10-11-2008, 12:43 | #1 (permalink) |
Freak Poster Join Date: Jul 2004 Location: always around
Member: 74338 Status: Offline Thanks Meter: 11 | To infinity supporter: success with motorola w220 ffs formatting!!! i.e COM3 [VCP0] selected Device: Motorola-W220 "advanced chip detection" active Action: reset Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! loading... Boot done Check connection... Check connection done Set baud... 115200 Set baud done Check hardware... flash: 89886400010001:89886400000000 flash: Intel Intel std [def 007Fx010000 0008x002000] 8Mb version sw: 1120-000 version sw: SCY-7- Check hardware done Read data... reading Motorola-W220_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Motorola-W220_eeprom_calibration-1_20081010-193847.6AE.bin reading Motorola-W220_ffs... file saved: C:\Program Files\InfinityBox\HModule\Motorola-W220_ffs_20081010-194044.6AE.bin Read data done Check data... Check data done Writing... flash: 89886400010001:89886400000000 Erase: ffs Writing done Finished, time used: 147 sec Remove/Install battery now ! pls make direct unlock for alcatel c and ot i.e. c825 etc. |
The Following User Says Thank You to dennis1 For This Useful Post: |
10-11-2008, 18:18 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
problem with motorola w220 | fasternaiger | Infinity-Box | 5 | 03-10-2009 16:03 |
problem with motorola w220 | amrsayed30 | Infinity-Box | 3 | 06-27-2008 02:25 |
Strange Problem With Motorola W220 | AbdulKadir | Infinity-Box | 6 | 12-12-2007 21:26 |
KG800 to KG90 flash success with LG GSM Toos V2.0.1 HWK patched by killer | y2khjh | Twisterflasher | 7 | 01-22-2007 22:56 |
Help me With C117 Showing FFS Formatting Only | Moderate | Infinity-Box | 1 | 11-02-2006 09:38 |
