Old 11-14-2009, 03:34   #1 (permalink)
Member: 369802
Thanks Meter: 82
to infinity support , pls we need alcatel 203ex simfree file in support
pls kindly upload simfree file for alcatel 203ex support area. i had a network locked to orange, i flashed with file in support area but now display virgin mobile,and locked to virgin mobile. i m sure with simfree file will be unlocked perfectly.
Old 11-16-2009, 22:39   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
Here is direct unlock solution for Alcatel models.
It's beta solution, need to test it and see what will be the results.
Please, try to unlock phone with this new software:
http://www.infinity-box.com/download...dule_v2.94.rar
It is no need to flash phone, just use "SP-Unlock" button from software "Service" page.
Waiting for your results.
Old 11-16-2009, 23:50   #3 (permalink)
Seedy's Avatar
Member: 8102
Thanks Meter: 118
Originally Posted by InfinitySupport View Post
Hello,
Tried it and phone is dead just blinking when holding power button
Any idea how to revive?
COM4 [VCP0] selected
module v2.94
Device: Alcatel-203X, 203A, 203E
Checking data, wait...
Action: rebuild security area
Boot ...
19200 fixed
Connecting, wait...
Initializing [6223:8A05:8A00]...
CPU: MT6223
chip: 0011:742D:A00C
status: 01
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: 01227E221A2201:2BEA0000000000
flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb
Initialize Done
Set baud ...
460800
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
searching rom info...
search rom info finished
rom info structure: 2nd [standard] generation
TCL-ID is present
rom info detection finished
TCL-ID detection...
TCL-ID detection done
rom info protocol ver: 05
ver. sw 1: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28_F1.BIN
ver. sw 2: MAUI.08A.W08.36.SP1.V28.F1, 00000000
address offset: 00000000
ffs offset/size: 003A0000/00058000
TCL-ID identification
version: 37E
provider: 203EX-2BRGGB1
customization: CM37CS32
customization: XM37CS32
TCL-ID identification done
ffs address assigned: 003A0000
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
sim-lock status: enabled
product id: JRD_COMMUNICATION_U91X_PRODUCTS
area1 is valid
area2 is valid
area3 is valid
area4 is valid
searching sec info#2...
search sec info#2 finished
security area (sec info, part #2) calculation...
done
Write: security area (sec info, part #2)
security area (sec info, part #2) calculation done
security area (sec info, part #1) calculation...
..................security area (sec info, part #1) detecting size...
security area (sec info, part #1) detecting parameters...
security area (sec info, part #1) encoding...
done
Write: security area (sec info, part #1)
security area (sec info, part #1) calculation done
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
Write Done
Finalization ...
ffs formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-203X,203A,203E_JRD23_NEP_08A_PCB01_GSM_MT6223_S00. MAUI_08A_W08_36_SP1_V28_F1__system_log__00000000_2 0091116-224643.B0X.bin
Finished, time used: 72 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
The Following User Says Thank You to Seedy For This Useful Post:
Old 11-16-2009, 23:57   #4 (permalink)
Member: 130995
Hello,
1. send C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-203X,203A,203E_JRD23_NEP_08A_PCB01_GSM_MT6223_S00. MAUI_08A_W08_36_SP1_V28_F1__system_log__00000000_2 0091116-224643.B0X.bin to [email protected]
2. read full flash backup and send full flash backup file to [email protected]
3. check battery voltage
4. try to press and hold phone "Power" button for a long time
5. if still no luck, try to make "repair security area"
6. if still no luck, try to flash phone with any firmware from support area
Old 11-17-2009, 00:02   #5 (permalink)
Seedy's Avatar
Member: 8102
Thanks Meter: 118
Hi
1 & 3 will be done in a few minutes
3 - its full
4 - already tried
5 - already tried (I am sorry but the backup will contain this - while doing this i did get an error about security error part 2 so will use existing)
6 - will let you know later if okay after flash
Old 11-17-2009, 00:11   #6 (permalink)
Member: 130995
Hello,
"system_log" file received and required data extracted.
If you will be need to restore phone to it's original state we will be able to do so after we will get full flash backup from phone in it's current state.
Also we will try to double check unlock process.
I am very sorry for troubles !
Old 11-17-2009, 00:23   #7 (permalink)
Seedy's Avatar
Member: 8102
Thanks Meter: 118
okay two things
First flashed with the 203EX flashfle and now working but locked to Virgin
Secondly have you got an Orange UK Flash file so at least I can restore phone?
Thirdly anyway of unlocking this at the moment?
Thanks
Old 11-17-2009, 05:45   #8 (permalink)
Member: 130995
Hello,
I did not received full flash backup from you yet, please, send it anyway.
You can try to unlock phone again now.
Updated software can be downloaded by the old link.
Please, keep me informed about results.
Old 11-17-2009, 12:04   #9 (permalink)
Seedy's Avatar
Member: 8102
Thanks Meter: 118
full flash now sent - will let you know outcome of unlocking this evening
The Following 2 Users Say Thank You to Seedy For This Useful Post:
Old 11-17-2009, 15:02   #10 (permalink)
Member: 130995
Hello,
Please, use latest software for unlock: http://www.infinity-box.com/download...e_v2.94_v2.rar
Old 11-17-2009, 19:29   #11 (permalink)
Seedy's Avatar
Member: 8102
Thanks Meter: 118
Finally success - one click unlock
One thing though is it possible you can upload Orange UK flash for 203ex?
module v2.94
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
status: 01
Boot Done
Initialize ...
Initialize Done
Set baud ...
460800
Set baud Done
TCL-ID is present
TCL-ID detection...
version: 37D
provider: 203EX-2AVRGB1
customization: CM37CN35
customization: XM37CN35
area1 is valid
area2 is valid
area3 is valid
area4 is valid
customization name adjusted
done
Write ...
Write Done
Finalization ...
ffs formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-203X,203A,203E_JRD23_NEP_08A_PCB01_GSM_MT6223_S00. MAUI_08A_W08_36_SP1_V28_F1__system_log__00000000_2 0091117-182653.B0X.bin
Finished, time used: 76 sec
The Following 4 Users Say Thank You to Seedy For This Useful Post:
Old 11-17-2009, 20:05   #12 (permalink)
Member: 130995
@Seedy
yes, we will prepare and upload flash file in support area ASAP.
Old 11-18-2009, 10:09   #13 (permalink)
Member: 369802
Thanks Meter: 82
module v2.94
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
status: 01
Boot Done
Initialize ...
Initialize Done
Set baud ...
460800
Set baud Done
TCL-ID is present
TCL-ID detection...
version: 37D
area1 is valid
area2 is valid
area3 is valid
area4 is valid
done
Write ...
Write Done
Finalization ...
ffs formatting...
Finalization Done
yes u are right, its done 100%
@Seedy
thanks alot infinitysupport, pls upload to support 4 others to benefit
Old 11-18-2009, 11:54   #14 (permalink)
Member: 130995
Hello,
We want to get test reports and probably fix some possible problems with some models before we upload this software for all users in support area.
It may be that we will need to make some software modifications for some models.
Old 11-18-2009, 20:26   #15 (permalink)
geriaf's Avatar
Member: 193303
Sonork: 100.1613585
Thanks Meter: 104
Good solution for OT600A.
COM7 [VCP0] selected
module v2.94
Device: Alcatel-600
Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
chip: 0001:0203:A00A
status: 01
Boot Done
Initialize ...
flash: 98000300000001:08EA0000000000
flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb
Initialize Done
Set baud ...
921600
Set baud Done
rom info structure: 2nd [enhanced] generation
TCL-ID is present
startup code area #1 is Ok
startup code area #1 backup saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\id.91 B03FAE.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN_C4B7397C].rpl
TCL-ID detection...
device-id: 91B03FAE
ver. sw 1: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN
ver. sw 2: MAUI.06B.W07.28.SP1.V38, 7C39B7C4
address offset: 00020000
ffs offset/size: 00C00000/00400000
version: 266
provider: 600X-2EVRGB1
customization: CJ26NG12
customization: XJ26NG12
ffs address assigned: 00C00000
startup code area #1 check...
startup code area #1 fixed
product id: JRD_COMMUNICATION_B82X_PRODUCTS
area1 is valid
area2 is invalid
area3 is valid
area4 is invalid
area1 is valid
area2 is valid
area3 is valid
area4 is invalid
searching sec info#3...
search sec info#3 finished
area1 is valid
area2 is valid
area3 is valid
area4 is valid
number of sec info areas: 3
error: security area (sec info, part #2) header is invalid
done
done
done
original imei: 00000000000000
Write ...
Write Done
Finalization ...
ffs formatting...
Finalization Done
file saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\Alcat el-600_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_2 8_SP1_V38__system_log_91B03FAE_C4B7397C_20091118-142316.B0X.bin
Finished, time used: 218 sec
But i can't change imei to this model, any solution??
The Infinity team is the best!!!
The Following User Says Thank You to geriaf For This Useful Post:
Alcatel 203x simfree file not on support francogsm Infinity-Box 10 03-11-2010 22:16
Alcatel Ot363 won't power on with simfree flash in support abdoune Infinity-Box 39 11-18-2009 17:15
I need alcatel S319a simfree fullflash supercell Infinity-Box 0 06-06-2009 22:41
Dear Infinity-Team Where Is O2 X3 Model Flash File In Support Area Pls Help uttam Infinity-Box 4 01-06-2009 16:24
Need Sx1 Intel Flash File in support ssatcom SST-Dongle 1 08-12-2005 22:08
Page generated in 0.33604 seconds with 9 queries
