Old 04-22-2017, 21:01   #1 (permalink)
Member: 980481
Thanks Meter: 14
to Infinity Suport #2
Chinese Miracle II  [MTK module] v 1.58
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 42 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BB_CPU_NME : [MediaTek] MT6582_S00
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
[DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED
Boot Error!
Operation Failed
Elapsed: 00:00:26
Reconnect Power/Cable!
to Infinity Suport
Infinity-Box Chinese Miracle-2 MTK/Mediatek Be on the last list.
No updates
Does not support modern devices
many problems . No solution
The team works on add-ons. There is no value to it
All box have been updated
Not updated from date 2016-Oct-06
Dear Team
The product is. We do not work
I promise you about myself. If not download update will not renew
It will be a general invitation to facebook
Old 04-22-2017, 21:10   #2 (permalink)
Member: 2105719
Thanks Meter: 19
I agree with you about 70%.
Old 04-22-2017, 22:05   #3 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 15,597
Go and use tools, which "support" "modern" phones and challenge their patience after with "why it not work" requests.
For rest - check news section at http://www.infinity-box.com
The Following 3 Users Say Thank You to JayDi For This Useful Post:
Old 04-22-2017, 22:09   #4 (permalink)
sky73's Avatar
Member: 1876736
Thanks Meter: 361
Team doing great work on spd lg qlm rka rda
About mtk it still better then others they add only format for secure boot thats what you need?
Btw:hold both volume keys for mt6582 secure boot
Old 04-22-2017, 22:56   #5 (permalink)
Member: 980481
Thanks Meter: 14
Wait for phone...
Phone found! [ 102 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
Processing DA stage
Running DA ver.4.2 on BBID : 0x87
NAND Flash : NOT INSTALLED
eMMC Flash : 90014A48414732650507AFA1993262B3
Initialize Memory ...
[DA_ERROR] : DRAM Configure failed!
ErroCode : 0x2003
EMICFG_NOT_FOUND
Firmware selected, but it NOT compatible!
Boot Error!
Old 04-23-2017, 23:03   #6 (permalink)
Member: 1043909
Thanks Meter: 51,305
@eslamhero
You can do all what you want, invitations on facbook, twitter or even in your ms-dos command prompt.
Hope you understand that your way to ask for a help is a little bit strange.
Thread closed.
The Following User Says Thank You to YellowBoss For This Useful Post:
Page generated in 0.29741 seconds with 7 queries
