10-13-2017, 06:19 | #91 (permalink) |
No Life Poster Join Date: May 2008
Member: 770503 Status: Offline Thanks Meter: 1,215 | SM-J500FN FRP Done..!! Code: Phone In Download mode... Reset FRP Procedure started... Port open Ok! LOKE received! Prepare Ok! Enter Setup... Try download PIT... Download PIT Ok! Reset FRP done Reboot phone... Code: Model : SM-J500FN Name : j5nltexx version : 5.1.1 Build : J500FNXXU1AOI6 Imei : Platform : msm8916 |
10-13-2017, 07:38 | #93 (permalink) |
Insane Poster Join Date: Apr 2014 Location: Mansehra shinkiari
Member: 2169026 Status: Offline Sonork: 100.1652002 Thanks Meter: 24 | samsung s6 g920p frp done with 1 click Phone In Download mode... Reset FRP Procedure started... Port open Ok! LOKE received! Prepare Ok! Enter Setup... Try download PIT... Download PIT Ok! Reset FRP done Reboot phone... |
10-13-2017, 07:44 | #94 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Reseller not require, just click below link http://forum.gsmhosting.com/vbb/f296...orial-2251948/ |
The Following User Says Thank You to Yusuf Lawal For This Useful Post: |
10-13-2017, 09:23 | #95 (permalink) |
No Life Poster Join Date: Mar 2016 Location: Ukraine
Member: 2550141 Status: Offline Thanks Meter: 1,115 | SM-G900H Error flashing, Odin Done Infinity SM Code: Phone found on COM18 Phone In Download mode... Port open Ok! LOKE received! Prepare Ok! Enter Setup... Setup Done! Re-Partition enabled Uploading Pit File Start Flashing PIT Prepare PIT Flashing... Flashing PIT done Try download PIT... Download PIT Ok! Start flashing! Flashing sboot.bin Flashing param.bin Flashing boot.img Flashing recovery.img Flashing system.img Flashing userdata.img Error flashing Code: <ID:0/018> Added!! <ID:0/018> Odin engine v(ID:3.1207).. <ID:0/018> File analysis.. <ID:0/018> SetupConnection.. <ID:0/018> Initialzation.. <ID:0/018> Set PIT file.. <ID:0/018> DO NOT TURN OFF TARGET!! <ID:0/018> Get PIT for mapping.. <ID:0/018> Firmware update start.. <ID:0/018> NAND Write Start!! <ID:0/018> SingleDownload. <ID:0/018> sboot.bin <ID:0/018> param.bin <ID:0/018> boot.img <ID:0/018> recovery.img <ID:0/018> system.img <ID:0/018> userdata.img <ID:0/018> modem.bin <ID:0/018> Transmission Complete.. <ID:0/018> Now Writing.. Please wait about 2 minutes <ID:0/018> Receive Response from boot-loader <ID:0/018> cache.img <ID:0/018> hidden.img <ID:0/018> RQT_CLOSE !! <ID:0/018> RES OK !! <ID:0/018> Removed!! <ID:0/018> Remain Port .... 0 <OSM> All threads completed. (succeed 1 / failed 0) |
10-13-2017, 10:45 | #96 (permalink) | |
Insane Poster Join Date: Sep 2014 Location: Java
Member: 2256941 Status: Offline Thanks Meter: 18 | J510FN AP 2 - FRP remove in Download mode done! Quote:
The Following User Says Thank You to R00f For This Useful Post: |
10-15-2017, 10:25 | #97 (permalink) |
Freak Poster Join Date: Sep 2014 Location: islamabad pakistan Age: 39
Member: 2266425 Status: Offline Thanks Meter: 58 | this info was from lg ls996 error on read firmware 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD VOLUME UP KEY! 3. Insert USB cable, wait until Download mode screen will appear Wait for phone... Connection opened successfully! Waiting for loader ... Handshake passed! Collect info... Prepare passed, mode 0x00 Boot done! DevInfo : MSM8994__LGLS996__LS996ZVB__ZVB__AOSv5.1.1__LS996Z VB_00 Reading Flash Content ... [Read Ok] : gpt_main.bin [Read Ok] : NON-HLOS.bin [Read Ok] : pmic.bin [Read Ok] : sbl1.mbn [Read Ok] : tz.mbn [Read Ok] : deploy.mbn [Read Ok] : hyp.mbn [Read Ok] : rpm.mbn [Read Ok] : emmc_appsboot.mbn [Read Ok] : misc.img [Read Ok] : persist.img [Read Ok] : ddr.bin [Read Ok] : sec.dat [Read Ok] : laf.img [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : persist_lg.img [Read Ok] : calibration.img [Read Ok] : carrier.img [Read Ok] : fact.img [Read Ok] : rawdata.img Error : Failed to read data! Connection or power problem! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Error : Firmware NOT selected! Nothing to do! |
10-15-2017, 10:28 | #98 (permalink) |
Member: 2266425 Status: Offline Thanks Meter: 58 | i have another dead phone same model ls996 dead after downgrade and i can create backup from working phone bu there are erro on firmware read any solution infinty suport team ,,thnk in advance.. |
10-15-2017, 10:53 | #99 (permalink) |
Freak Poster Join Date: Feb 2012 Location: berhampur (odisha) Age: 48
Member: 1723300 Status: Offline Sonork: 100.1626921 Thanks Meter: 12 | samsung on5 frp done Phone In Download mode... Reset FRP Procedure started... Port open Ok! LOKE received! Prepare Ok! Enter Setup... Try download PIT... Download PIT Ok! Reset FRP done Reboot phone... Phone Disconnected Phone found on COM37 Read Info... Modem Busy Now... Read Info Canceled Phone Disconnected Phone found on COM37 Read Info... Read Info - ok |
10-16-2017, 07:27 | #101 (permalink) | |
Junior Member Join Date: Aug 2016
Member: 2615304 Status: Offline Sonork: zee Thanks Meter: 10 | CM2 We neeed MTK update we need mTK update >>>> Quote:
10-16-2017, 17:08 | #103 (permalink) | ||
No Life Poster Join Date: Jun 2006
Member: 303419 Status: Offline Sonork: Fes Thanks Meter: 209 | Quote:
http://forum.gsmhosting.com/vbb/12726387-post21.html | ||
