ChineseMiracle\system_log_27EADF DB_BXWY28_06B_PCB04_GPRS_MT6228_S02.R888_432_6680_ INF_HY64_V2_2_TR.BIN_29288D40_20080727-134332.B4X.bin write core area 1 of 3... write core area 2 of 3... write core area 3 of 3... Write Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\system_log_27EADF DB_BXWY28_06B_PCB04_GPRS_MT6228_S02.R888_432_6680_ INF_HY64_V2_2_TR.BIN_29288D40_20080727-142010.B4X.bin Finished, time used: 2294 sec Remove/Install battery now ! Last edited by ..::Neo::..; 08-02-2008 at 23:14. Reason: S/N Removed |
07-28-2008, 09:08 | #6 (permalink) |
Member: 705213 Status: Offline Sonork: https://wa.link/aru52t Thanks Meter: 2,733 | infinjty support area flash file BXWY28_06B_PCB04_GPRS_MT6228_S02.R888_320_7670_HYN _HY128_V2_1__I808_128m_En_Cn.B4M BXWY28_06B_PCB04_GPRS_MT6228_S02.R888_432_7670_HYN _HY128_V2_1__Cect-N528_128m_En_Cn.B4M BXWY28_06B_PCB04_GPRS_MT6228_S02.R888_432_6680_INF _HY128_V2_1__ZTC-ZT8900_En_Cn.B4M BXWY28_06B_PCB04_GPRS_MT6228_S02.R888_432_6680_INF _HY64_V2_2_TR__ZT8900_64m_En_Cn_Cn.B4M |
07-28-2008, 17:35 | #8 (permalink) |
Member: 705213 Status: Offline Sonork: https://wa.link/aru52t Thanks Meter: 2,733 | no looks like flash file support area sir . many many set i can compleat infinity box . so sir need your help. |
07-28-2008, 17:49 | #9 (permalink) |
No Life Poster Join Date: Jul 2004 Location: Cuttack,India Age: 54
Member: 71721 Status: Offline Sonork: 100.106320 Thanks Meter: 139 | remove sirial no from your 1st post and try other flash file mtk 6228 based may be your original firmware different from this firmware. |
The Following User Says Thank You to TURNING POINT For This Useful Post: |
@ infinity , need to be touch screen cal. of this flash file | Faisal_Computer | Infinity-Box | 0 | 01-04-2009 16:38 |
!!! if i flahs the z6 with the flahs file of support IT CAN BE UNLOCKEC AUTO..???' | ktienda | Smart-Clip | 1 | 09-19-2007 15:44 |
Wich files to flahs K700 | delo | SonyEricsson (USB-Smart) | 1 | 02-10-2006 00:29 |
Where to find Swedish Flah file?? | Shaterlo | Twisterflasher | 3 | 10-06-2004 00:03 |
