03-09-2015, 16:31 | #1 (permalink) |
Product Supporter Join Date: Mar 2008 Location: Thailand Age: 46
Member: 716581 Status: Offline Thanks Meter: 767 | To Infinity team But i need infinity team add read mtk factory file for OPPO Mobile. Thank you. |
The Following User Says Thank You to nongmobile For This Useful Post: |
03-10-2015, 07:09 | #3 (permalink) |
Member: 716581 Status: Offline Thanks Meter: 767 | Start at : [8/3/2015 / 19:56:35] Operation : Read Flash [ v1.14 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Device boot not done Check Drivers Try again Boot Error! Operation Failed Elapsed: 00:00:40 Reconnect Power/Cable! Finish at : [8/3/2015 / 19:57:15] Start at : [8/3/2015 / 19:58:32] Operation : Read Flash [ v1.14 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 153 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582|8312_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004B4A5330304D03F45D5807C0F7 DA Stat : v4.2 on BBID : 0x87 Configure emi settings Error : DA init Failed! Error code : 0x5 Boot Error! Operation Failed Elapsed: 00:00:06 Reconnect Power/Cable! OPPO R827 |
03-10-2015, 07:11 | #4 (permalink) |
Member: 716581 Status: Offline Thanks Meter: 767 | Start at : [18/2/2015 / 16:38:00] Operation : Read Flash [ v1.11 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 52 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164040501A1C0BE516D DA Stat : v4.2 on BBID : 0x88 Configure emi settings Error : DA init Failed! Error code : 0x5 Boot Error! Operation Failed Elapsed: 00:00:30 Reconnect Power/Cable! OPPO R821 |
03-10-2015, 07:31 | #5 (permalink) |
Member: 716581 Status: Offline Thanks Meter: 767 | Operation : Read Flash [ v1.14 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 153 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8B00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575_S00 Processing BROM stage i2c Init : 00008810 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : M00SJ [eMMC] : FLASH_CID : 1501004E4A5330304D00BCE73BB311C3 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x00000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... USBDL : Init HSUSB Ok! Not supported CPU for this operation yet Done! Elapsed: 00:00:22 Reconnect Power/Cable! oppo r8113 |
03-10-2015, 08:16 | #6 (permalink) | |
No Life Poster Join Date: Mar 2007 Location: Factory Reset Protection (FRP) Age: 13
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,543 | Quote:
Code: Preloader Status : Not active (Erased) | |
03-10-2015, 08:53 | #7 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | MT6572,MT6582 : Looks like alive, but no need press any boot key. If still same - need find those FlashID's to add in CM2. MT6575 : not supported for factory FW reading. |
03-10-2015, 15:24 | #11 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | All MTK6571 , MTK6572 , MTK6582, MTK6589 , MTK6592 supported for FW reading. Problem , which can be : 1) "BootKey" pressed - can be fixed by check side keys and not press them during connect , or disabled preloder - can be fixed only by adding flash ic to CM2 DB. 2) PMT-disabled phones. Mostly solved in latest updates. 3) Cable/Driver/Win errors - on CRC errors only |
07-21-2015, 19:32 | #12 (permalink) |
Junior Member Join Date: Mar 2015 Location: INDONESIA
Member: 2364237 Status: Offline Thanks Meter: 2 | please help me sir...i have problem with oppo r1001,first case bootloop and then i flash with spflashtool ,the phone still bootloop,,and i format via spflashtool,after that the phone dead only vibrate,thanks a lot off,sorry my english bad |
