02-15-2018, 07:22 | #1 (permalink) |
No Life Poster Join Date: Sep 2008 Location: Bohicon (Rep of Benin)
Member: 862014 Status: Offline Sonork: 100.1608307 Thanks Meter: 64 | INFINITY mt6753 X601-H537A1-M-161009V33 don't change after flash I've been trying to flash one infinix x601 mt6753 X601-H537A1-M-161009V33 for days but nothing changes in it even after formatting. it begin the flash fine with sp tool or infinity soft but at the end it display error and all customer data it always inter. Need help think |
02-15-2018, 09:46 | #3 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
Make HW Test and check eMMC state. Br. Infinity Box Team. | |
02-16-2018, 07:36 | #4 (permalink) | |
Member: 862014 Status: Offline Sonork: 100.1608307 Thanks Meter: 64 | Quote:
think for your answer . here is hw test Operation : HW Test [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 13 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 4500017045434148952301418720814C Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x70 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , AECAH [eMMC] : FLASH_CID : 7001004548414345410123954C817387 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000390000000 [eMMC] : FLASH_UCP : 14592 MiB [eMMC 16 GiB] DEV RID : 0x33EC6C62586716CC8826022B7913CC87 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Processing Miscellaneous test MSC : BatteryLevel : 3474 mV [Processing] FlashMemory Read-Write test [eMMC] : [KINGSTON] , AECAH , 0x390000000 , 14592 MiB [eMMC] : CID : 7001004548414345410123954C817387 [eMMC] : MODE : SQ-WR [FAILED : READONLY] : eMMC state seems as READ-ONLY !!!! Operation Failed Elapsed: 00:00:49 Reconnect Power/Cable! i notice failed on emmc state, now how do for repair it. any think i do all user data is there. think | |
02-18-2018, 06:49 | #5 (permalink) |
No Life Poster Join Date: Dec 2015 Location: Somewhere on the Internet
Member: 2500215 Status: Offline Thanks Meter: 417 | There is nothing you can do in software part. It is EMMC issue. Your hardware test tells it all Sent from my Redmi Note 4 using Tapatalk |
