Old 12-26-2005, 10:38   #1 (permalink)
hitibiti's Avatar
Member: 24023
Sonork: 100.61317
Thanks Meter: 2,630
infinity kill my panaX200
my phone working good problem is auto power off after 10second , i try bto flash it using infinity , copnnect and eraze flash after that i have error !
i try again softcan't detect mobile and i have this problem
Testing COM1 at 115200...
Done[10]
Boot...
Press Power button now !
Checking...
Err: wrong Boot answer2: 00
Boot Failed
Finished
Remove/Install battery now !
Time used: 18 sec
any help ?
Old 12-26-2005, 12:40   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Hi,
There is some difference between "my phone working good" and "is auto power off after 10second".
It's impossible to kill X200 permanently in any case because this phone can be booted/flashed even if flash chip is totally erased.
So, pls, check phone hardware first and double check your cable.
Old 12-26-2005, 14:03   #3 (permalink)
hitibiti's Avatar
Member: 24023
Sonork: 100.61317
Thanks Meter: 2,630
cable working good , test now in Flash panasonic A102
Old 12-26-2005, 14:37   #4 (permalink)
needi's Avatar
Member: 18303
Thanks Meter: 3
Its 100% Flash chip fault.Its not infinity fault....i did flashed many X200 with it without any problems.
Old 12-26-2005, 16:00   #5 (permalink)
Member: 81373
Thanks Meter: 5
@ hitibiti
what infinity are you talking about ?
In a post in panasonic section u said you tried to use a so called infiniy cracked? , what support are you asking here ?
All members loook at this post , this member should be banned
this man made fake log , infinity cracked can not perform any function not even read info .
he said , he erased flash , this is false too
This is his post in panasonic section
http://forum.gsmhosting.com/vbb/showthread.php?t=257866
MIKE
Old 12-26-2005, 16:45   #6 (permalink)
needi's Avatar
Member: 18303
Thanks Meter: 3
This is very bad......really very bad.
Old 12-26-2005, 16:55   #7 (permalink)
hitibiti's Avatar
Member: 24023
Sonork: 100.61317
Thanks Meter: 2,630
i have infinity freind i by it specily for X200
Old 12-26-2005, 16:57   #8 (permalink)
hitibiti's Avatar
Member: 24023
Sonork: 100.61317
Thanks Meter: 2,630
Originally Posted by InfinitySupport
Hi,
after try many time phoen flashed and alive now
but , same problem before after power on , he work for 10second , and auto power off any solution?
Old 12-26-2005, 17:11   #9 (permalink)
Member: 130995
I think you need to check phone hardware.
Old 12-26-2005, 17:13   #10 (permalink)
hitibiti's Avatar
Member: 24023
Sonork: 100.61317
Thanks Meter: 2,630
@InfinitySupport
u mean ic flash is damajed ?
Old 12-26-2005, 17:35   #11 (permalink)
Member: 130995
It can be any part of HW damaged.
If it was problems with this phone booting then it can be CPU problem. Of course it's need to check (maybe resolder) flash IC.
infinity killed my bluetooth zt8866 sahil00150 Infinity-Box 5 04-09-2009 19:04
i kill my phone infinity team uburo22 Infinity-Box 3 12-30-2008 10:38
Infinity killed my X300 gsm flying free Infinity-Box 10 02-06-2008 06:44
!!! Infinity Kill C121 !!! Umbabaraumba Infinity-Box 1 11-05-2007 16:31
Infinity Kill pantech PG-6100 after reset Tan Thanh Infinity-Box 3 03-27-2007 19:45
Page generated in 0.28192 seconds with 9 queries
