02-11-2015, 15:08 | #1 (permalink) |
No Life Poster Join Date: Dec 2013
Member: 2085670 Status: Offline Thanks Meter: 35 | infinity team ?????? Device : QMobile i9 AndroidVer: 4.4.2 MTKxCPU : MT6582 MTKxPRJ : ALPS.KK1.MP1.V2.10 ISPFF ID : 6582 TARGET ID : 6582 FlashFile is differs from eMMC settings, continue by user request Flash pre-erase enabled Erase Flash now ... Flash pre-erase done Write Flash now ... [ MCU ] : i9 ok file.bin Init Ok , Sending blocks ... Write failed Flash Error! Check Cable, Battery , try again Operation Failed Elapsed: 00:00:59 Reconnect Power/Cable! ======= Flash Files set for flashing : [ MCU ] : i9 ok file.bin 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 12 ] Sync... Open port error , something went wrong! Boot Error! Operation Failed Elapsed: 00:00:02 Reconnect Power/Cable! Bead update ialwys i get this error ido maney time but infinity activion is very brack heart update |
02-11-2015, 15:18 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | What is that all? Can you explain on English? Normal English. Your logs tells much about your zero ( "0" ) knowledge. Maybe not need touch phones? It bad idea for some peoples at all. |
02-11-2015, 15:41 | #3 (permalink) | |
Member: 2085670 Status: Offline Thanks Meter: 35 | Quote:
i do maney time write file on Q mobile i9 MTK 6582 white infinity box ,he show this error alwys (it have maney b**** )in all update,infinty team nerver give 100% ok update | |
02-11-2015, 17:38 | #4 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | What write? Where write? Maybe, check your phone first, instead of trying write inside it something "maney time" ? Until you not learn how use software and how post logs, explain all - better you try yourself in other way, not with mobiles. |
02-11-2015, 18:12 | #5 (permalink) |
Member: 2085670 Status: Offline Thanks Meter: 35 | Dear ; I also working on mtk 6572 and 6582 chip but he can not do this I also read file on this box and after that when we write this file other phone then I am facing this problem if he work fine then why I do post dear; Plz never mind never hipper |
