03-11-2009, 13:28 | #1 (permalink) |
No Life Poster Join Date: Feb 2008
Member: 701779 Status: Offline Sonork: 100.1622334 Thanks Meter: 121 | infinity support team...... ver. sw 1: APL216_PCB01_GPRS_MT6230_S02.APL216_V1_2_20080918. BIN ver. sw 2: APL216_V1.2_20080918, 9C534816 |
The Following User Says Thank You to lorenzo roberto For This Useful Post: |
03-11-2009, 22:36 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! [bin] flashfiles/ChineseMiracle/_MT6230/APL216_PCB01_GPRS_MT6230_S02.APL216_V1_2_20080918_ 128m_En_Ru_Fr_Farsi_Ar.B4M.bin |
03-12-2009, 00:06 | #3 (permalink) |
Member: 701779 Status: Offline Sonork: 100.1622334 Thanks Meter: 121 | yes sir i already used this flashfiles but its gives me an error write fail.. phone now is dead, when i try to write back my read fullflash back up still the same error write fail. phone condition before will reboot when i used the i pod menu and also insert sim> action taken format ffs safe mode no luck. complete ffs mode> result: now i pod menu works fine... only insert sim was not fix. so i decided to flash phone with flashfile from download support and went to dead phone how could i revived this phone sir i have the logs if you need it just check my early post yesterday. thanks |
03-13-2009, 10:24 | #5 (permalink) |
Member: 701779 Status: Offline Sonork: 100.1622334 Thanks Meter: 121 | here's my logs sir please help me asap my *******r is in hurry... module v2.78 Device: Autodetect 6228-6230 NAND Checking data, wait... Action: write NAND flash read mode: 01 write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs source data: page only identification#1 protocol ver: 04 ver. sw 1: APL216_PCB01_GPRS_MT6230_S02.APL216_V1_2_20080918. BIN ver. sw 2: APL216_V1.2_20080918, 9C534816 ffs offset/size: 02000000/06000000 id-page1 Ok end mark #2 found nfi area detection finished: Ok Boot ... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing [6230:8A02:8A02]... CPU: MT6230 high speed boot Off chip: 0031:0000:0101 status: FF high speed boot Off boot packet size: 0400 Release Power button now ! Boot Done Initialize ... version: 3.020C loader: 3.748.0 NAND id: ECF10095 page size: 800+40 pages/block: 40 bits i/o: 08 address cycles: 04 blocks: 0400 NOR: 0000:000000000000 [00000000] NAND: 00EC:00F100000095 [08400000] NOR chip is not installed Initialize Done Set baud ... 115200 Set baud Done Identification ... reading bootloader structure area... detecting bootloader structure... warning: probably flash chip completely erased, no bootloader found nfi area detection finished: failed warning: can't detect nand chip parameters, default values assigned security area (code #1) calculation... Identification Done Write ... error: unexpected answer: error: incorrect write core parameters error: can't write nand core Write Fail Finished, time used: 115 sec Remove/Install battery now ! |
03-13-2009, 15:02 | #6 (permalink) |
Freak Poster Join Date: Jun 2006
Member: 295357 Status: Offline Thanks Meter: 15 | sir my pinfinder no update plz help show this error ----------Process started: 7:00:26 PM---------- Locating server... Server address found#1 Connecting to server#1... Server connection successfully established S/N: ********, Firmware: 0112.02 Authenticating on server... Authentication stage error: Server reported error:[0007] No more upgrade logs: Dongle is up-to-date and has latest firmware. Don't try more ! If software can not start (or SmartCard data is damaged) contact to [email protected] |
03-14-2009, 22:41 | #7 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
please send email to [email protected] include dongle number and detailed problem description. please note that "my pinfinder no update" is not detailed problem description. | |
03-15-2009, 04:33 | #8 (permalink) |
Member: 701779 Status: Offline Sonork: 100.1622334 Thanks Meter: 121 | sir i need your guidance to revived my i phone 16GB i just flash the said phone to repair insert sim using flashfile from download support area.. please response you ask me where was the error and i already post the logs check it out sir... |
03-15-2009, 22:41 | #10 (permalink) | |
i saw your tread http://forum.gsmhosting.com/vbb/showthread.php?t=698688 will reply soon | |
03-22-2009, 19:33 | #12 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Try to use this software: http://www.infinity-box.com/download...9_for_test.rar Waiting for your results. |
03-23-2009, 05:07 | #13 (permalink) | |
Member: 701779 Status: Offline Sonork: 100.1622334 Thanks Meter: 121 | Quote:
COM6 [VCP10] selected module v2.79 Device: Autodetect 6228-6230 NAND Checking data, wait... Action: write NAND flash read mode: 01 write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs source data: page only identification#1 protocol ver: 04 ver. sw 1: APL216_PCB01_GPRS_MT6230_S02.APL216_V1_2_20080918. BIN ver. sw 2: APL216_V1.2_20080918, 9C534816 ffs offset/size: 02000000/06000000 id-page1 Ok end mark #4 found nfi area detection finished: Ok Boot ... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing [6230:8A02:8A02]... CPU: MT6230 high speed boot Off chip: 0031:0000:0101 status: FF high speed boot Off boot packet size: 0400 Release Power button now ! Boot Done Initialize ... version: 3.020C loader: 3.748.0 NAND id: ECF10095 page size: 800+40 pages/block: 40 bits i/o: 08 address cycles: 04 blocks: 0400 error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: NOR: 0000:000000000000 [00000000] NAND: 00EC:00F100000095 [08400000] NOR chip is not installed Initialize Done Set baud ... slowest Set baud Done Identification ... error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: reading bootloader structure area (00080000 bytes)... error: unexpected answer: warning: nfi read command is not accepted error: bootloader structure area read failed, read again... error: unexpected answer: warning: nfi read command is not accepted error: can't read area required for bootloader structure detection: 00000000 instead of 00080000 error: unexpected answer: Identification Done Write ... error: unexpected answer: error: write bootloader command is not accepted error: can't write nand bootloader Write Fail Finished, time used: 180 sec Remove/Install battery now ! | |
where are the infinity support team? | lorenzo roberto | Infinity-Box | 8 | 03-22-2009 19:32 |
Attention for infinity support team plz !!! | Mobile_plus | Infinity-Box | 4 | 01-25-2009 22:20 |
help please infinity support team | hik | Infinity-Box | 2 | 10-13-2007 21:47 |
@ Infinity Support Team! | minhtrimobile | Infinity-Box | 1 | 10-18-2006 16:30 |
@ Infinity Support Team! | minhtrimobile | Infinity-Box | 0 | 08-26-2006 10:14 |
