Old 05-23-2008, 06:46   #1 (permalink)
Member: 294245
Sonork: 100.1602405
Thanks Meter: 115
infinity and friend help
COM2 [Serial2] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: read/check detailed information
Boot...
19200 fixed
Connecting, wait...
Initializing[6226:8A02:8A01]...
CPU: MT6226
high speed boot disabled
chip: 0031:AF8E:3C20
high speed disabled
boot step size: 0002
Release Power button now !
Boot Done
Initialize...
flash: 01227E22202200:2BFA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
115200
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
it's time to stop: 2B0000EA18E09FE518E09FE518E09FE518E09FE518E09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detection phase #2...
warning: identification#1 information not found, possible reasons:
.old firmware type w/o identification#1 data
.damaged firmware
.damaged hardware
if phone works fine just ignore this warning
detect device identification#1 finished
detect device identification#2...
warning: optional information not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset assigned: 00E00000
checking area[00000000]: 00000000-00FFFFFF...
Can't detect eeprom/ffs area
Do you want to use standard ffs address: 00E00000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
standard ffs address selected by user
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
detecting ffs structure pass 1...
can't detect fat record name location
ffs element #1 detection failed
detecting ffs structure pass 2...
ffs element #2 detection failed
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
Finished, time used: 95 sec
Remove/Install battery now !
Old 05-23-2008, 09:56   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
What is the problem with phone ?
Old 05-23-2008, 12:18   #3 (permalink)
Member: 294245
Sonork: 100.1602405
Thanks Meter: 115
u mean this is hard ware
Old 05-23-2008, 18:04   #4 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
no, we asking what problem do you have with your phone?
friends help n73 ??? sajjadahmad Universalbox 5 03-29-2010 18:57
For Infinity support please help and other user member magucha Infinity-Box 1 12-11-2009 18:59
Daily reading threads and adding helpful info for my friends in my shell hasnain FuriousGold 13 06-05-2009 11:07
Infinity team plz help me and give me flash file aamirgsm Infinity-Box 14 12-01-2008 08:41
C139 and infinity problem need help berigaz Motorola ODM 2 06-29-2006 22:39
Page generated in 0.17289 seconds with 9 queries
