Old 09-17-2008, 15:17   #1 (permalink)
robin25's Avatar
Member: 771565
Sonork: 100.1656305
Thanks Meter: 145
Exclamation infinity plz help me
COM3 [VCP0] selected
Action: reset settings
Model: Autodetect 6205-6227 NOR
Checking data, wait...
19200 autodetect
Initializing[6226:8A02:8A01]...
CPU: MT6226
high speed boot disabled
chip: 0031:CD41:0124
Connecting, wait...
error: can't finalize test mode
repeat operation and HOLD phone "Power" button long time !
error: operation failed !
Finished, time used: 99 sec
Remove/Install battery now !
what's wrong plz tell me
Old 09-17-2008, 15:23   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
1. repeat operation and HOLD phone \"Power\" button long time !
2. Did you tried to make \"complete\" format instead of \"safe\" ?
Old 09-17-2008, 15:33   #3 (permalink)
robin25's Avatar
Member: 771565
Sonork: 100.1656305
Thanks Meter: 145
Exclamation
in complete formate mode
Device: Autodetect 6205-6227 NOR
eeprom backup enabled, it may takes several minutes !
Action: "format ffs"
Boot...
baud autodetection active
19200 autodetect
Connecting, wait...
CPU: MT6226
high speed disabled
boot step size: 0002
Release Power button now !
Boot Done
Initialize...
flash: BBEA90E098E19B:BBFA9000000000
number of flash chip/regions detected: 00/01
Unknown or damaged flash chip, operation aborted.
Fault reasons:
1. damaged flash chip: replace or resolder/reball flash chip
2. damaged hardware: check hardware, water inside etc.
3. unknown hardware: set "Advanced chip detection method" box [un-checked] and try again
4. wrong model selection, try 'NAND' selection
Initialize Fail
Finished, time used: 111 sec
Old 09-17-2008, 15:35   #4 (permalink)
robin25's Avatar
Member: 771565
Sonork: 100.1656305
Thanks Meter: 145
Exclamation
Boot...
19200 autodetect
Connecting, wait...
CPU: MT6226
high speed disabled
Boot Done
Initialize...
Fault reasons:
Initialize Fail
ever things ok in hardware
Old 09-17-2008, 16:29   #5 (permalink)
Registered User
Member: 437195
Thanks Meter: 1,734
brother flash chip damage check and change.
re flash phone .
Old 09-17-2008, 17:27   #6 (permalink)
Member: 130995
@robin25
flash chip is damaged or bad soldered.
Old 11-24-2009, 08:01   #7 (permalink)
Member: 1091455
Sonork: qq 2250871952
Thanks Meter: 769
help me
COM5 [VCP0] selected
module v3.00
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A03:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:8B03:000E
status: FF
boot packet size: 0400
Boot Done
====> Initialize ...
flash: 90009000900090:90909000000000
flash chip is unknown or damaged, operation aborted.
Fault reasons:
1. flash chip is damaged: replace or resolder/reball flash chip
2. hardware is damaged: check hardware, water inside etc.
Initialize Fail
Finished, time used: 16 sec
Old 11-24-2009, 19:46   #8 (permalink)
Member: 148515
Thanks Meter: 19,534
module v3.00
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
status: FF
Boot Done
Fault reasons:
Initialize Fail
hello!
is this full working phone or have some fault?
if it is faulty- what symptoms?
plz help me lloydgsm FuriousGold 3 03-29-2010 20:08
plz help me its urgent lloydgsm SETool2 2 03-29-2010 17:45
plz help me lloydgsm SETool2 6 03-29-2010 13:10
Great infinity plz help me double sim DEAD urromeo Infinity-Box 1 07-06-2008 04:57
infinity plz help me david laborator Infinity-Box 4 05-19-2007 12:11
Page generated in 0.26238 seconds with 10 queries
