06-11-2016, 12:29 | #1 (permalink) |
Registered User Join Date: Mar 2008 Location: @ blacksheep digital
Member: 731353 Status: Offline Thanks Meter: 254 | infinity please help if a try to repair using infinity software will say repair done but still imei invalid HERE IS THE LOG..1ST I READ FULLY INFO BEFORE FLASH THEN REPAIR IMEI BUT STILL INVALID..SAME RESULTS ON 6 PHONES..i even try imei change..other mtk ok just this model Card found : S/N : 6EF5F8E0 , v0130 Chinese Miracle II [MTK module] v 1.49 Operation : Check / Read Info [ v1.49 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 73 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473261110105871D027297 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , a2G4 [eMMC] : FLASH_CID : 90014A4834473261110105871D027297 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xE34DFB12F203B88D2F1E992A2B3E9921 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : AG ProdName : AG_Chacer ProdModel : Chacer Device : Chacer AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.KK1.MP7.V1.7 SECURITY : IMEI_SW [1] : 353393072392741 IMEI_SW [2] : 353393072427745 BTMAC Addr : F2174665729E WiFi MAC : 74BADB36DD6F MODEM : BaseBand : MT6572_S00_MOLY_WR8_W1315_MD_WG_MP_V47_P16_1_wg_n EXTRA : LCD [0] : ili9488_hvga_dsi_cmd LCD Res : 480x320 TOUCH [0] : ft5206 TOUCH [1] : msg2133 CAM [0] : gc2155_yuv CAM [1] : gc0328_yuv CAM [2] : gc2145_yuv CAM [3] : gc0311_yuv CAM [4] : gc0312_yuv MODEM : S3525_AG_New_NoEdge_B18_Switch_UnLock LOCALE : en_US es_ES zh_CN zh_TW ru_RU pt_BR fr_FR de_DE tr_TR it_IT in_ID ms_MY vi_VN ar_EG th_TH pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ iw_IL my_MM km_KH ko_KR mdpi -sw600dp -sw720dp pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB Done! Elapsed: 00:00:16 Reconnect Power/Cable! log 2 Card found : S/N : 6EF5F8E0 , v0130 Chinese Miracle II [MTK module] v 1.49 Operation : Repair Security [ v1.49 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473261110105871D027297 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , a2G4 [eMMC] : FLASH_CID : 90014A4834473261110105871D027297 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xE34DFB12F203B88D2F1E992A2B3E9921 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! IMEI [00] : 353393072392741 IMEI [01] : 353393072427745 Set IMEI [00] : 345445434556552 Set IMEI [01] : 334345435667676 Prepare finished. Security check required! Wait for phone... Phone found! [ 5 ] Sync... Repair done! Done! Elapsed: 00:00:59 Reconnect Power/Cable! |
06-11-2016, 14:39 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | And seems as you read it once, and think, it is Ok? Find another one WORKING phone, read FW and use it. Also make NVRAM backup and restore it to faulty ones. |
06-11-2016, 17:45 | #4 (permalink) |
Member: 731353 Status: Offline Thanks Meter: 254 | Card found : S/N : xxxxxx Chinese Miracle II [MTK module] v 1.49 Operation : Check / Read Info [ v1.49 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473261110105871D027297 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , a2G4 [eMMC] : FLASH_CID : 90014A4834473261110105871D027297 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xE34DFB12F203B88D2F1E992A2B3E9921 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : AG ProdName : AG_Chacer ProdModel : Chacer Device : Chacer AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.KK1.MP7.V1.7 SECURITY : IMEI_SW [1] : 345445434556552 IMEI_SW [2] : 334345435667676 BTMAC Addr : F2174665729E WiFi MAC : 74BADB36DD6F MODEM : BaseBand : MT6572_S00_MOLY_WR8_W1315_MD_WG_MP_V47_P11_1_wg_n EXTRA : LCD [0] : ili9488_hvga_dsi_cmd LCD Res : 480x320 TOUCH [0] : ft5206 CAM [0] : gc2155_yuv CAM [1] : gc0328_yuv CAM [2] : gc2145_yuv CAM [3] : gc0311_yuv CAM [4] : gc0312_yuv MODEM : S3525_AG_NoEdge_B18_Switch_UnLock LOCALE : en_US es_ES zh_CN zh_TW ru_RU pt_BR fr_FR de_DE tr_TR it_IT in_ID ms_MY vi_VN ar_EG th_TH pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ iw_IL my_MM km_KH ko_KR mdpi -sw600dp -sw720dp pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB Done! Elapsed: 00:00:16 Reconnect Power/Cable! Operation : Write NVRAM [ v1.49 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473261110105871D027297 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , a2G4 [eMMC] : FLASH_CID : 90014A4834473261110105871D027297 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xE34DFB12F203B88D2F1E992A2B3E9921 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [NVCheck] : BBID : MT6572 , NVID : MT6572 [NVM] : Write Ok! [Info] : NVRAM Repair on erased/damaged phone : 1. Fix Unknown BaseBand 2. Power On phone, check BB state 3. Write NVRAM 4. Repair Security Done! Elapsed: 00:00:27 Reconnect Power/Cable! thanks nvram repair done..still imei invalid and uknown baseband...if i read full info after write imei it will read new imei...but on phone *#06# =INVALID IMEI and unknown baseband last question is it possible to read and write full dump from a working phone beacuse all along was using factory firmware only {scatter file } not full bin Last edited by bigjef1; 06-11-2016 at 17:51. |
