Infinity Support Help My BenQ C30 Infinity Support Help My BenQ C30, how to flash this phone give me solution this phone Hank BenQ Logo and restart :confused::confused: |
infinity box after birth good support mtk. |
Hello, What is phone connector type ? Where is GND and Charge pins at phone connector ? |
I can not access this link, pls post it again. |
Yes, sir. I need BENQ C30 firmware file ASAP. Connected with Chinese Miracle. Here my log, I try to format ffs but still restart... Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] v2.57 S/N: ***x : ***x Wait... Device: Autodetect 6205-6227 NOR Done WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? COM4 [VCP0] selected Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:0D03:000E Connecting, wait... Release Power button now ! Phone detected, wait... warning: wrong packet cs Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: MARCH_BENQ_L3EN_205_070919_LY3_SIV100_SA75_HTF_FM Version: CKT25_06B_HW detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok building list... done items to clear: 169 warning: wrong packet cs 169 of 169 items cleared building list... done 0 items remains Finished, time used: 28 sec Remove/Install battery now ! Or if anyone have a good phone, please read it and then upload it here. Thanks, |
Hello, What is phone connector type ? What is pinout (RX, TX, Gnd pins) ? Also if you want to see this phone in supported models list read flash from this phone and send flash backup file to: [email protected] so we will be able to make support for this phone. |
coz i have dead phone after flashing by others person.and i need your backup file your phone :D :D |
It's good idea to send flash backup files to [email protected] so we will be able to upload new files in support area for all users. |
here is the correct link.. http://www./showpo...59&postcount=9 or http://rapidshare.com/files/11142701...30_6225_FF.rar br, kevin168 |
damaged phone coz before you upload files in the support this phone have flashing with anothers files,and i use MT6225 files with Chinesse Miracle Module.....please help me sir,i need another files to solved this problem. |
BenQ-C30 model supported http://www./showpo...59&postcount=1 Flash files in support area. BenQC30_CKT25_06B_APAC_PCB01_GPRS_MT6225_S00.MARCH _BENQ_L3EN_220_071224_LY3_SIV100AB_SA75_CTF_FM_En_ Id_Hi.B0M. |
100% hardware problem coz i have 2 time this problem |
