10-14-2010, 11:26 | #1 (permalink) |
Junior Member Join Date: Feb 2008 Location: Ghana Tarkwa
Member: 713562 Status: Offline Thanks Meter: 4 | Infinity pin finder promble searching adapter at COM70... can't open COM70 can't find adapter searching adapter at COM113... too many retries can't find adapter searching adapter at COM114... too many retries can't find adapter searching adapter at COM2... too many retries can't find adapter searching adapter at COM1... too many retries can't find adapter searching adapter at COM9... too many retries can't find adapter searching adapter at COM69... too many retries can't find adapter searching adapter at COM70... can't open COM70 can't find adapter can't open COM70 done PLAESE HELP HELP for i'm |
The Following User Says Thank You to akotia For This Useful Post: |
01-23-2011, 22:06 | #3 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello guys! you must start from user manual. check if you connect link cable to correct port. also please note, that link cable must be from infinity package. it is special mirrored cable, pinout is available in user manual. check it with multimeter if all wires is ok |
01-29-2011, 10:10 | #4 (permalink) |
Insane Poster Join Date: Jan 2010 Location: PARIS
Member: 1216581 Status: Offline Sonork: btcoolmi Thanks Meter: 3 | hello peoples. i have the big problem with pin finder infinity box i have since time ago but i can not unlock or flash chiness phone if some one use correctly this person can help me what i can use. i have box infinity combo plus and all pin finder. thanks gsm people. |
01-29-2011, 11:46 | #5 (permalink) | |
No Life Poster Join Date: Aug 2007 Location: Under Blue
Member: 569925 Status: Offline Sonork: 100.1624057 Thanks Meter: 6,313 | Quote:
01-30-2011, 20:51 | #6 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
first of all make sure that your phone has MT62xx CPU type. second: find suitable cable with correct number of pins. third: run pinfinder, select cable type, connect cable and power lines. press "power On" and check if phone can be powered On. after that run pinout search. what result you get? | |
Handy Finder | mody | GSM Mobile Links | 0 | 08-15-2001 20:13 |
Nokia 1610 from E Plus pin info needed | talenat | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-16-2000 02:56 |
How to use Nokia tool - with connection 6-7 pin or not?.. | 2M | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 07-20-2000 19:53 |
PIC for lock 2 What pin for clock ??? | ondenuove | Nokia Hardware & Hardware Repair | 5 | 10-28-1999 08:49 |
