Old 10-10-2008, 22:21   #1 (permalink)
Member: 193967
Thanks Meter: 26
infinity ok but problem wirh pinfinder
i just bought the two boxes and the installation for the infinity box is ok but it cannot detect the pinfinder if i try to activate the box with the infinity
can some one please help me solve this problem for i am worried
Old 10-10-2008, 22:30   #2 (permalink)
Member: 771937
Sonork: 100.1605717
Thanks Meter: 1,051
see carefully :- x:\Program Files\InfinityBox\Documentation\PinFinder
i think you will get your ans.
Old 10-10-2008, 22:32   #3 (permalink)
Member: 193967
Thanks Meter: 26
fake pinfinder
may i know fello brothers if there are fake pinfinder on the market
i am asking this because i just bought my infinity box and the pinfinder the infinity box is ok but cannot detect the pinfinder if connected to the box
i collected one from a frend and it connected fine but my own does not connect what might be the problem with it can you good one ple help me out
Old 10-10-2008, 22:37   #4 (permalink)
Member: 771937
Sonork: 100.1605717
Thanks Meter: 1,051
Can you chek your infinity com port? Can you set same com port on pinfinder? Can you update your dongle? If all it's ok then your finder prob contact your reseller.
Old 10-10-2008, 22:38   #5 (permalink)
Member: 105817
Thanks Meter: 129
i collected one from a frend and it connected fine but my own does not connect what might be the problem with it can you good one ple help me out :d:d:d
use dongle menager activate pin finder
Old 10-10-2008, 22:41   #6 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,071
@kingsley baafoe
Try to change short RJ45-RJ45 box to PinFinder cable .
Do you see PinFinder power led activity when you connect PinFinder to your box ?
Old 10-10-2008, 22:43   #7 (permalink)
Member: 732994
Thanks Meter: 80
use dongle manager to update
Select Pinfinder
Update box
Open Pinfinder sw
Select com port where pinfinder is connected
Click Detect
select cable
Detect Pin
Power on when needed
Somethings maybe not correct but this is all i remember :P
Old 10-11-2008, 14:27   #8 (permalink)
Member: 193967
Thanks Meter: 26
Originally Posted by InfinitySupport View Post
@kingsley baafoe
it was a hard ware problem
one of the ic was not well fixed that have been done and now when i upgrade it can detect pinfinder but the new problem is when i open the software for the pin finder it says "dongle
Locating server...
Server#1 address found.
Connecting to server#1...
Server connection successfully established.
S/N: xxxxxx, Firmware: 0111.02
Authenticating on server...
Authentication successfull.
Checking DongleManager version...
Your DongleManager is up-to-date.
Checking Dongle Identification...
Dongle Identification checked.
Activating module...
Module-04 S/N: 000000000000000000000000000000
Module check error: Server reported error:[0044] Module S/N is already registered. Contact to [email protected]
Old 10-11-2008, 15:13   #9 (permalink)
Member: 193967
Thanks Meter: 26
@kingsley baafoe
it was a hardware problem that have been solved and this is the log i get if i try to activate the box
Locating server...
Old 10-11-2008, 15:39   #10 (permalink)
Member: 732994
Thanks Meter: 80
Check if it start
If not contact Infinity by mail only
Old 10-11-2008, 19:11   #11 (permalink)
Member: 130995
@kingsley baafoe
I suggest you to contact to [email protected] and make very detailed explanation of problem.
What was the problem.
What you have tried to do.
What is the results.
VERY detiailed !
w200i unlock ok but problem geepee777 DreamBox 8 10-16-2008 14:52
Chinsees Skyworks CPU ok But problem with Flash IC .::BHATTI::. Infinity-Box 1 07-09-2008 09:36
KG195 Flash With Infinity ok but? Kanwalgee Infinity-Box 4 05-25-2008 15:13
i have problem mybe any wan can solved it if i open any soft for infinity ok but if i gsm4libya Infinity-Box 2 05-01-2006 12:56
Page generated in 0.37571 seconds with 8 queries
