Old 08-02-2007, 12:02   #1 (permalink)
Cheater -Don't Deal with him-
Member: 7250
Sonork: 100.1575042
Thanks Meter: 440
infinity need help urgent!!!!!
i have a china brand phone same pic below and i want to make cable for it. 18 pin cable and i made cable same as pinout given infinity:
1-2 gnd
13-14 tx rx
but not work . test on infinity- uni- usb cable ...
need hlp
Old 08-02-2007, 12:09   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
that means it has different pinout.
what is a name of this phone?
Old 08-02-2007, 14:54   #3 (permalink)
Member: 7250
Sonork: 100.1575042
Thanks Meter: 440
nec model L821 but there many phones with same software and hardware but different name in china!!!!
Old 08-02-2007, 17:36   #4 (permalink)
Member: 148515
hello!
for this phone we dont have records in our database.
maybe some forum members can give some idea after you check with multimeter where is located GND and charging pins. Also, have you checked disassembled phone PCB? maybe tx, rx points are marked there?
Old 08-03-2007, 11:23   #5 (permalink)
Member: 218192
Thanks Meter: 25
hello!
yes 90% of chines phones have tx, rx point marked in PCB ,sometimes under the battery and sometimes under the lable
Old 08-03-2007, 22:25   #6 (permalink)
Member: 161985
Thanks Meter: 59
4,5-vpp
10-tx
12-rx
17,18-gnd
try this
Old 08-08-2007, 07:02   #7 (permalink)
Member: 62016
Thanks Meter: 48
can any one pls upload reset code and hand code charging error code pls
Old 08-18-2007, 12:39   #8 (permalink)
Member: 366426
Thanks Meter: 4
reset code ( security code ) is 1122
Old 08-18-2007, 12:46   #9 (permalink)
Member: 366426
Thanks Meter: 4
l 821 is E553 that marked on PCB and GND-RX-TX is are marked on PCB right side of sim card connector
Old 09-08-2007, 08:45   #10 (permalink)
Member: 185776
Thanks Meter: 73
Action: read information
Model: Autodetect: 6205-6227, 6228
Checking data, wait...
Phone should be Switched ON !
Connecting, wait...
Phone detected, wait...
Hardware version: MT6226, E02
Hardware version: M500Z_05C_HW
Software version: E553_W1BPA.01.1_26S0
Software date: 2005.04.12
Barcode: MT012345678901234567
imei: 355263002062862
Finished, time used: 10 sec
Power off phone now !
THis details below sim connecter= e553 V2.2 2007 05 31 Above details I read from phone.I cant formate this.Error msg coming.Any other idea
Old 09-08-2007, 13:58   #11 (permalink)
Member: 348451
Thanks Meter: 2
i used the same anycool cable and it worked
try to use it
Old 09-10-2007, 12:15   #12 (permalink)
Member: 185776
Thanks Meter: 73
Do you want to continue ?
Acti=== log opened: [9/10/2007 11:52:38 AM] ====
Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e
Loading data, wait...
[Infinity Box] v1.48
S/N:
Wait...
Current device: Autodetect: 6205-6227, 6228
Done
COM7 [VCP0] selected
Device: Autodetect: 6205-6227, 6228
advanced flash detection active
Action: read/check detailed information
Boot...
baud autodetection active
19200
Connecting, wait...
Initializing[6226:8A02:8A01]...
high speed disabled
boot step size: 0002
Release Power button now !
Boot Done
Initialize...
flash: EC257E25082501:29EA0000000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
Initialize Done
Set baud...
115200
Set baud Done
Check space...
device parameters autodetection in progress..
total flash region size: 01000000
detect device identification, method #1...
detection phase #1...
detect device parameters finished
structure: 2nd [enhanced] (or higher) generation
New firmware detected: E553_W1BPA_E553_GPRS_MT6226_S01.01_1.BIN
- make "Read detailed information, ask/rpl" operation
- send "backup_system_log_..." file to support
- make "Read full flash" operation
- send flash backup file(s) to support
- include in your e-mail full text from phone back label (phone name etc.)
identification data Ok
identification data backup saved: id.494C33BD.[E553_W1BPA_E553_GPRS_MT6226_S01.01_1.BIN_A14D3956].rpl
identification detection finished
device-id: 494C33BD
protocol ver: 04
ver. sw1: E553_W1BPA_E553_GPRS_MT6226_S01.01_1.BIN
ver. sw2: E553_W1BPA.01.1
ffs offset/size: 00800000/001FF000
detecting eeprom area in 1 chip(s)...
checking area[00000000]: 00000000-00FFFFFF...
eeprom found near: 00E00000
detecting eeprom size...
eeprom size: 00200000
eeprom chip: 00
eeprom area: 00000000:00E00000-00FFFFFF
detection phase #3...
done
detecting structure pass 1...
detect standard fat location pass #1...
detect extended fat location pass #1...
detect standard fat offset pass #1...
detect standard fat data...
layout detection complete
eeprom element #1 detected ok
file saved: backup_system_log_494C33BD_E553_W1BPA_E553_GPRS_MT 6226_S01.01_1.BIN_A14D3956_20070910-115609.B0X.bin
Finished, time used: 157 sec
Remove/Install battery now !
WARNING ! Settings will be cleared, user data erased, Imei set to default value !
Make full flash backup before this procedure !
Action: reset settings
error: can't activate test moide
Operation failed !
Finished, time used: 16 sec
on: reset settings
19200
Initializing[6226:8A02]...
Connecting, wait...
error: can't finalize test moide
Operation failed !
Finished, time used: 22 sec
Any idea?
Old 09-11-2007, 00:59   #13 (permalink)
Member: 130995
Thanks Meter: 35,227
@cellbhai
charge battery and make "complete" format
and don't forget to send backup_system_log_494C33BD_E553_W1BPA_E553_GPRS_MT 6226_S01.01_1.BIN_A14D3956_20070910-115609.B0X.bin file to [email protected]
Old 09-20-2007, 05:29   #14 (permalink)
Member: 185776
Thanks Meter: 73
Originally Posted by InfinitySupport View Post
@cellbhai
Sorry sir.MY hand set is ok.sorry for late answer.I do complete formate.THanks again.
Old 09-22-2008, 15:26   #15 (permalink)
bhavesh123's Avatar
Member: 295852
Sonork: 100.1624073
Thanks Meter: 78
plz help me infinity i want this file E553_W1BPA_E553_GPRS_MT6226_S01.01_1.BIN
Need Nktel K400 Frimware Infinity Team help urgent plz blast.gsmhost Infinity-Box 7 03-12-2010 08:38
Infinity Box help urgent please vaghubha_sodha Infinity-Box 2 12-02-2009 14:50
Hello Infinity-Box I need Help Urgent ms_ahmed Infinity-Box 8 04-05-2009 11:53
need help urgent.infinity box! sas-pc Infinity-Box 1 07-06-2008 23:03
Infinity Team Need Help Urgent brain00000 Infinity-Box 1 10-07-2007 17:45
Page generated in 0.22446 seconds with 9 queries
