08-21-2006, 07:43 | #1 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Inside MTK Age: 38
Member: 248182 Status: Offline Thanks Meter: 786 | @ infinity supporter recently i purchase i ininitybox for c168 flashing first i install infinty driver and serial number reader then i go to support area and downlod the infinity full setup 2.3 then i downlod the main,lp,flx,img and mld files for c168 then i dont understand i have rj45 cabel for c168 so what comport i select and what is the meaning of mbus and fbus and backsite of infinty on off button what the feature of this button can infinity flashes c168 @ rj45 cabel what can i do i try but phone no connection then i go to market and purcahe the serial cabel now i am connect this cabel serial port 1 and select the comport 1 and baud rate 115200 then select flash file and click start so the error is this COM1 selected Device: C168 Checking data, wait... Action: Flash write Write: Firmware Write: Flex Write: Language Pack Skip: FFS/File system Write: Images Write: Melody Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... SW ver: HW ver: Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0089:886400010001 Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Write: Firmware Flash: 0089:886400010001 Writing Fail Finished Remove/Install battery now ! so i have 4 pice and both on i try all infinty erase ok but flash fail why and my 4 phone c168 are died plz plz help me and suggest what can i do ???? |
08-21-2006, 08:15 | #2 (permalink) |
Freak Poster Join Date: Feb 2005 Age: 43
Member: 115515 Status: Offline Thanks Meter: 1 | These are the pictures of infinity box details. If you want to know how to connect using com port cable see the following link. http:///vbb/showth...highlight=C139 |
08-21-2006, 08:38 | #3 (permalink) |
Member: 248182 Status: Offline Thanks Meter: 786 | Infinity check this picture why this picture rx led is not blinking why is my box problem plz check and tell me in this picture [IMG]C:\Documents and Settings\basil\Desktop\untitled.GIF [/IMG] |
08-21-2006, 10:22 | #6 (permalink) |
Member: 248182 Status: Offline Thanks Meter: 786 | @ tazz hi i have t191 cabel for moto its flash or not c168 if not so plz explain whic cabel flash this phone i don't understand x700 plz expalin me |
08-21-2006, 12:19 | #8 (permalink) | |
Dear Mr. BluffMaster Please, check this link: http://forum.gsmhosting.com/vbb/showthread.php?t=207207 You can see how to configure Infinity-Box (set switches, connect cables). Also, you can find there information how to select correct COM port. As about C168: Go to www.infinity-box.com and download latest Moto02 software from support area "Updates" section. Use cable supplied with box. Cable mark: "X60", it's hands-free cable with 3 (three) metal pins. | |
