infinity ok but problem wirh pinfinder i just bought the two boxes and the installation for the infinity box is ok but it cannot detect the pinfinder if i try to activate the box with the infinity can some one please help me solve this problem for i am worried |
i think you will get your ans. |
fake pinfinder may i know fello brothers if there are fake pinfinder on the market i am asking this because i just bought my infinity box and the pinfinder the infinity box is ok but cannot detect the pinfinder if connected to the box i collected one from a frend and it connected fine but my own does not connect what might be the problem with it can you good one ple help me out :D:D:D |
Can you chek your infinity com port? Can you set same com port on pinfinder? Can you update your dongle? If all it's ok then your finder prob contact your reseller. |
@kingsley baafoe Try to change short RJ45-RJ45 box to PinFinder cable . Do you see PinFinder power led activity when you connect PinFinder to your box ? |
use dongle manager to update Select Pinfinder Update box Open Pinfinder sw Select com port where pinfinder is connected Click Detect select cable Detect Pin Power on when needed Somethings maybe not correct but this is all i remember :P |
one of the ic was not well fixed that have been done and now when i upgrade it can detect pinfinder but the new problem is when i open the software for the pin finder it says "dongle Locating server... Server#1 address found. Connecting to server#1... Server connection successfully established. S/N: xxxxxx, Firmware: 0111.02 Authenticating on server... Authentication successfull. Checking DongleManager version... Your DongleManager is up-to-date. Checking Dongle Identification... Dongle Identification checked. Activating module... Module-04 S/N: 000000000000000000000000000000 Module check error: Server reported error:[0044] Module S/N is already registered. Contact to [email protected] |
Locating server... Server#1 address found. Connecting to server#1... Server connection successfully established. S/N: xxxxxx, Firmware: 0111.02 Authenticating on server... Authentication successfull. Checking DongleManager version... Your DongleManager is up-to-date. Checking Dongle Identification... Dongle Identification checked. Activating module... Module-04 S/N: 000000000000000000000000000000 Module check error: Server reported error:[0044] Module S/N is already registered. |
Check if it start If not contact Infinity by mail only |
@kingsley baafoe I suggest you to contact to [email protected] and make very detailed explanation of problem. What was the problem. What you have tried to do. What is the results. VERY detiailed ! |
