11-09-2009, 10:25 | #1 (permalink) |
Freak Poster Join Date: Aug 2006
Member: 340551 Status: Offline Thanks Meter: 9 | 5800 Read Fullflash help.. Phone Start up with sims auto off... Ok with offline mode... Try to backup firmware before do anything but result: COM62 [VCP5] selected module v2.84 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read NOR flash Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot Off chip: 0001:1B03:0001 status: FF high speed boot Off boot packet size: 0400 error: bootcode load error: FFFFEAFF0000E10F10C0E3A00001E180F000E12F1010E59F10 04E241D00CE59F0003EB000857EB00FFFDEAFF140040006000 40004030E92DD01CE24D0032EA005480E3A03318E59F0008EA 00C0B8E1D5E0B0E1D54004E593ECFFE20E000CE154C0080593 000E015C00030A00301CE283C000E5D3000CE35CFFF31AFF00 08E3503018E58D3018159D300C159301801793000803A00004 E58D0008E3510018159D000C1590018117901980E3A0000803 A00008E58D0008E3520018159D000C1590018217902C80E3A0 000803A0000CE58D0440E3A00010E58D0004E59D2A80E3A016 80E3A00014E58D0010E59D0000E3500014159D000013500000 00000030A01004E28D0001E3A0D01CE28D8030E8BD00010000 1501003100440101A0110101000000000301A0410101000031 000040002A504000460000004000252A280011000800004000 252A2800200000111210000905040012000800004000252A28 004A00001112100009050400120000004000252A2800190031 004440002A5040002500080011121000090504000200001112 10000905040000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFF000000000000800100000800 00088001000010000010800100001800001880010000000000 0100000001FEFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF00000000 00008001000008000008800100001000001080010000180000 18000100000000020002080000FFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF15144000105C E59F005CE59F15B0E1C01058E59F15B4E1C0FFFEEAFFFF1EE1 2FFF1EE12F0288E3A000B0E1D0FF1EE12F0480E3A000B0E1D0 FF1EE12F0480E3A000B0E1D000FFE200FF1EE12F0480E3A000 B0E1D00CFFE200FF1EE12F0010E59F0000E590FF1EE12F1234 00000000802156780000000040004038E92DD068E24D0B9CEB 003000E1A02088E59F0B8BEB000080E59F100DE1A02010E3 Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 16 sec Remove/Install battery now ! Can help? Did i set something wrong? BR Oki |
11-09-2009, 21:06 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,531 | hello! ussually communication brakes like this when you have bad connection of connector can you clean phone connector and try again, few times in a row? |
11-10-2009, 06:21 | #3 (permalink) |
Member: 340551 Status: Offline Thanks Meter: 9 | Hey Thanks for the reply.. I follow http://forum.gsmhosting.com/vbb/show...highlight=5800 pinout... Its solder to the board.. so unable to clean it... My cable were able to flash few china n95.. Any clue? Again thanks for helping... |
11-10-2009, 15:10 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,531 | hello! ok, you using my pinout. did you take GND from same place, as me? does your phone is powered via box or you use batery do you release power button only after program says so? |
11-23-2009, 14:09 | #5 (permalink) |
Member: 340551 Status: Offline Thanks Meter: 9 | Sorry for the late reply.. i was on vacation... I didnt use any batt or power supply... Do i have to? And i also holding or without holding the power till the end... i attach a pic where i solder... Thanks for helping.. BR Oki |
11-24-2009, 07:03 | #7 (permalink) |
Member: 340551 Status: Offline Thanks Meter: 9 | Its Works... Thanks man.. But now others problem... Log: COM16 [VCP0] selected module v3.00 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read NOR flash ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:1B03:0001 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 09FA09FA09FA09:00000000000000 flash: F9FAF9FAF9FAF9:F000F000000000 number of flash chip/regions detected: 00/01 flash chip is unknown or damaged, operation aborted. Fault reasons: 1. flash chip is damaged: replace or resolder/reball flash chip 2. hardware is damaged: check hardware, water inside etc. 3. unknown hardware: set "Advanced chip detection method" box [un-checked] and try again 4. wrong model selection, try 'NAND' selection Initialize Fail Finished, time used: 358 sec Remove/Install battery now ! Sorry to trouble u... BR Oki |
11-24-2009, 19:44 | #8 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,531 | hello! repeat few more times. if you always get this error- looks like you have bad soldering of Flash IC. resolder it if you have skills, if not- just heat it check phone after that, probably you will not need to do any other operations. if it still reboots- format FFS it |
can anybody help me read fullflash and eeprom from normal d600e | freakyass | UST Pro II | 2 | 03-16-2007 06:34 |
Read fullflash from Z150 ?? | Insight | UST Pro II | 0 | 11-09-2006 13:50 |
absolute newbee question: how to read fullflash from phone to file? | rostfrei | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 07-01-2006 22:00 |
is it possible read fullflash from 8120 and write to another 8120? | VIZER | Cruiser Suite | 1 | 06-28-2005 17:14 |
How to read fullflash? | MOBICOM | UFS2 + UFS3-Tornadoflasher | 1 | 08-29-2004 01:55 |
