Old 09-08-2015, 22:25   #1 (permalink)
Member: 2246096
Infinity Online Service (IOS) Could not load SSL library
Hi, when I type my password and username to access my account or send a SHA file on Infinity Online Service (IOS) I can not connect and I get this message Could not load SSL library
how to solve this problem?
Old 09-08-2015, 23:41   #2 (permalink)
Member: 1043909
Thanks Meter: 51,298
Hello,
Could you please post here screenshot.
Old 03-24-2017, 20:46   #3 (permalink)
Member: 6358
Thanks Meter: 10
I had this problem today.
First time I tried to use iosJobUploader v1.0.0.28 it could not check account because of Windows error with message "Not possible to initiate program because MSVCR120.DLL is missing". I have VCRedist installed already, so I copied this dll file to iosJobUploader folder, after that the Windows error no longer occured but the log from software was this:
24-03-2017: 18:39:11: Operation: Check Account
24-03-2017: 18:39:11: Connecting to server...
24-03-2017: 18:39:12: Message: Could not load SSL library.
24-03-2017: 18:39:12: Operation terminated
I tried to use previous version iosJobUploader.1.0.0.27 and it worked, so I checked .ini file to see the differences and found out that url in server settings is different, v1.0.0.27 has "url=http://service.infinity-box.com/api/" and v1.0.0.28 has "url=https://service.infinity-box.com/api/", so after editing this problem is solved.
Old 01-17-2019, 12:52   #4 (permalink)
Member: 2501288
Thanks Meter: 248
same problem here windows 10 64bit even changing https to http
Old 01-17-2019, 16:06   #5 (permalink)
Member: 1043909
Please return back https://
then run software
result ?
Old 01-17-2019, 17:56   #6 (permalink)
Member: 2501288
Thanks Meter: 248
then run software
result ?
17-1-2019: 5:56:01 PM: Operation: Check Account
17-1-2019: 5:56:01 PM: Connecting to server...
17-1-2019: 5:56:01 PM: Message: Could not load SSL library.
17-1-2019: 5:56:01 PM: Operation terminated
Old 01-17-2019, 19:34   #7 (permalink)
Member: 1043909
Do you have libssl32.dll and ssleay32.dll and libeay32.dll files in folder with software ?
Old 01-17-2019, 19:40   #8 (permalink)
Member: 2501288
Thanks Meter: 248
Yes .......
Old 01-17-2019, 22:48   #9 (permalink)
Member: 1043909
delete libssl32.dll and ssleay32.dll and libeay32.dll files from software folder
Install latest OpenSSL libraries Win32/Win64 OpenSSL Installer for Windows - Shining Light Productions
http://slproweb.com/download/Win32OpenSSL-1_1_0j.exe
or
http://slproweb.com/download/Win64OpenSSL-1_1_0j.exe
Restart PC after install.
Install x32 version first, even if your OS is 64 bits.
The Following User Says Thank You to YellowBoss For This Useful Post:
Old 01-18-2019, 11:43   #10 (permalink)
Member: 2501288
Thanks Meter: 248
or
still same problem
18-1-2019: 11:43:06 AM: Operation: Check Account
18-1-2019: 11:43:06 AM: Connecting to server...
18-1-2019: 11:43:06 AM: Message: Could not load SSL library.
18-1-2019: 11:43:06 AM: Operation terminated
Old 01-18-2019, 11:58   #11 (permalink)
Member: 2501288
Thanks Meter: 248
problem solved after copy those files in iosJobUploader folder
https://indy.fulgan.com/SSL/openssl-...i386-win32.zip
The Following User Says Thank You to Steve-1 For This Useful Post:
Old 01-26-2019, 22:58   #12 (permalink)
Member: 2812901
Thanks Meter: 373
thanks for sharing us the sollution
Page generated in 0.34240 seconds with 7 queries
