Old 05-01-2009, 08:04   #1 (permalink)
Member: 647448
Thanks Meter: 13
Question Infinity support please help
Sir ia am using infinity box since last 2 year it was working fine on all chines mobile .
Nut from last two month i cant repair any chines mobile .
When i formate any mobile formatting complets but mobile dead .
I had tried 24 chines mobiles all mobiles were on and had software fault but after formating all my mobile are dead now .
I had reinstall windows and complete infinity box setup..
I had tried to repair all mobile using "repair software"
but problem same.
Thanks in advance.
Old 05-01-2009, 08:38   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,296
Hello,
What is the problems exactly with each phone ?
Post here operation log.
Old 05-01-2009, 14:40   #3 (permalink)
Member: 647448
Thanks Meter: 13
Post Sir here is operation log
Originally Posted by InfinitySupport View Post
Hello,
COM3 [VCP0] selected
module v2.81
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: "format ffs"
Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A03:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:3603:0005
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: 98000300000000:18A59F00000000
flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
Set baud ...
115200
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
device parameters autodetection in progress...
it's time to stop: 18B09FA518B09FA518B09FA518B09FA518B09FA518B09FA5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detection phase #2...
warning: identification#1 information not found, possible reasons:
.old firmware type w/o identification#1 data
.damaged firmware
.damaged hardware
if phone works fine just ignore this warning
detect device identification#1 finished
detect device identification#2...
detect device identification#2 finished
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset assigned: 00E00000
checking area [00000000]: 00000000-00FFFFFF...
Can't detect ffs/eeprom area
Do you want to use standard ffs/eeprom address: 00E00000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
standard ffs/eeprom address selected by user
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
Write Done
Finalization ...
formatting...
Finalization Done
Finished, time used: 103 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Old 05-01-2009, 14:47   #4 (permalink)
Member: 647448
Thanks Meter: 13
Post Please solve my problem
Sir my all 24 mobile have same log which i had shown above but al mobile have same problem they doesn't power on .
Even some of them were on before i formated them
so please solve my problem because i am only based on infinity box.
Old 05-02-2009, 23:59   #5 (permalink)
Member: 148515
Thanks Meter: 14,904
hello!
best solution is making full backup before operation.
also, smarter is to make Format FFS safe
only after safe format do not help- proceed to complete format
Infinity Support! please help ottyone Infinity-Box 4 05-30-2008 16:38
to infinity support please help hooshi Infinity-Box 7 04-18-2008 14:04
Strongly Need Help With Pinfinder Box, Infinity Support please Help. yeerk05 Infinity-Box 23 03-13-2008 20:24
infinity support please help me lie_james Infinity-Box 5 03-04-2008 19:25
Infinity support please help. jay k sundrani Infinity-Box 4 07-28-2007 09:49
Page generated in 0.28230 seconds with 8 queries
