05-07-2009, 05:59 | #1 (permalink) |
Banned Join Date: Jan 2008
Member: 677796 Status: Offline Thanks Meter: 102 | Huawei-T161L SIM INVALID 100% OK write eperom file. . . change IMEI 100% ok .. COM17 selected module v1.60 Device: Huawei-T161L Checking data, wait... Action: "repair imei" new imei: 353960024487140 Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-static_20000624-195051.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-security_20000624-195052.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-complete_20000624-195058.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_imei-area_20000624-195118.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_lock-area_20000624-195139.B1E.bin backup critical area Done Check memory ... lock found imei found #1 Check memory Done Write ... Erasing: imei-area Writing: imei-area Erasing: lock-area Writing: lock-area Erasing: eeprom-security Writing: eeprom-security Write Done Finished, time used: 116 sec Remove/Install battery now ! Finished....................... ***********, |
The Following User Says Thank You to kashi4lucky For This Useful Post: |
05-09-2009, 18:44 | #2 (permalink) | |
Each test report with attached logs is very important for us so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type) and what is possible problems (so we will be able to fix it) and successfully done work. | |
Huawei-T161L unlock ok | shahid41 | Infinity-Box | 0 | 11-18-2009 05:10 |
UNLOCK ALL MODEL Huawei T158B,Huawei T156B,Huawei T161L,Huawei,KENYANS CONTACT ME NOW | hassanjinja1 | Main Sales Section | 0 | 10-22-2009 13:45 |
6300 NEW dual sim INVALID sim ok 100% working | themobileshop | Infinity-Box | 1 | 09-09-2009 18:30 |
C225 Isert Sim Slution 100% ok | gilani4_all | Samsung Hardware Repair | 3 | 10-12-2008 10:47 |
cect T689 opening sim B 100% OK. | shoeb7 | Infinity-Box | 5 | 09-08-2008 18:48 |
