11-26-2007, 08:17 | #1 (permalink) |
No Life Poster Join Date: Jul 2006
Member: 308296 Status: Offline Thanks Meter: 152 | infinity team can u read my problem warring proberly flash chip empety earased and after reading i m not found the any name of flash Here is log Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: read NOR flash Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6205:8B00]... boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E221A2201:FFFFFF00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #01 in region #00... flash: 01227E221A2201:FFFFFF00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #02 in region #00... flash: 01227E221A2201:FFFFFF00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #03 in region #00... flash: 01227E221A2201:FFFFFF00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud... 115200 Set baud Done Identification... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E221A2201:FFFFFF00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb Warning: probably flash chip empty, erased, incorrectly flashed or damaged. What to do: 1. go to software "Settings" page 2. set "Advanced chip detection method" box UN-CHECKED ! 3. make flash write operation If still no luck: send mail to support with detailed description of problem, attach the next files in your e-mail: 1. E:\Program Files\InfinityBox\ChineseMiracle\operation.log 2. E:\Program Files\InfinityBox\ChineseMiracle\cfi_xxxx_xxxx.bin detecting chip #01 in region #00... flash: 01227E221A2201:FFFFFF00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF number of flash chip/regions detected: 01/01 total flash region size: 00400000 detect device identification, method #1... detection phase #1... . detection phase #2... .................................................. .............. warning: identification information not found, possible reasons: .old firmware type w/o identification data .damaged firmware .damaged hardware detect device parameters finished detecting eeprom area in 1 chip(s)... flash: 01227E221A2201:FFFFFF00000000 checking area[00000000]: 00000000-003FFFFF... Can't detect eeprom area Do you want to use standard eeprom address: 00380000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard eeprom address selected by user detecting eeprom size... eeprom size: 00080000 eeprom chip: 00 eeprom area: 00000000:00380000-003FFFFF reading [flash]... warning: wrong data size at 0x00196C00, retry... read error recovered warning: wrong data size at 0x001D4400, retry... read error recovered file saved: E:\Program Files\InfinityBox\ChineseMiracle\Zt678\backup_flas h_20071126-124205.B0M.bin Finished, time used: 499 sec Remove/Install battery now ! sir after all the backup is only 6Kb and not define any name of falsh file its show only this name so plz tell how to i m find a proper flash file for this set the name of file is backup_flash_20071126-124205.B0M |
11-26-2007, 08:33 | #3 (permalink) |
Member: 308296 Status: Offline Thanks Meter: 152 | sir i m when read first time of the backup of set so i mread of this name file DAYO_NEP_06B_PMJ_PCB01_GSM_MT6205B_DN.MAUI_06B_W07 _20_MP_V7.BIN]_20071116-154219.B0M is only 3mb sir plz give me the advise whoes the best flash file for this set th Thanks in advance |
Can my Infinity Team can add this model? | Kashif Khan | Infinity-Box | 0 | 04-30-2009 23:48 |
Infinity Team Please help with my Infinity.... | ASHRIFF | Infinity-Box | 1 | 03-10-2008 16:51 |
@Infinity Team :How to read or reset phonelock for Bird V10 | anhtam | Infinity-Box | 3 | 07-16-2006 11:02 |
Infinity Team can update Vk900 | KAITA | Infinity-Box | 0 | 12-19-2005 10:49 |
Infinity Team Can You Help Me Quick ?? | distefano | Infinity-Box | 2 | 11-04-2005 18:58 |
