08-02-2007, 12:02 | #1 (permalink) |
Cheater -Don't Deal with him- Join Date: Nov 2001 Location: IRAN Age: 49
Member: 7250 Status: Offline Sonork: 100.1575042 Thanks Meter: 440 | infinity need help urgent!!!!! 1-2 gnd 13-14 tx rx but not work . test on infinity- uni- usb cable ... need hlp |
08-02-2007, 17:36 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! for this phone we dont have records in our database. maybe some forum members can give some idea after you check with multimeter where is located GND and charging pins. Also, have you checked disassembled phone PCB? maybe tx, rx points are marked there? |
08-03-2007, 11:23 | #5 (permalink) | |
Freak Poster Join Date: Jan 2006 Location: I r a q
Member: 218192 Status: Offline Thanks Meter: 25 | Quote:
09-08-2007, 08:45 | #10 (permalink) |
No Life Poster Join Date: Sep 2005 Age: 59
Member: 185776 Status: Offline Thanks Meter: 73 | Action: read information Model: Autodetect: 6205-6227, 6228 Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6226, E02 Hardware version: M500Z_05C_HW Software version: E553_W1BPA.01.1_26S0 Software date: 2005.04.12 Barcode: MT012345678901234567 imei: 355263002062862 Finished, time used: 10 sec Power off phone now ! THis details below sim connecter= e553 V2.2 2007 05 31 Above details I read from phone.I cant formate this.Error msg coming.Any other idea |
09-10-2007, 12:15 | #12 (permalink) |
Member: 185776 Status: Offline Thanks Meter: 73 | Do you want to continue ? Acti=== log opened: [9/10/2007 11:52:38 AM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] v1.48 S/N: Wait... Current device: Autodetect: 6205-6227, 6228 Done COM7 [VCP0] selected Device: Autodetect: 6205-6227, 6228 Checking data, wait... advanced flash detection active Action: read/check detailed information Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6226:8A02:8A01]... high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 115200 Set baud Done Check space... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification, method #1... detection phase #1... detect device parameters finished structure: 2nd [enhanced] (or higher) generation New firmware detected: E553_W1BPA_E553_GPRS_MT6226_S01.01_1.BIN - make "Read detailed information, ask/rpl" operation - send "backup_system_log_..." file to support - make "Read full flash" operation - send flash backup file(s) to support - include in your e-mail full text from phone back label (phone name etc.) identification data Ok identification data backup saved: id.494C33BD.[E553_W1BPA_E553_GPRS_MT6226_S01.01_1.BIN_A14D3956].rpl identification detection finished device-id: 494C33BD protocol ver: 04 ver. sw1: E553_W1BPA_E553_GPRS_MT6226_S01.01_1.BIN ver. sw2: E553_W1BPA.01.1 ffs offset/size: 00800000/001FF000 detecting eeprom area in 1 chip(s)... flash: EC257E25082501:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom found near: 00E00000 detecting eeprom size... eeprom size: 00200000 eeprom chip: 00 eeprom area: 00000000:00E00000-00FFFFFF detection phase #3... .................................................. .............. done detecting structure pass 1... ................... detect standard fat location pass #1... .................................................. ...... detect extended fat location pass #1... .................................................. ..... detect standard fat offset pass #1... detect standard fat data... layout detection complete eeprom element #1 detected ok file saved: backup_system_log_494C33BD_E553_W1BPA_E553_GPRS_MT 6226_S01.01_1.BIN_A14D3956_20070910-115609.B0X.bin Finished, time used: 157 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make full flash backup before this procedure ! Do you want to continue ? Action: reset settings Model: Autodetect: 6205-6227, 6228 Checking data, wait... COM7 [VCP0] selected Phone should be Switched OFF ! Press and HOLD Power button now ! error: can't activate test moide Operation failed ! Finished, time used: 16 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make full flash backup before this procedure ! on: reset settings Model: Autodetect: 6205-6227, 6228 Checking data, wait... COM7 [VCP0] selected Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 Initializing[6226:8A02]... Connecting, wait... error: can't finalize test moide Operation failed ! Finished, time used: 22 sec Remove/Install battery now ! Any idea? |
09-11-2007, 00:59 | #13 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @cellbhai charge battery and make "complete" format and don't forget to send backup_system_log_494C33BD_E553_W1BPA_E553_GPRS_MT 6226_S01.01_1.BIN_A14D3956_20070910-115609.B0X.bin file to [email protected] |
09-20-2007, 05:29 | #14 (permalink) | |
Member: 185776 Status: Offline Thanks Meter: 73 | Quote:
Need Nktel K400 Frimware Infinity Team help urgent plz | blast.gsmhost | Infinity-Box | 7 | 03-12-2010 08:38 |
Infinity Box help urgent please | vaghubha_sodha | Infinity-Box | 2 | 12-02-2009 14:50 |
Hello Infinity-Box I need Help Urgent | ms_ahmed | Infinity-Box | 8 | 04-05-2009 11:53 |
need help urgent.infinity box! | sas-pc | Infinity-Box | 1 | 07-06-2008 23:03 |
Infinity Team Need Help Urgent | brain00000 | Infinity-Box | 1 | 10-07-2007 17:45 |
