12-02-2008, 10:24 | #1 (permalink) |
Freak Poster Join Date: Dec 2007
Member: 642536 Status: Offline Thanks Meter: 22 | infinity support help.... wat to do .. here is log Do you want to continue ? COM20 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: reset Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:2003:0001 boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE50090000000001345 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: MT6225_06B_PCB01_GPRS_MT6225_S00.A10_V007_KQ_08051 2.BIN ver. sw2: A10_V007_KQ_080512, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 98004900000002:18E59F00000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... flash: 98004900000002:18E59F00000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... formatting... flash: 98004900000002:18E59F00000000 Finalization Done Finished, time used: 38 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
12-02-2008, 10:34 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, If phone can not power-on and can not be formatted in "safe" mode this means that firmware is not good (or is incompatible with phone hardware) or hardware is damaged. At first check phone hardware. |
for infinity-support help | EASYTECH | Infinity-Box | 8 | 04-06-2008 06:06 |
want infinity support help for chines phone | bharatg | Infinity-Box | 4 | 12-29-2007 10:22 |
infinity support helpe me | DEHGHAN | Infinity-Box | 1 | 09-04-2007 13:01 |
Infinity support help | Nenadpin | Infinity-Box | 1 | 08-25-2006 09:55 |
infinity-support help | vascof1 | Infinity-Box | 5 | 05-17-2005 16:52 |
