Old 04-13-2009, 01:11   #1 (permalink)
Member: 240756
Thanks Meter: 90
To Infinity Team,Facing New Problem
Hello Infinity Team,
Now a days im facing new problem that i can not make any operation with
MT6228 Cpu base fone.always one Error shows(error Unexpected answer)
Mobiles are on working condition,just Restart Problem.not a single mobile
more then 5 MT6228 cpu not format nor read detail information.
Here is a 1 example Logs.
COM4 [VCP0] selected
module v2.81
Device: Autodetect 6228-6230 NAND
Checking data, wait...
Action: read/check detailed information
Boot ...
19200 fixed
Connecting, wait...
Initializing [6228:8A02:8A02]...
CPU: MT6228
high speed boot Off
chip: 0031:0000:0101
status: FF
high speed boot Off
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
version: 3.0207
loader: 3.748.0
NAND: Hynix HY27XS08121M 512+16 32 pages, 66Mb
NAND id: AD76AD76
page size: 200+10
pages/block: 20
bits i/o: 08
address cycles: 04
blocks: 1000
finalize connection...
done
emi configuration...
emi configuration done
check bootloader validity...
error: unexpected answer:
done
NOR: 0000:000000000000 [00000000]
NAND: 00AD:007600AD0076 [04200000]
NOR chip is not installed
Initialize Done
Set baud ...
slowest
Set baud Done
Identification ...
reading bootloader structure area (00010000 bytes)...
warning: nfi read command is not accepted
error: bootloader structure area read failed, read again...
error: can't read area required for bootloader structure detection: 00000000 instead of 00010000
Finished, time used: 140 sec
Remove/Install battery now !.
Tried evrything what i can do.
slowest speed,highiest Baudrate.at everybaudrate i try but same result.
i can not understand that My infinity is damaged or what?
MT6226 and others are having no problems.good flash good format.
I request to infinit team,plz kindly help me and solve this nonsense problem.
i will be very thankfull to Infinity team.
im using infinity for 3year.
Thanx in Adv............
Old 04-13-2009, 08:39   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
There is no any problems with your box.
Try to press and HOLD phone "Power" button more long time, probably it may helps to solve problem.
Old 04-13-2009, 20:00   #3 (permalink)
Member: 240756
Thanks Meter: 90
@Infinitysupport
Thanx to infinity team
not help,Same problem..
COM4 [VCP2] selected
module v2.81
Boot ...
baud autodetection active
19200 autodetect
Connecting, wait...
CPU: MT6228
high speed boot Off
status: FF
high speed boot Off
Boot Done
Initialize ...
version: 3.0207
loader: 3.748.0
NAND id: AD76AD76
page size: 200+10
pages/block: 20
bits i/o: 08
address cycles: 04
blocks: 1000
done
done
Initialize Done
Set baud ...
115200
error: can't work at this speed, use lower speed
Set baud Fail
Finished, time used: 101 sec
Old 04-13-2009, 20:11   #4 (permalink)
SHOEB AHMED's Avatar
Member: 161115
Sonork: Here you can find it...
Thanks Meter: 3,039
Hardware Problem,rihot phone cpu and try
Old 04-13-2009, 22:32   #5 (permalink)
Member: 130995
@Aazib jhon
I don't think that it's a problem with latest software, but to be sure, please, make this test:
download and install previous ChineseMiracle version (f.e. 2.79) and test your phone with previous version.
What is the results ?
Old 04-15-2009, 00:15   #6 (permalink)
Member: 240756
Thanks Meter: 90
@Infinitysupport
Same Result.problem is stil yet.
COM14 [VCP0] selected
Device: Autodetect 6228, 6230 NAND
Boot...
19200 autodetect
Connecting, wait...
Initializing[6228:8A02:8A02]...
CPU: MT6228
high speed boot disabled
high speed disabled
boot step size: 0400
Boot Done
Initialize...
version: 3.0207
loader: 3.748.0
NAND id: AD76AD76
page size: 200+10
pages/block: 20
bits i/o: 08
address cycles: 04
blocks: 1000
Initialize Done
Set baud...
115200
Set baud Fail
Finished, time used: 106 sec
im in deep trouble now.i don't know what should i do more?
now im going to change my pc.then i will post result.
(this logs is from another infinity box)i also changed pinfinder cable.
anyway thanx infinity team.!
(version chinese miracle 2.61 and 2.78 tried)
Old 04-18-2009, 21:57   #7 (permalink)
Member: 130995
Hello,
I don't think that it's a problem with software due to it was done no big changes with initial communication in latest ChineseMiracle versions.
Try to adjust port settings:
Let's see results.
Old 04-18-2009, 22:35   #8 (permalink)
GSM-XPERTS's Avatar
Member: 1001830
Sonork: 100.1652282
Thanks Meter: 242
try it with minimum speed and check ur cable
may be its hardwere fault
to infinity team fix problem R306 ayhen42 Infinity-Box 1 01-17-2010 09:17
to infinity team please respond(((solution new alcatelīs avaible.. residentdenuevo Infinity-Box 8 08-20-2009 19:28
to infinity team plss add new firm ware s22ou ayhen42 Infinity-Box 0 06-07-2009 09:34
i am facing new problem like this kasim iPhone 2 / iPhone 3G / iPhone 3GS 0 08-04-2008 08:52
Page generated in 0.19545 seconds with 9 queries
