INFINITY TEAM Help Hi... I want to unlock Alcatel S319x... But after flashing, Its came to a BLUE SCREEN only.... heres my last logs Code: ==== log: [3/5/2009 11:40:40 AM] ==== I flashed it to the NEW firmware... I flashed the phone with EEPROM from the support... But Still BLUE SCREEN... but you can make a call... But Blue Screen How do I do now???? HELP... bR |
what was the firware in the set before flash. |
Here.. Code: ==== log: [3/5/2009 11:02:38 AM] ==== |
Hello, It may be hardware <-> firmware incompatibility. Try to flash phone with higher firmware version (select file with latest release date). |
Hello friend this is very simpel problem that you need full flash file right the full flash file.with smart right. [email protected] |
What Exact File do i use??? I use This 2 New FW on the support... Code: S319A-2ARGDO4_XH16NF11_JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_36_SP1_V20_2008-06-26_En_Fr_Es_Pt-BR_It.B0M.bin http://207.218.205.237/download/inde.../winxp/new.png bR |
Hello, Try to flash phone with this file: S319X-2GPWGB1_XH16DP32_JRD23_07A_PCB01_GPRS_MT6223_S00.M AUI_07A_W07_36_SP1_V20_2008-10-29_En_Fr_Es_It_De_Orange-Uk.B0M.bin What is the results ? |
let me finish my flashing using this file >>>> S319X-2BVGGB1_XH16CS20_JRD23_07A_PCB01_GPRS_MT6223_S00.M AUI_07A_W07_36_SP1_V20_2008-08-28_En_Fr_Es_It_De_Virgin.B0M.bin br |
I My phone is ok now using this FW >>>> S319X-2GPWGB1_XH16DP32_JRD23_07A_PCB01_GPRS_MT6223_S00.M AUI_07A_W07_36_SP1_V20_2008-10-29_En_Fr_Es_It_De_Orange-Uk.B0M.bin... But the Problem is, its Locked Again :( bR |
Hello, yes, it's the problem. We need a time to prepare unlock solution for latest firmware/hardware type. We will try to make it ASAP. I can give you some files for tests and you can try it (if you have some time) but I am not sure in success. Will prepare and upload some files ASAP. |
Hello, Files uploaded. Try to make this: 1. download "customization" files from this folder: \flashfiles\Alcatel\S319\parts 2. flash phone with "customization" files one by one and see results (make "format ffs" checked during each flash operation) if you will see some good results, please, test phone carefully, be sure that all buttons and functions works well. waiting for your results. |
Ok... its clear now... can you upload the file here or give me your MSN, i will test it now, when the phone is here... bR |
Hi... Here is the Result... I put all the costumization files that you upload at the support site.... All BUTTONS are working, receiving and making call , but the problem is this...If you are on the MENU, you did'nt go to all ICON inside there.... Hopely you will find a way to resolve this... thank you very much INFINITY... nice Box.... regards FDSALESREP ( turon ) |
U may check this http://forum.gsmhosting.com/vbb/showthread.php?t=681998 all ready clearly discussed about this problem , any way u r now on right and last way ... we need the perfect customized firmware for this ... |
