Infinity Online Service (IOS) Could not load SSL library Hi, when I type my password and username to access my account or send a SHA file on Infinity Online Service (IOS) I can not connect and I get this message Could not load SSL library how to solve this problem? |
Could you please post here screenshot. |
I had this problem today. First time I tried to use iosJobUploader v1.0.0.28 it could not check account because of Windows error with message "Not possible to initiate program because MSVCR120.DLL is missing". I have VCRedist installed already, so I copied this dll file to iosJobUploader folder, after that the Windows error no longer occured but the log from software was this: 24-03-2017: 18:39:11: Operation: Check Account 24-03-2017: 18:39:11: Connecting to server... 24-03-2017: 18:39:12: Message: Could not load SSL library. 24-03-2017: 18:39:12: Operation terminated I tried to use previous version iosJobUploader.1.0.0.27 and it worked, so I checked .ini file to see the differences and found out that url in server settings is different, v1.0.0.27 has "url=http://service.infinity-box.com/api/" and v1.0.0.28 has "url=https://service.infinity-box.com/api/", so after editing this problem is solved. |
same problem here windows 10 64bit even changing https to http :confused: https://cdn.pbrd.co/images/HWRd3zK.png |
then run software result ? |
17-1-2019: 5:56:01 PM: Connecting to server... 17-1-2019: 5:56:01 PM: Message: Could not load SSL library. 17-1-2019: 5:56:01 PM: Operation terminated |
Do you have libssl32.dll and ssleay32.dll and libeay32.dll files in folder with software ? |
delete libssl32.dll and ssleay32.dll and libeay32.dll files from software folder Install latest OpenSSL libraries Win32/Win64 OpenSSL Installer for Windows - Shining Light Productions http://slproweb.com/download/Win32OpenSSL-1_1_0j.exe or http://slproweb.com/download/Win64OpenSSL-1_1_0j.exe Restart PC after install. Install x32 version first, even if your OS is 64 bits. |
still same problem 18-1-2019: 11:43:06 AM: Operation: Check Account 18-1-2019: 11:43:06 AM: Connecting to server... 18-1-2019: 11:43:06 AM: Message: Could not load SSL library. 18-1-2019: 11:43:06 AM: Operation terminated |
problem solved after copy those files in iosJobUploader folder https://indy.fulgan.com/SSL/openssl-...i386-win32.zip |
thanks for sharing us the sollution |
