06-11-2008, 07:48 | #1 (permalink) |
Junior Member Join Date: Apr 2006
Member: 255468 Status: Offline Thanks Meter: 3 | Infinity PinFinder not work i have one pin finder And it dosent work on any phone it is log from my pin finder operation Code: software version: 1.10 cable type: 1x14 DKU-2 (L14F) platform: MT62xx (autodetect) searching adapter at COM11... adapter found, version: 2000 pins: 14, plain power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... failed to detect pins time required: 86 sec Power Off ! whan can i do for it |
06-11-2008, 08:59 | #2 (permalink) |
No Life Poster Join Date: May 2008 Location: COME & MADE GREEN WORLD
Member: 771937 Status: Offline Sonork: 100.1605717 Thanks Meter: 1,052 | problem is sockeat or hardware, this is right solution-User manual with pictures and detailed step-by-step instructionhttp://www.infinity-box.biz/download/public/Infinity-Box_PinFinder.pdf |
The Following 2 Users Say Thank You to debmobile For This Useful Post: |
06-11-2008, 13:20 | #7 (permalink) |
No Life Poster Join Date: May 2007 Location: uk
Member: 508072 Status: Offline Thanks Meter: 1,621 | cheq in put in your pin finder as shown in user manule if voltage is less then 5volts or less then 4.93 then short diod in yor box and then post result best of luck |
06-11-2008, 13:24 | #8 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Burundi Bujumbura
Member: 750759 Status: Offline Sonork: 75101010 Thanks Meter: 169 | Pin finder cable schematic Hi! Can you help me with schematic of cable of power for infinity pin finder. RJ45 to RJ45. My box cames without that cable so i can't connect it with my infinity box. |
pinfinder not working | king_khan | Infinity-Box | 4 | 11-27-2008 19:28 |
pinfinder not working | sureshplaza | Infinity-Box | 1 | 09-30-2008 12:33 |
pinfinder not working | kabajilee | Infinity-Box | 3 | 08-13-2008 18:56 |
pinfinder not working | shooib | SpiderMan | 3 | 07-05-2008 07:02 |
