11-27-2008, 18:40 | #1 (permalink) |
No Life Poster Join Date: Feb 2006 Location: United State
Member: 229658 Status: Offline Thanks Meter: 60 | chinese nokia flashig procedure i am new i the system pls thanks |
11-27-2008, 19:47 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, How to write flash (step-by-step instruction): 1. connect cable 2. run "Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Flash" page and load required files 8. press "Write" button and follow instruction given by software How to unlock (step-by-step instruction): 1. connect cable 2. run "Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "SP-Unlock" button and follow instruction given by software How to reset/format ffs (step-by-step instruction): 1. connect cable 2. run "Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "Reset" or "Format" button and follow instruction given by software |
11-27-2008, 21:03 | #3 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
Flashing is a last thing to do. Always try to solve problem first by Format FFS safe and if not help- format FFS complete. To avoid problems- always make full backup (read full flash operation) before work. please ask here needed steps. First step is assembling cable. do you have it ready? | |
Nokia 2610b procedure step by step after unlock to have network 900MHz help me???? | Unlocker AL | MT-BOX | 1 | 11-16-2009 06:01 |
Chinese nokia e60i need help for flash files | HAROON's | Infinity-Box | 7 | 07-22-2007 13:42 |
Chinese NOKIA Problem | .:==di@bila==:. | Infinity-Box | 1 | 07-19-2007 22:46 |
Chinese Nokia N95 Cable Connecter Pinout | maplegsm | Infinity-Box | 0 | 07-18-2007 11:53 |
Haw Do I Unlock U8800 Chinese Nokia | joe 1 | Infinity-Box | 1 | 06-24-2007 19:06 |
