05-05-2018, 11:56 | #2 (permalink) |
Crazy Poster Join Date: Nov 2017
Member: 2778250 Status: Offline Thanks Meter: 7 | === DongleManager [Infinity] v1.70 [5/5/2018 15:55:44] === Searching... Card-Reader: Generic EMV Smartcard Reader 0 HWID: 00009A4C187A4082 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): 55629A4C Firmware version: 0136.02 === Process started: 5/5/2018 15:55:46 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0007] No updates found for your Smart-Card. DO NOT try more today ! |
05-05-2018, 11:57 | #3 (permalink) |
Member: 2778250 Status: Offline Thanks Meter: 7 | === DongleManager [Infinity] v1.70 [5/5/2018 15:56:54] === Searching... Card-Reader: Generic EMV Smartcard Reader 0 HWID: 00009A4C187A4082 Box/Dongle found: Infinity-Box/Dongle Serial No (S/N): 55629A4C Firmware version: 0136.02 "UK Edition" status: Off Last launched Application: 0030 v.0136 => Activations: - 00: Infinity-Box/Dongle v.0136 - 07: module #07 |
05-05-2018, 22:03 | #4 (permalink) |
Freak Poster Join Date: Feb 2011 Location: ALGERIA Age: 43
Member: 1513870 Status: Offline Thanks Meter: 46 | So 1-turn your antivirus off 1-inistall previous version with IObit Uninstaller 2-extract cm2mtkr2 setup in disktop and unstall as administrator dont (install from the rar file) 4-Add an exclusion in your antivirus and add CM2MTKR2 in my case i use avast 4-and after you finish steps run as administrator And i think you can run good luck |
The Following User Says Thank You to sgreenphone For This Useful Post: |
05-06-2018, 15:02 | #5 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | @flashing-center There is no problem with your dongle, it's Ok. So try to check what new software you have installed during last days. Also uninsall CM2MT2, delete CM2MT2 older, install it again |
