Old 07-06-2018, 07:41   #196 (permalink)
Member: 1232130
Thanks Meter: 12
activation SM is possible for bb5 best dongle ????
Old 07-06-2018, 07:54   #197 (permalink)
maremestera's Avatar
Member: 691388
Thanks Meter: 371
yes you can activate on Best
Old 07-06-2018, 08:10   #198 (permalink)
Member: 1372118
Thanks Meter: 139
yes you can
activations to best
Old 07-06-2018, 12:04   #199 (permalink)
Member: 2612469
=== DongleManager [Infinity] v1.72 [06/07/2018 17:56:28] ===
Searching...
Card-Reader: Alcor Micro USB Smart Card Reader 0
HWID: 00007B5813114082
Box/Dongle found: Infinity-Box/Dongle
Reading...
Serial No (S/N): 76757B58
Firmware version: 0136.02
=== Process started: 06/07/2018 17:56:29 ===
Connecting to server...
Server connection successfully established
Checking upgrade client version...
Your upgrade client is up-to-date
Checking Box/Dongle Identification...
Authenticating on server...
Authentication stage error:
Server reported error: [0007] Not translated!
Old 07-06-2018, 12:06   #200 (permalink)
Member: 1556436
Thanks Meter: 66
Originally Posted by samuelsteve View Post
Hi there, i have this docomo s8 aka SC-02J that is hardlocked because of wrong codes by Z3X box remote service, i know that with the right unfreeze code and network unlock code my SC-02J can be unlock, the question is can Infinity service find the right codes? thanks.
Support u don't have anything to say about this?
Sent from my iPhone using Tapatalk
Old 07-06-2018, 17:07   #201 (permalink)
Member: 2676976
Sonork: SDSDA
2FA52AE2
pleas active sm tool 2.0 this serial number
Old 07-06-2018, 18:20   #202 (permalink)
Member: 691388
Thanks Meter: 371
A310F bit4 - where others failed, including combi+...
SM S/N: BABxxxxB
Firmware Version: 0101
Phone found on COM312
Phone In Download mode...
Reset FRP Procedure started...
Port open Ok!
LOKE received!
Prepare Ok!
Enter Setup...
Try download PIT...
Download PIT Ok!
Reset FRP done
Reboot phone...
The Following 2 Users Say Thank You to maremestera For This Useful Post:
Old 07-06-2018, 21:56   #203 (permalink)
Member: 2576731
Thanks Meter: 72
[/B]how to buy this activation pls i need it be4 too late
[/B]
Old 07-06-2018, 22:46   #204 (permalink)
Member: 1677653
Thanks Meter: 2,769
[/B]
Contact your reseller to buy just 55 infinity credit, then login to your iOS account and activate....
Old 07-06-2018, 23:37   #205 (permalink)
Alfareedmobile's Avatar
Member: 2675538
Thanks Meter: 90
I think best for samsung octopus or z3x don't need this we need mtk spd or Qualcomm updates its special for Chinese phone
The Following User Says Thank You to Alfareedmobile For This Useful Post:
Old 07-07-2018, 04:05   #206 (permalink)
Member: 1372118
Thanks Meter: 139
Originally Posted by salmanshan007 View Post
2FA52AE2
you must by activations
[/B]
contact nearest re seller
Old 07-07-2018, 08:06   #207 (permalink)
Member: 2091717
Thanks Meter: 5
Serial No (S/N): 7E427460 updateis now
Old 07-07-2018, 08:36   #208 (permalink)
Member: 2091717
Thanks Meter: 5
=== DongleManager [Infinity] v1.72 [07/07/2018 08:37:51] ===
Searching...
Card-Reader: FT SCR2000 0
HWID: 0101746014D11292
Box/Dongle found: [BEST]
Reading...
Firmware version: 0122.02
=== Process started: 07/07/2018 08:37:54 ===
Checking DongleManager version...
Your DongleManager is up-to-date
Checking Dongle Identification...
Server answer:[0007] No updates found for your Smart-Card. DO NOT try more today !
Old 07-07-2018, 12:01   #209 (permalink)
Member: 387154
Thanks Meter: 70
SM S/N: BABxxxxB
Port open Ok!
LOKE received!
Prepare Ok!
Enter Setup...
Try download PIT...
Download PIT Ok!
Reset FRP done
Reboot phone...
Trick talckback not work, must use combination file to enable adb,
and flash with modified file when normal boot and remove frp in setings or with box !
Old 07-07-2018, 23:26   #210 (permalink)
Member: 1334744
Sonork: 1617739:dammy21
Thanks Meter: 14
S/n 28a2915c support acoount active but infinity cm2 sm not working with cm2mtk2v2 and cm2scr thanks
Page generated in 0.26766 seconds with 9 queries
